Old 10-15-2011, 02:04 PM   #1
1975 25' Tradewind
Pawtucket , Rhode Island
New tires
It's probably in a thread somewhere, but I need to replace all 4 tires on my 1975 Airstream. The specs say:
7.00x15
6 ply tires
Or
7.00x15XC
Steel Radial tires
I've been looking all over and have only really found 8 ply.
Help anyone?
udonnelly is offline   Reply With Quote
Old 10-15-2011, 03:38 PM   #2
Mexray's Avatar
1978 28' Ambassador
Morada , California
7:00 x 15 bias ply tires are still a popular trailer tire size...check with any of the national tire chains (no pun intended...) nearby, you should find them...
Ray & Pat; Morada, CA
Old 10-16-2011, 05:06 PM   #3
1975 25' Tradewind
Do you know if I can use ST205-75R15 6 ply tires instead?
Old 10-16-2011, 06:29 PM   #4
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
My preference is a st225-75r15 D rated,I`ve tried cratings and just couldn`t keep the tread on the tires. Dave
easyride is offline   Reply With Quote
Old 10-16-2011, 09:30 PM   #5
Mexray's Avatar
1978 28' Ambassador
Morada , California
The original 700 x 15 tire diameter is about 29.8 "
The 205/75R15's dia is about 27.1 " - which will lower your trailer about 1-1/3 " due to the dia difference, but in reality, probably more due to the radial's more flexible sidewall...
225/75R15's have a dia of about 28.2 " - closer, but will still lower the trailer, giving you a bit less ground clearance...
To retain the original height of the 700 x 15's, (converting to radials) I believe you'd have to change to 16 inch wheels, as many of the current trailers use... 235/80R16's perhaps - dia of 30.8 "...
Old 10-31-2011, 04:47 PM   #6
1972 25' Tradewind
Madison , Wisconsin
7.00x15
6 ply tires
Or
7.00x15XC
Steel Radial tires
Help anyone?
I recall looking for new tires a few years ago. You want 6 or 8 ply C or D load range tires. Cross ply tires are supposed to be a bit stiffer and I have been told (don't know if it is true- but..) cross ply tires are better for most trailers, definitely use an ST type, though I have been told on the lighter trailers (like tradewinds) that LT can also be used.
ST= special Trailer ---very stiff side walls
LT = Light Truck---stiff side walls
If you use a D load tire - only inflate it to C range (50-60) pressure. The tire can take more but your rims are not made for higher loads...this is all second hand though, I am not a tire guy. Search the tire threads, I also got a lot of information from the forum.
Smokin Camel is offline   Reply With Quote
Old 10-31-2011, 05:42 PM   #7
1981 31' Excella II
New Market , Alabama
You can go with a 235/75-R15 XL rated tire truck tire. These are bigger and wider than stock. They are rated a 2185lb if it is 108T load rated.
Perry
Old 11-04-2011, 01:25 PM   #8
mpc
mpc's Avatar
1973 25' Tradewind
Bon Secour , Alabama
Send a message via Yahoo to mpc
I just bought a set of Goodyear Marathon ST225 75R15 load range D thats a good match
mpc is offline   Reply With Quote
Old 11-04-2011, 01:49 PM   #9
SteveH's Avatar
Common Sense , Texas
Yokohama makes a 7r15, the radial replacement of the old 7.00X15 bias ply tire. Yokohama RY215
Regards,
Steve
airstream, tires
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
Wide White Wall Tires wasagachris Tires 14 08-04-2011 09:32 PM
Tires and Alignment Airstream12557 Land Yacht/Legacy Motorhomes 0 06-08-2011 05:04 AM
Towmaster Tires mshamilton Tires 0 05-08-2011 09:38 AM
