Hi, I have a 72 Tradewind and cannot figure out how to reassemble and install my wardrobe plastic latch - those pesky little things. Does anyone know what the sequence is? Or, where I can get some DETAILED instructions? Thanks. Daniel
Best quick suggestion would be "very carefully" take apart the latch from another door.
Then reverse the process to reinstall it, as well as the new one
Not enough info, Andy
You can be as carefull as if you were handling a snake, and all of a sudden a spring flies to where ever springs go.
I've trid and can't get the hang of putting them back together either
