Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Tradewind > 1970-79 Tradewind
Old 08-29-2012, 08:31 PM   #1
Airstream Newby
CMSmith's Avatar
1975 25' Tradewind
Florence , South Carolina
Switches by the door
There are two switches right next to the door on my '75 Tradewind, the second one is broken and I have no idea what it's does. Anyone with a '75 Tradewind able to tell me what that switch is for? The first one turns on the exterior light over the door, a third one closer to the front window turns on the scare light.. Help me out, Tradewinders!
CMSmith is offline   Reply With Quote
Old 08-29-2012, 08:33 PM   #2
Ottawa , ON
On my '75 Sovereign, the closest switch is the light over the sink, and the further one is the outside light over the door.
Scare light switch is on the other side of the stack window.
Old 08-29-2012, 08:34 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
There are two by my 68. One does the outside light the other does the middle light in the trailer, so when you come in you don't have to fumble for the light.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-29-2012, 09:17 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Same thing on my '67 Trade Wind.
Vaughan
Old 08-30-2012, 06:13 AM   #5
Airstream Newby
CMSmith's Avatar
1975 25' Tradewind
Thanks, I need to get a new switch so I can use it. I hate walking in and searching for the knob on the overhead light. It must be in the on position, at least, since all interior lights are working for me.
Old 08-31-2012, 05:30 AM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
On the 1975's it should work the kitchen light over the sink area. However it is wired different from a standard 3 way switch like you would have in a house. You have to turn the kitchen light switch on first, then use the door switch to turn it on and off. It doesn't matter what position the door switch is in the kitchen light switch overrides it.
Aaron
WBCCI #XXXX AIR #2495
Old 08-31-2012, 06:35 AM   #7
Ottawa , ON
Aaron
Well, there's a difference between the '74s and the '75s: on my TT, it works as a true three-way. No matter how the sink light is set, it can be turned on from the door.
Old 08-31-2012, 06:50 AM   #8
Kevin245's Avatar
Aaron
Same with our 76.
William C. Swinney
Old 01-09-2014, 12:39 PM   #9
1975 25' Tradewind
VA Beach , Virginia
That 3 way switch for over the sink light on mine had burned up switch in fixture. Found replacement switch at a electronics supply store and converted fixture to LED strips and converted all the other lights . now the battery drain is nominal even with all turned on.(Amp meter barely moves)Much cheaper than LED Pads.
jimrich60 is offline   Reply With Quote
Old 01-09-2014, 03:04 PM   #10
1975 25' Tradewind
VA Beach , Virginia
Easy upgrade LED
Up Grade to Strip LED is easy even on Incandescent fixtures just drill out rivets and remove sockets.
12 Inch Led Light Upgrade and Repair - YouTube
