Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Globetrotter > 1962 Globetrotter
Old 03-05-2007, 01:04 PM   #43
A-Merry-Can
Addicted to Aluminum
A-Merry-Can's Avatar
Profile:  1959 18' "Footer"
1962 19' Globetrotter
1964 24' Tradewind
Woodstock , Georgia
forgot to ask, is there any reason why i can't run all of my sewer vents out a single pipe? that's teh way it was in my 18 footer. i can't figure out why a 19 foot globe trotter would need 3. i assumed i could run a vent tube up from the drain pipe to the grey tank, and put a "T" connection in there to run one from the black tank as well... leaving only a single hole/pipe sticking through the roof... much beter than having all 3, less than 3 feet apart, poking through the end cap! yuck!
jp
8576 • • • • • • • •
there's always room for one more!
• • www.toolbox-design.com • •
A-Merry-Can is offline   Reply With Quote
Old 03-05-2007, 02:18 PM   #44
C Johnson
C Johnson's Avatar
Profile:  1965 17' Caravel
Portland , Oregon
Images: 326
jp
Yes, I think there is a reason for the two vents. One for the black tank alone and one for the rest of the sewer system. Thats the way my Caravel is set up anyway. Not knowing how you are doing your tanks though, you might get away with one vent. You could plumb the sewer system vent and black tank vents together, I would think. Depends on routing of the pipes. In my trailer it was just easier to reuse the existing two holes and routing.
Chris AIR # 7276 WBCCI # 7276
WBCCI Forum Save Wally Forum
Photos of Project 2k5 My Blog Chris' World
My Pictures
C Johnson is offline   Reply With Quote
Old 03-05-2007, 04:43 PM   #45
A-Merry-Can
1964 24' Tradewind
Woodstock , Georgia
i'm planning on running the black and grey tubes half way up the wall before T-ing them together. that should give me plenty of vertical distance to make sure the vent stays clear. The way things are set up, the black tank can vent straight up from the top of the tank. So can the grey, in fact. i'm thinking at this point it will be ok to run them together. i can't tell you how much i hate those sewer vents poking through the rear endcaps. especially when you know how hard it is to replace those panels! ha!
jp
Old 03-06-2007, 12:59 PM   #46
A-Merry-Can
1964 24' Tradewind
Woodstock , Georgia
Another patch done!
for the arm-chair airstreamer, here's a little sequence i did at lunch today... vent-pipe-ectomy #2...
step one, remove that caulk mess around the pipe. there is NO way Airstream did this kind of work. i can't figure out why the forward vent has an aluminum cowl around it, and a clean simple seal, while the rear 2 looked like this mess. horrible!
anyway, i removed the big chunks with a screw driver and putty knife...
Old 03-06-2007, 01:00 PM   #47
A-Merry-Can
1964 24' Tradewind
Woodstock , Georgia
step 2, remove the pipe by pulling it into the trailer, then get rid of the crud-covered rusty ring...
Old 03-06-2007, 01:01 PM   #48
A-Merry-Can
1964 24' Tradewind
Woodstock , Georgia
the shell was covered with excess caulk and sealant... nasty stuff... so i let it soak for 2 hours in caulk remover...
Old 03-06-2007, 01:02 PM   #49
A-Merry-Can
1964 24' Tradewind
Woodstock , Georgia
next step was to clean all that mess up, and hit it with the buffing wheel to polish the metal. i like a clean aluminum surface to seal to... no dirt!
Old 03-06-2007, 01:04 PM   #50
A-Merry-Can
1964 24' Tradewind
Woodstock , Georgia
i flattened out the bumps from the old screw holes, and taped the patch in place, making sure to mark one edge with a pen for re-installation. VERY important to make sure the holes line back up when you put it on...
... then i drilled, and clecoed away...
Old 03-06-2007, 01:06 PM   #51
A-Merry-Can
1964 24' Tradewind
Woodstock , Georgia
take it off, clean up teh aluminum shavings, and put a good amount of sealer on there. i used alcoa, so i wouldn't have to open up a fresh tube of vulkem. it works great. so far i have done 7 patches this way, and no leaks!
Old 03-06-2007, 01:08 PM   #52
A-Merry-Can
1964 24' Tradewind
Woodstock , Georgia
rivet time!
Old 03-06-2007, 01:18 PM   #53
A-Merry-Can
1964 24' Tradewind
Woodstock , Georgia
i don't have a rivet shaver, $200 for one NON-motorized tool! so i dremel mine, clean the surface with acetone, and buff to a shine! ouala!
i know all this is basic stuff that we all already know and do... but it's fun to see the pic sequence, no?
jp
Old 03-06-2007, 01:27 PM   #54
GreatPumpkin
GreatPumpkin's Avatar
Profile:  1964 26' Overlander
Colville , Washington
Images: 66
jp
YES Living vicariously until I retrieve mine from winter storage at the end of the month.
AIR 12256
1964 Overlander
1999 Dodge Ram 1500
2001 Honda XR650R
"In regione caecorum rex est luscus."
GP
GreatPumpkin is offline   Reply With Quote
Old 03-06-2007, 02:55 PM   #55
pinkflamingoes
pinkflamingoes's Avatar
Profile:  1967 24' Tradewind
Alameda , California
Images: 40
curious
I don't want to hijack this thread...I have a question though, when you do an aluminum patch, what do you do to the patch so the edges of it are smooth? Or do you just cut out a piece of aluminum and put it on that way? Your repair job looks gorgeous. Nice work, I'm following this thread. I'm glad you rescued this baby.
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 03-06-2007, 03:56 PM   #56
Marti
Marti's Avatar
Profile:
Images: 20
I say we save EVERY airstream and if we can't camp in em, we BOWL in them...
Marti is offline   Reply With Quote
Great 71 Globe Trotter for Sale in WA michaero For Sale & Wanted 0 05-06-2003 08:29 PM
1963 Airstream Globe Trotter - Where Can I find these Parts Uncle_Phil 1963 Globetrotter 10 03-01-2003 10:05 AM
Picture of my project 74Tradewind 1970-76 Tradewind 1 12-21-2002 09:14 AM
Serial number of 1960s Globe Trotter ? What year is it ? oldvws Our Community 1 12-12-2002 08:25 PM
