Old 08-03-2011, 06:17 PM   #1
1973 25' Tradewind
1962 22' Safari
Augusta , Georgia
Split rims? How long were they OEM equipment?
Currently in process of finalizing deal for a 1973 Tradewind (25-feet) that is about 300 miles away- mostly interstate. Seller says it will need new tires before going far. Any thoughts on if this would have split rims or not. If I knew it had single piece rims would drive up and pull old tires/rims off and get new tires at local tire store, check bearings, brakes, and head home. Have access to F-250 dually so functioning brakes is not a real concern - just don't want any hanging shoes. For new tires thinking of something like 225/70 or 215/75 - suggestions welcome on this as well.
Looking forward to this project.
Dennis
DGJackson is offline   Reply With Quote
Old 08-03-2011, 06:54 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Not sure when they quit using split rims, but they were not in use in 69 so you will be ok with your 73.
The standard tire back then was 700-15. These are usually replaced with ST 225/75R 15.
Load range C or D although I would favor the D.
Good luck with the new project
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Split Rims gotta go, is this a correct replacement? Tabasco Wheels, Hubs & Bearings 20 03-23-2012 01:48 AM
1961 Bambi wheel rims jennings0566 Wheels, Hubs & Bearings 2 08-24-2011 12:10 PM
1965 overlander tires and rims? buddyboy54 Tires 3 08-03-2011 08:04 PM
Baby Moons for my new 15" rims airdoxy Wheels, Hubs & Bearings 1 07-27-2011 04:10 PM
"The Long, Long Trailer" GeocamperAS Hitches, Couplers & Balls 14 05-10-2011 07:02 PM
