Old 09-30-2011, 11:34 AM   #1
Buffysairst's Avatar
1973 31' Sovereign
Vancouver , British Columbia
Looking to buy Tradewind '74
Hi!
My husband and I have been looking for a used airstream for our future family adventures. We have come across a lovely 1974 25' Tradewind.
Current owner says all is in working order. It has most of its original gear and systems. It has a new water pump, new wheels, new flooring, and foam.
It smells clean inside, no musty smells.
Any advice or things to look for before purchasing?
We are also in need of a towing vehicle. Any favourites?
Buffy
Buffysairst is offline   Reply With Quote
Old 09-30-2011, 04:27 PM   #2
1973 25' Tradewind
1962 22' Safari
Augusta , Georgia
Determine the condition of the frame. There are several threads about rear end separation for this era and frame rot around rear end, vents, and stairs. I recently picked up a '73 that was advertised as clean, new floor, ready to camp, etc. I was prepared for frame issues and used to negotiate price. Right now I'm in middle of shell off frame replacement. Sounds bad - but it's not that hard for somebody with a little mechanical aptitude.
Dennis
Augusta, Ga
DGJackson is offline   Reply With Quote
Old 09-30-2011, 04:46 PM   #3
Flynavy's Avatar
1974 25' Tradewind
2008 25' Safari FB SE
Col. Station , Ohio
Hello Buffy and welcome.
We bought our first AS this past spring. It is also a 74 25' TradeWind. It was in origional condition, never been modified, even had all the origional paper work and manuals. The young man we bought from recieved it in an uncles' estate so he knew little about the coach. Our plan was to clean it upa bit, new cushions, floor coverings and such, and go camping. Hasn't worked out that way.
I'm retired so I have lot's of time, and thats a good thing because I have been working on it pretty much full time since June.
What I would look closely at:
Condition of the floor in particular under all the glass, around the furnace, under the frige and in the bath at the rear of the coach. Some of these places are hard to see. Take a metal awl and poke around as best as you can.
Do the holding tanks leak?
Do all the appliances function as they should?
Does the AC work as it should?
The furnace on these units were recalled sometime during the 80's. The recall was never performed on mine so it is unsafe to operate and will have to be replaced.
The list goes on, and I don't type well, but you get the idea.
I am not trying to discourge you. Just be aware that you are buying a nearly 40 year old coach, and it will need work.
All that said, I have no regrets with our purchase. When we are done it will be way cool!
Good luck and feel to PM if you have any questions. Hope this helps.
Paul.
Flynavy is offline   Reply With Quote
Old 09-30-2011, 05:27 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Buffy,
Flynavy covered most everything you need to look for. Make a check list when you look at it and verify that everything is indeed working. Check for soft floor around the door, the rear hatch, and under all vents stacks ( all these places very prone leaks).
Check the axles, you can go to Inland.com and read about what to look for. Best thing would be to have someone go with you who "knows" Airstreams.
I looked at a trailer this week that a young lady had purchased it and thought it was in great shape. She did not know Airstreams and although the exterior condition was great the trailer had many serious problems. All of the issues will take lots of time and or money to fix. If you can not do the work yourself due to skill or time be aware that shop rates for RV work are approaching $100/hr in many places.
Hope it works out, Trade Winds are the "best".
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 09-30-2011, 06:53 PM   #5
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
There is an excellent used-Airstream evaluation checklist here on the forum site.
I used it when I was searching, to first eliminate one bad choice and to validate the Argosy we're very happy with. It's just one of the many great pieces of information on this site.
David
Old 09-30-2011, 07:26 PM   #6
cameront120's Avatar
1972 25' Tradewind
Make sure to ask the current owner to have all systems up and running for you when you visit next so that you can be assured that everything is operational. The only way to know that the water heater, stove & oven, furnace and fridge are working is to see them running.
North Vancouver, BC
Old 10-01-2011, 08:16 PM   #7
1973 31' Sovereign
Thanks for all the great advice! We are taking a second look tomorrow with an inspector. Hopefully we will be newbie Airstreamers tomorrow!
Old 10-01-2011, 09:31 PM   #8
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
We really like our Tradewind. If you buy that one, and it needs a few things, don't be afraid to just USE it as-is. It seems many people buy the vintage models and then gut them for a complete reno and then lose steam.
As for tow vehicles, these units come in a 4000-4500 lbs. with a fair bit of tongue weight. We have a Ford F-150 rated at 6600 lbs. towing with the 4.6 V-8 and it's marginal in headwinds or up steep grades. On level ground it's fine, it's just under extreme conditions it lacks the power.
Look at where you want to tow (mountains?) and judge accordingly.
Good luck & safe travels!
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 10-01-2011, 11:46 PM   #9
Yhottys's Avatar
1960 24' Tradewind
1961 16' Bambi
Oakland , California
Airstream Inspector?
Welcome to the forums Buffy.
Our gateway Airstream was our 1974 Tradewind. We bought it sight unseen from a very honest couple. That being said, we had no idea how to operate any of the systems. All we knew was that the air conditioner was blowing cold and it was clean. It took us four years to figure out why water wasn't being pumped from the fresh water tank even though the pump was functioning. (Open water valve - at the rear of the trailer - aha!)
We also bought the trailer before we had a tow vehicle. Our first truck was a Dodge Ram 2500 and it pulled the trailer well. We made it up Grant's Pass on the way home from Seattle. We've since gotten a new truck, a Ford F350 XLT Power Stroke Diesel and it will pull a house.
You mentioned that the seller doesn't know much about the Tradewind - so it's great that you've found an inspector to help you check out the systems.
Good luck, welcome to the Airstream life and hopefully, the 1974 Tradwind Club!
Gemma and Murray
Yhottys is offline   Reply With Quote
Old 10-02-2011, 07:19 AM   #10
1977 Argosy 24
Milltown , Wisconsin
Whenever you buy a 30+ year old trailer you should automatically figure in the replacement of the furnace and the water heater in the final price. I have owned 2 older Airstreams and my current 1964 Avion, and I had to replace both items in all 3 trailers. The way I look at it, you would never have a 30+ year old water heater or furnace in your house for safety and fuel usage reasons, so why do it in your camper? The new water heaters with electronic ignition are so much easier to use then the old ones that you have to light from outside the trailer. Since you can turn them off and on from inside, you save fuel by only having the water heater on 15 minutes before you need to use hot water. The new furnaces are the same deal with electronic ignition, and much quieter when running. I sleep much better knowing I am not going to be over come by carbon monoxide due to a cracked heat exchanger in my original furnace also.
ventport is offline   Reply With Quote
Old 10-02-2011, 09:27 AM   #11
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
Inside of 37 yr old furnace. Was good for 50+ ppm co on detector after 15 minutes use. Knife stuck in split joint and corrosion lower center. New furnace now installed. Good luck in your quest......Phil.
pgr32e is offline   Reply With Quote
Old 10-02-2011, 09:44 AM   #12
Originally Posted by Buffysairst View Post
Hi!
Buffy
Please be advised that "everything in working order", is an opinion, not fact.
How well the working order is the real answer.
When was the last time the furnace was removed and cleaned, last time the reefer burner oriface was removed and cleaned, when was the window, entrance door, access door gaskets replaced, and when was the sewer vent pipe cover gaskets replaced since those only last 2 to 3 years?
Whats the condition of the clearcoat, since the original only lasts 5 to 6 years or so?
When were the axles checked out to see what the condition of the rubber rods may be, since torsion axle rubber rods, if used often can only last 30 t0 35 years or so, and much less if parked for a long period like a couple of years or more?
Ask to see "service records".
Or, be prepared to negotiate a much cheaper price, in the absence of good information.
Old 10-02-2011, 06:09 PM   #13
1973 31' Sovereign
As it turns out the furnace and water heater connections were both issues for the inspector. The fridge, toilet will need replacing. The flooring has a limited life. We walked away from this sale. It just is too much of a project. So sad.
All this advice has been very educational tho! Thank you!
Old 10-02-2011, 07:24 PM   #14
kevin242's Avatar
1977 25' Tradewind
We walked away from this sale. It just is too much of a project. So sad. All this advice has been very educational tho! Thank you!
We looked at a few before we found the right one. If it's meant to be, you will likely find the right one for you if you are patient.
I've posted this before - Put "Airstream Wanted" ads on www.buysell.com , www.kijiji.ca , and anywhere else you can think of (bulletin boards, etc.) and see what comes to you! Sometimes people thinking of selling don't like the hassle of advertising and might just call you directly... and then you are not competing with others for the same trailer.
Old 10-03-2011, 04:15 PM   #15
1973 25' Tradewind
1962 22' Safari
Augusta , Georgia
To follow up on Kevin's thought, I use jaded mash. While it was far better before they got in squabble with craigslist. It hits several online buyer/seller venues.
As with others - keep looking. I spent 12 months looking for what I wanted, factoring cost, distance, condition, etc.
Old 10-03-2011, 04:17 PM   #16
1973 25' Tradewind
1962 22' Safari
Augusta , Georgia
Sorry the web set is jaxed mash. Apple spell check corrected me.
Dennis
Old 10-04-2011, 09:58 AM   #17
1972 25' Tradewind
Was this the trailer out in White Rock? The price was high if it had the problems that you mentioned. But don't let the appliances, etc. deter you as they can all be replaced fairly easily. You just want to adjust the price to allow for their replacement.
North Vancouver, BC
Old 10-05-2011, 08:08 AM   #18
1973 31' Sovereign
Yes! It is the one from White Rock! Really nice folks. He put some effort into it, so I imagine he wants a little return on his investment. Did you go out to look at it?
Old 10-05-2011, 07:44 PM   #19
1972 25' Tradewind
No, I saw it on Craigslist. Despite having one, I'm always looking to see what comes up for sale. There's a 20 foot Argosy that just came up a few days ago. That one might be worth looking at.
North Vancouver, BC
Old 10-05-2011, 08:57 PM   #20
kevin242's Avatar
1977 25' Tradewind
1978 23' Airsteam land yacht - Alberta Travel Trailers, Campers For Sale - Kijiji Alberta Canada.
One province over...
Brake Shoes - Where to buy? ckbailey97 Brakes & Brake Controllers 23 09-21-2011 01:43 PM
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 07:31 PM
1965 Airstream Tradewind Vintage Camper No Reserve!!! eBay Watch Airstreams on eBay 0 04-23-2011 09:50 AM
Airstream Classic 1964 Tradewind 24' great condition eBay Watch Airstreams on eBay 0 04-04-2011 08:30 PM
