Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Tradewind > 1970-79 Tradewind
Old 08-08-2010, 06:03 AM   #1
moparjohn's Avatar
1973 25' Tradewind
Bloomsbury , New Jersey
need a quick answer, 8/8/10 8am est
how tall/high is a 72 tradewind including A/C ? Thanks MPJ
moparjohn is offline   Reply With Quote
Old 08-08-2010, 06:10 AM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
According to Airstream.com a 1973 was 8' 10". this was the earliest spec I could find.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 08-08-2010, 06:23 AM   #3
moparjohn's Avatar
1973 25' Tradewind
Thanks, finnally found it too, I hope this hieght includes A/C, bringing home my 72 Tradewind today, one underpass to go through. MPJ
Old 08-08-2010, 06:29 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I would bet it doesn't. FWIW my 1975 will clear 10' but not 9' with the AC.
If yours still has the original axles it may ride a bit lower than what it did originally.
Aaron
WBCCI #XXXX AIR #2495
Old 08-08-2010, 06:35 AM   #5
moparjohn's Avatar
1973 25' Tradewind
OK, thanks, then I will look for a 10ft bridge clearance at min. MPJ
Old 08-08-2010, 07:02 AM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
That would be my suggestion and take it real slow on any questionable ones. I know in NC all of the main roads have clearances for semi trucks which usually require 13'-10"
Aaron
Old 08-08-2010, 07:25 AM   #7
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
Thanks so much for this info as i am considering having my newly purchased trailer shipped to me and this info is required by shipping/hauling companies
LilNomad
LiLNomad is offline   Reply With Quote
Old 08-08-2010, 07:34 AM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
LilNomad
I would have the current owner measure it if possible. There is some variation between models and years, but if it is were mine and coming on a dedicated truck I would want it to be on a drop deck.
Aaron
Old 08-08-2010, 08:48 AM   #9
To be most accurate, the height also depends on the axle condition.
Some owners increase the axle starting angle when replacing the axles.
The limit, according to Airstream and Henschen, is not more than 35 degrees.
35 degrees will raise the trailer an additional 1 1/2 inches above the original axles when new.
However, a few owners have gone with 45 degree starting angles, which will raise the trailer even moreso.
On the other hand, if the axles are original, in this case, the height could be 2 to 3 inches less than original specs.
Andy Rogozinski
Inland RV Center
Corona, CA
Inspection advice Fri 3/6 2-5PM EST ?? Bohemian Buyer Guidelines 1 03-05-2009 04:53 AM
Today's the Airstream Webinar 11:00 a.m. (EST) wheel interested Our Community 16 05-29-2008 03:13 PM
Hey any airstream techs need your help with EST of damage.. Mrcrowley Insurance & Claims 17 06-12-2007 01:01 PM
Need help on est for insurances. Angel73 Insurance & Claims 0 05-15-2006 08:32 PM
Quick answer to replacing my b/w tank 68Glbtrotter Waste Systems, Tanks & Totes 8 01-27-2006 10:29 AM
