Old 08-04-2017, 06:58 PM   #1
1961 22' Safari
Phoenix , Arizona
Zolatone Repair
Overall my zolatone is in great shape but I do need to repair places where it is scratched. Can anybody tell me a good way to do this and also how I figure out which color I should use. I have a 1961 Safari which I believe is an Ohio trailer. Thanks so much for any help.
Chris
Felina is offline   Reply With Quote
Old 08-04-2017, 07:17 PM   #2
1966 22' Safari
Fredericksburg , Texas
Way back when there were few Zolatone colors offered. Green seemed to be the predominant color. Zolatone no longer offers that specific color without a special order of a tremendous amount. I guess a thought would be to see if there is an inconspicuous spot in the back of a cabinet, scrape a small piece off and see if your local paint store can come close to matching the primary color. If it looks close, take a small brush and paint the scratches. Zolatone has multiple colored paint particles. The the overall primary color may be the best you can do. Good luck.
Bubba L is online now   Reply With Quote
Old 08-06-2017, 11:19 AM   #3
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Welcome to AirForums Chris!
On our first Airstream (1964 GlobeTrotter), had Zolatone that was in great shape with just a few scratches & minor areas of damage as you describe yours - certainly not bad enough to warrant re-spraying or painting over. I went to a local train model hobby shop and bought the tiny little bottles of model paint in colors like the flecks in our Zolatone and a tiny little brush and dabbed the colors on to blend with the Zolatone. I also "painted" replaced rivets the same way. You could not see the repairs once done.
The key is finding the colors in your Zolatone and keeping the sheen down - a lot of the model paints were "high gloss" (which didn't look right), but I found the model paints had a lot of flat "neutral colors" that blended very nicely with our Zolatone. It just took patience & looks of little dabs letting them dry in between so as not to look muddled.
As I recall though, '61's may have the older Zolatone which is more of a solid color with more random flecks...ours was the newer style that was more solid flecks. Regardless, I think the same approach would work. Find colors that match an faux-finish to match the Zolatone colors/pattern.
On our second Airstream, we stripped years of paint off the Zolatone and re-sprayed new Zolatone - so we didn't have to go through the faux-finishing as in our '64, but I have touched-up replaced rivets in the same manner.
Good luck!
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 08-06-2017, 11:21 AM   #4
1961 22' Safari
Phoenix , Arizona
That is an amazing idea. Thanks so much
To Zolatone or Not to Zolatone jonplayers Upholstery, Blinds, Walls & Interior Finishes 7 07-18-2017 03:50 PM
Original Zolatone or New Zolatone - Value judgement? robwok General Interior Topics 1 12-05-2014 09:34 AM
Zolatone walls Rob Upholstery, Blinds, Walls & Interior Finishes 19 08-05-2009 06:54 PM
Repainting with Zolatone 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 3 06-10-2002 09:58 AM
Zolatone Paint Question ALANSD Upholstery, Blinds, Walls & Interior Finishes 3 03-05-2002 03:25 PM
