Old 07-17-2017, 08:51 PM   #1
Drought Buster's Avatar
1978 25' Tradewind
Darlington , South Carolina
Taillight assembly
So in the 3 light assembly the inside lamp is a turn signal and brake light, the middle is a reverse light, and the outside is an 1157 bulb. What does this light do other than a taillight?
Drought Buster is offline   Reply With Quote
Old 07-18-2017, 07:09 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The 1157 bulb is a dual filament bulb. It is both the tail light and the brake/turn signal.
A close look at the bulbs filaments and you will notice one filament has a finer (smaller) gauge. This is the tail light. The filament closest to the top of the bulb has a heavier (larger) gauge. This is the brake/turn signal.
There should be 2 wires coming out of the base. You can test which is which with a 12 volt power source. The brighter one is the brake/turn signal.
Old 07-18-2017, 07:23 AM   #3
1978 25' Tradewind
That is what I was thinking. The brake light isn't working on either side, so that gives me a place to start.
Old 07-18-2017, 02:23 PM   #4
1978 25' Tradewind
Upon further inspection there is a wire that has either been cut or broken. This evening's project. Thanks for your knowledge!
Old 07-18-2017, 04:49 PM   #5
1978 25' Tradewind
Any idea where the yellow wire goes?
Old 07-18-2017, 07:51 PM   #6
Slats's Avatar
1966 24' Tradewind
Kansas City , Missouri
I've always heard that yellow, containing the letter L, is for the left turn signal and green, containing the letter R, is for the right turn signal.
Slats is offline   Reply With Quote
Old 07-18-2017, 07:53 PM   #7
1977 31' Sovereign
2005 30' Safari
1977 28' Argosy 28
North Port , Florida
Yellow is generally back up lamp
cliffcharb is offline   Reply With Quote
Old 07-18-2017, 08:03 PM   #8
1978 25' Tradewind
It looks like the yellow was never hooked up.
Old 07-18-2017, 08:07 PM   #9
1978 25' Tradewind
I don't see where the yellow wire should go.
Old 07-18-2017, 08:47 PM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Is the yellow wire connected to the light fixture?
Check to see if it is the brake/turn signal or the tail light by connecting it to a 12 volt source. If it is the tail light just connect it to the fixture on the right in the photo. Were you see the wire nut.
If it is the brake/turn signal you are probably going to have to do some digging in to the wire loom.
Old 07-18-2017, 08:51 PM   #11
1978 25' Tradewind
It is for the brake light. The tail light works. I'll have to dive into the wire loom it seems.
Taillight Bulbs Trailer Girl Electrical - Systems, Generators, Batteries & Solar 17 09-10-2004 04:19 PM
Autolamp Taillight Gasket? 66Overlander Electrical - Systems, Generators, Batteries & Solar 7 06-04-2004 11:24 AM
taillight bulbs davidz71 Lights - Interior & Exterior 4 02-14-2003 08:59 AM
Wet taillight Pahaska 2002 - 2005 International 5 12-27-2002 01:16 PM
Taillight gaskets? davidz71 Lights - Interior & Exterior 0 09-10-2002 05:26 PM
