Old 09-25-2015, 01:15 PM   #1
1976 25' Tradewind
mill valley , California
Replacing Belly Skins.....Help
Hello i have a 76 TW and i have full gutted the floors and belly skins. I am replacing all the skin under the trailer with Aluminum. What I am wondering is should i replace the Aluminum segments that are on the lower part of the trailer that rap around under to the frame? I friend says that some small pitting can be noted in the aluminum down on those aluminum raps.....do you guys think i should leave them in place or replace them....Also how hard is it to rivet these areas back together and can i use the same rivet holes ?
tamvalleyman is offline   Reply With Quote
Old 09-25-2015, 02:09 PM   #2
1979 23' Safari
Wayland , New York
Just finishing up my belly have one corner to finish up, rear street side. Replaced the wraps as well.
You can use the old wraps if they're still in good shape, it's subjective. I did it as mine were rough and I was doing the rest anyway. If you do use the old as templates. You can try using old rivet holes bit it's not easy since you have to blind drill trying to line up the drill, it's easier to fill the old holes with rivets and drill new ones.
Overall the whole process wasn't as bad as I thought it would be. Make sure you have nice sharp drill bits. My first bit was a real pain drilling into the frame rails, new bit much easier.
Work so the overlap keeps road spray out.
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Galvanized steel as an alternative to aluminum belly skins perryg114 Belly Pans & Banana Wraps 10 08-07-2012 12:32 PM
Belly Skins? Dano57 Belly Pans & Banana Wraps 11 09-24-2006 09:41 PM
Replacing the belly and cleaning out the walls? Slik Belly Pans & Banana Wraps 1 10-12-2004 12:20 AM
Replacing Skins NSMITH Ribs, Skins & Rivets 8 06-04-2002 03:02 PM
