Old 07-02-2012, 01:17 PM   #1
kljfamily's Avatar
1975 25' Tradewind
albuqerque , New Mexico
Need replacement thermostat for '75 Tradewind
Hi all,
This weekend I noticed my thermostat was stuck at 80 degrees. So the a/c just get going and going and almost froze us solid since i went to bed with it on. Whats great is its the original a/c and it works just great! I've looked around and am finding it hard to locate a 2 cool only thermostats that would work. Looking at the wiring diagram it says it needs a 24 volt with Y, G1, G2 and R. I cannot find any thermostats that have the g1 and g2 setting. Has anyone replaced theirs with a newer unit? If so how do I wire it to get both speeds?
Kris
kljfamily is offline   Reply With Quote
Old 10-11-2012, 09:46 PM   #2
ricknach's Avatar
1978 25' Tradewind
San Bernardino , California
I replaced mine with a $29.00 unit from Lowes. The units are made by Hunter and are digital and work really well. It come with stickers to go on the wires. Three of the wires go to the Air and two go to the heater.
Rick N
ricknach is offline   Reply With Quote
Old 10-12-2012, 05:33 AM   #3
Taylormade's Avatar
1978 31' Sovereign
Rick N
Errr isn't your heater (furnace) 12V? If so, that AC thermostat from Lowes isn't going to work. You need a 12V t-stat that's separate from the 120V A/C.
Taylormade is offline   Reply With Quote
Old 10-12-2012, 07:10 AM   #4
1981 31' Excella II
New Market , Alabama
Correct me if I am wrong but don't the older trailer have an AC with a separate thermostat from the furnance? Are you just looking for a thermostat with a knob?
Perry
Old 10-12-2012, 08:15 AM   #5
Originally Posted by kljfamily View Post
Hi all,
Kris
Kris.
99 percent of the time, that original thermostat can be repaired in less than a couple of minutes.
I have done it for 40 years.
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 08:31 PM
[Q] MC16c thermostat stuck flashgrbiv Refrigerators 4 05-21-2011 10:48 AM
Replacement Thermostat... Kevo Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-30-2011 08:29 AM
PEX Replacement CAN NOT BE DONE...'75 Tradewind... onemanclan Plumbing - Systems & Fixtures 40 04-16-2011 09:50 PM
Check Valve Replacement 73 Tradewind constructor Fresh Water Systems 1 03-20-2011 02:02 PM
