Old 03-12-2006, 04:43 PM   #15
CanoeStream's Avatar
St. Cloud , Minnesota
68 Overlander is a commercial vendor. My impression is that 3-stage charging is an improvement over Intellipower with Charge Wizard. The thread link seemed to attract a lot of input from knowledgeable people -- not myself of course. Anybody offer any direct experience with 3-stage charging?
5 meter Langford Nahanni
Old 03-12-2006, 04:57 PM   #16
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Cool, your link worked no better than my repeated attempts. Moderators?
I have direct experience - I tried to share it in my two failed attempts at posting a link to the thread.
Tom
Old 03-12-2006, 05:04 PM   #17
Cut & Paste then...
Maybe the mods are watching the NCAA B-ball selections and working on their picks ... .
How can we fool the software? This is not a hyperlink (ie, you can't just click on it). Copy the following into your browser address window and hit Return: airstreamforums.com/forums/f206/got-3-stage-charging-yet-17326.html
Yep! That works!!
Old 03-12-2006, 11:30 PM   #18
Hippo's Avatar
Battle Ground , Washington
I will junk the uni-volt
OK thanks for all the info I will remove the uni-volt and replace it with a modern unit.
Chuck
Hippo is offline   Reply With Quote
Old 03-13-2006, 08:45 AM   #19
1975 29' Ambassador
Reno , Nevada
The charge wizard does provide 3 stage charging. It also provides battery maintenance functions.
see http://www.progressivedyn.com/chargewizard_home.html
My impression is that the Intellepower charge wizard setup is a bit kinder on your batteries that some dedicated 3 stage chargers. Its battery maintenance is also a significant improvement over many of the alternatives.
Old 09-04-2007, 06:19 PM   #20
Albuquerque , New Mexico
Univolt not working
71tradewind, to access the capacitors did you just pop the rivets to the univolt case and then you could get to them to replace them? Thanks for the info, I also have a 71 tradewind 25'.
Gonyo73 is offline   Reply With Quote
Old 06-08-2011, 11:05 PM   #21
Saint Charles , Missouri
After much lurking here, it's time to show my face and give thanks.
I was able to repair the Univolt V Model TU-345A with these capacitors.
KKSF66P405QAPI - Capacitor, Oil. 4uF.
16v no load, 12.6v with a 12 v cigarette lighter attached.
My first capacitor in the parallel circuit was bulged on top, and shorted out. replaced them and all is working great. (I do have plans to upgrade to 3 stage charging in the future, but this Overlander is at a permanent location, so other things need higher priority)
Regal1 is offline   Reply With Quote
Old 06-08-2011, 11:36 PM   #22
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
Hi and welcome to the board - lurk no more.
Thanks for posting the part info
AirForums Custom Search
Janet H is offline   Reply With Quote
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
Univolt reminder ** Battery Check! Sav'h Steve Batteries, Univolts, Converters & Inverters 21 10-07-2003 02:18 PM
Removing Old Univolt & Installing New Intellipower 9160 montanaandy Electrical - Systems, Generators, Batteries & Solar 3 07-15-2003 11:08 AM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 08:26 PM
