Old 08-13-2010, 06:15 PM   #1
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
over the door outside light
I can't get the over the door light on, so I removed the three screws and the cover, only found a bulb wrapped in tape with wires comming out the end (and into trailer) I looked in the manual, is this right, no fixture? I have not tried hard, but the bulb does not twist or pull out. Help here is welcomed, and if you know the bulb size....great! MPJ
moparjohn is offline   Reply With Quote
Old 08-13-2010, 07:09 PM   #2
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Last time we fixed ours we were told to be sure NOT to let that wire go back into the shell. We clipped our old light off and put a new one on and then grounded it to the trailer, works fine now, but some of the others will be recommending halogen light up there too.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 08-13-2010, 07:18 PM   #3
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
My 77 has an 1141 bulb that is in a springloaded press and turn socket similar to the ones inside.
4RXLA is offline   Reply With Quote
Old 08-13-2010, 07:19 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Mine had been "repaired" by a PO and was in similar condition.
FYI a trimmed down, double bulb marker light housing with a dab of JB weld fits nicely into the casting.
Made up a new frosted plexiglass lens and its better than new.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 08-13-2010, 09:08 PM   #5
Harry W's Avatar
1978 31' Sovereign
Scottsdale , Arizona
Replacement sockets are available. Try NAPA. Our 78 Sovreign socket disintegrated and with creative bending, the replacement socket was installed. Tom Nuglers fix sounds like a good one also.
Harry W
4CU Charter Member
AIR # 13858, WBCCI # 2420
Harry W is offline   Reply With Quote
Light above door m. Clarke All Argosy Trailers 6 07-03-2009 08:19 PM
Light cover above door - where do I get one? Miss Vicki Lights - Interior & Exterior 2 05-17-2009 06:34 PM
Light or light cover over the door.. help please! harestream Lights - Interior & Exterior 19 08-29-2008 09:51 AM
Over the Door Light B4WEDI Electrical - Systems, Generators, Batteries & Solar 14 01-25-2007 11:28 PM
Light above entry door silver buffalo Airstream Motorhome Forums 3 05-06-2004 07:40 PM
