Old 08-18-2014, 03:12 PM   #1
Robfromnorth's Avatar
1973 25' Tradewind
Calgary , Alberta
It's alive! My '73 TW Restoration. A cautionary tale of the breaking of a man.
A few weeks ago I bought my first Airstream. Of course it's a 25' Tradewind with the double beds. It towed well and didn't smell like an abattoir so I grabbed it up. The fellow selling it was in a small town and had a sign in the window that I saw on the long weekend while coming back to Calgary.
Long story short I bought it after a test tow for a song and since I was the first person with cash in hand that the fellow saw it was mine. In fact I could have sold it to a guy who showed up a little later for his viewing for an extra $1500. But no, this is my project of undoing.
Here's a few shots of the buy.
Name:	ImageUploadedByAirstream Forums1408396153.710162.jpg
ID:	219313Click image for larger version
Name:	ImageUploadedByAirstream Forums1408396170.361496.jpg
ID:	219314Click image for larger version
Name:	ImageUploadedByAirstream Forums1408396214.363409.jpg
ID:	219315Click image for larger version
Name:	ImageUploadedByAirstream Forums1408396248.237560.jpg
ID:	219316Click image for larger version
Name:	ImageUploadedByAirstream Forums1408396279.617230.jpg
ID:	219317Click image for larger version
Name:	ImageUploadedByAirstream Forums1408396336.762096.jpg
Robfromnorth is offline   Reply With Quote
Old 08-18-2014, 03:24 PM   #2
1973 25' Tradewind
Calgary , Alberta
The following weekend I dived into the tear down.
Heres the rub, it's my first RV, ever... Let alone RV renovation.
It's not that bad, I do work in construction and have built approximately 250 homes in my times as a residential construction super. I haven't had to buy any tools and besides the cyclo I probably won't have to. I also work in an engineering firm now and have ready access to confidence boosting resources... But still.
And there is this great forum online where tons of folks have done the same thing and shared along the way so...
Name:	ImageUploadedByAirstream Forums1408396616.425372.jpg
ID:	219319Click image for larger version
Name:	ImageUploadedByAirstream Forums1408396638.529908.jpg
ID:	219320Click image for larger version
Name:	ImageUploadedByAirstream Forums1408396652.435346.jpg
ID:	219321Click image for larger version
Name:	ImageUploadedByAirstream Forums1408396665.250104.jpg
ID:	219322Click image for larger version
Name:	ImageUploadedByAirstream Forums1408396683.682528.jpg
These are about as ugly as I can get. It vacuumed up well but that's not as cool.
This week I am booked for my axle replacement and after that it's interior wall removal and a complete redo of electrical systems and plumbing/heating.
Check out this find in the furniture
Name:	ImageUploadedByAirstream Forums1408396892.123642.jpg
I'll grab some under and ugly photos later. If you want to see anything in particular let me know.
Old 08-18-2014, 03:27 PM   #3
1973 25' Tradewind
Calgary , Alberta
It's alive! My 73 TW Restoration. A cautionary tale of the breaking of a man.
Also. Quick question. I have these rivets popped above the wheel wells on both sides. What are they indicative of?Click image for larger version
Name:	ImageUploadedByAirstream Forums1408397206.717318.jpg
ID:	219325Click image for larger version
Name:	ImageUploadedByAirstream Forums1408397220.972308.jpg
Old 08-18-2014, 03:55 PM   #4
aquinob's Avatar
Portsmouth , Virginia
Interior didn't look too bad from the pix, though they may not show all the issues. It looked pretty original, that is usually a good thing. The rivets probably popped due to flexing of the panels as it rode down the road. Worn axles can do that when they dont properly cushion the rig from larger bumps and potholes.
So what are your intentions for this personal penance you have signed yourself up for? How does the floor look, especially in the back? Have you pulled the belly pan down to check the condition of the frame or will you be pulling up the floor and looking down? Either way getting all that old pink fiberglass out and preserving the frame is one of the first things that should get attention along with sealing up any leaks on the roof or around the windows.
Good luck, keep the pix coming, we like pix...
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 08-18-2014, 03:57 PM   #5
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
Congratulations on your purchase....and welcome to the Forum! It looks like a great unit, overall. Considering the broken interior wheel wells, the popped rivets may be due to a very rough ride. Also, puffiness around other rivets can be indicative of undue stress. I see your unit has been updated with newer wheels. What is the condition of the axels? What is the load rating on the tires? Pressure? Popped rivets can mean unbalanced or over-rated running gear.
arktos55343 is offline   Reply With Quote
Old 08-18-2014, 04:48 PM   #6
1973 25' Tradewind
Calgary , Alberta
I figured it was rough rides. The axles are riding low and actually have a negative angle on the torsion arms even with a lot of the weight out from the gutting. I spotted the bad axles right away and even priced out replacements as part of the plan. The tires are/were decent. They are D rated trailer tires but the side walls are all cracked out. I am replacing them as well as soon as I get it back from the axle shop.
What are those rivets attached to? I will see when I take out the interior skins, for now I assume it is the wheel well housing.
Old 08-18-2014, 08:45 PM   #7
1972 25' Tradewind
Hopkins , Minnesota
Those rivets probably secure the skin to the exterior wheel well
Old 08-18-2014, 10:10 PM   #8
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Yes post those gory belly pan pictures! we love pictures and any Airstream that looks worse than ours did makes them all the better!! Welcome and you are in for more fun if your memory is like mine and you did not take a bunch of reference pictures! Keep us posted please
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 08-20-2014, 11:57 AM   #9
1973 25' Tradewind
Calgary , Alberta
Belly pan status.
So it's in a few sections. I've noticed different materials and even different levels on the underside. For cleanliness and ease I will be getting a full set if banana wraps (from Vintage Trailer Supply unless there are other/better sources for a Canadian. I won't be making them. The compound and curve...
There is a ton of frame rust and I am pricing options to take it to a location and do the sanding myself for $120/hr or buying a small unit and doing it over a longer timeline. Really dependent on the ability to move the trailer with belly pan and floor mostly off.
New axles going on this week. I drop it off today and get it back on the 28th.
Name:	ImageUploadedByAirstream Forums1408557142.644519.jpg
Corrosion on the front where copper line (LP) met this replacement material
Name:	ImageUploadedByAirstream Forums1408557243.542124.jpg
Name:	ImageUploadedByAirstream Forums1408557283.150033.jpg
ID:	219434Click image for larger version
Name:	ImageUploadedByAirstream Forums1408557324.674693.jpg
ID:	219435Click image for larger version
Name:	ImageUploadedByAirstream Forums1408557351.817395.jpg
Flashing holdings sections up.
And a shot of the old axles.
Name:	ImageUploadedByAirstream Forums1408557394.988984.jpg
ID:	219437Click image for larger version
Name:	ImageUploadedByAirstream Forums1408557435.779791.jpg
Old 08-20-2014, 01:07 PM   #10
1981 31' Excella II
New Market , Alabama
Pull the belly skins and see what the frame looks like behind the wheels. Sometimes the frame can break causing the rear end to sag which makes the wheel wells bow out and that maybe what popped the rivets or if you are lucky they popped from vibration. My trailer had a lot of what I would call wheel balance issues. Areas around the wheel wells had popped interior rivets from all the vibration. A few pop rivets fixed most of the issues and adding a little more structure where Airstream skimped.
Perry
Old 08-20-2014, 01:57 PM   #11
1973 25' Tradewind
Calgary , Alberta
After the axle is on the whole of the subfloor and the belly pan will be replaced. The main "section" left on the belly pan is in good shape and can be re-used. It does droop and sag and need better mounting so I'll be doing that if it reusable but only a deeper look will tell.
The rest of the belly pan will be rebuilt in the sections they came off in with 4x8 sheeting. Here's where things may get controversial.
I use a lot of products in my business for building envelopes and I am sort of wary of Vulkem 921 for use as a sealer in my interior walls and especially the belly pan. It was a great option but there are way better ones these days that are proven in their environments.
I am planning on using a product called Blueseal as it has a better elasticity and temperature variance than Vulkem (ie I can move the trailer in -25C weather and not crack up my seals). As well it can stand up against chlorinated water (ie potable city water) in the event of a water line leak. After cleaning and blasting the frame I will also look at designing the belly pan with a drainage management system rather than a tight envelope to allow water to escape. Same with my vertical walls.
I fear saying so because folks like what they like and the reps of the supply companies even hang out here but I have the data sheets side by side and Vulkem is old tech. Proven in its time but not always the best. I have also looked at Sikaflex and it's a good looking product with few limitations just sourcing and quantity supply are tricky.
Old 08-20-2014, 03:55 PM   #12
aquinob's Avatar
The belly pan helps to keep moisture from the subfloor, the insulation and frame and to make the underside more aerodynamic. I don't think the belly pan needs to be sealed up, I'm of the opinion that any water that can get in there, needs a quick way to get out. So having some strategic holes in the middle that allow drainage are good to have. Removing the existing spun fiberglass insulation also helps with any future rust since it generally holds moisture up against the frame.
I replaced the fiberglass with some closed cell urethane foam boards secured to the subfloor with decking screws and fender washers. I reused part of the existing belly pan aluminum even though it was significantly corroded in parts, it was still intact enough to do its job. If I could have found a different material that would have served the purpose without being any heavier, I would considered that as well. Having aluminum in close contact with steel isn't great in my book, but it is what they have been doing for years.
Some folks have also provided for drainage in the bottom of the c channels as well. This is doable if you have all the interior skins off, on mine that only occurred in the rear bath.
So by all means keep thinking out of the box, there are lots of newer products that can work better than what was used when these trailers were new.
Old 08-20-2014, 08:46 PM   #13
1973 25' Tradewind
Calgary , Alberta
Thats a great looking setup. Thanks for the pictures.
Did you put any additional insulation beneath that? I plan on still using the trailer after it begins to freeze overnight and convection cooling from the bottom is a concern. I like that system a lot for its clean and dry approach though. That is probably worth a lot more in the long run? How cool is it where you camp? If it's a hot region light insulation down low is ok because of shaded area I imagine.
Anyway. Trailer is at the axle shop for a week. I have a weekend in my life that isn't all work on the trailer.
Old 08-21-2014, 07:01 AM   #14
aquinob's Avatar
No, that was it. Its the equivalent of R8. We live down in Virginia and don't plan on using the trailer in the winter. Cooling it is much more of a concern than heating. If I was up in Alberta I think I would worry more about heat loss through the shell than through the floor anyway. Aluminum transmits the heat or cold quite well and there is only an inch and a half of insulation possible in the walls anyway. I think in really cold climates I'd try and heat the hell out of it to keep up with the temp loss. You also need to make sure the waste tanks and the fresh water tanks are insulated and properly heated to keep them from freezing. I'd think about using some heat tape on anything that cant take a direct freeze with liquid in it.
Old 08-21-2014, 09:22 AM   #15
1973 25' Tradewind
Calgary , Alberta
The plumbing lines will be winterized through a dry out method. I can put a low pressure compressor on the line and blow them out rather than flow antifreeze through them. Dry pex is safe and secure even below -40.
Winter or below freezing camping simply won't use the plumbing system. It's too finicky to try and heat tape things when a single overnight power or LP failure can blow out your plumbing and force you to pull lines in the spring.
Old 08-21-2014, 12:15 PM   #16
1981 31' Excella II
Well there are low places like the toilet fill valve that are hard to get all the water out of. It can be done but it is not that critical for me since I live in the south.
Perry
Old 08-22-2014, 08:06 PM   #17
1973 25' Tradewind
Calgary , Alberta
The burdens of the north.
On the plus side I managed to buy a 20 gal. sandblaster on sale and will be ready for frame clean up when it gets out of the axle shop.
Old 12-29-2014, 10:57 AM   #18
1975 25' Tradewind
Biddeford , Maine
How's your restoration going? I had major piece of mine (that was apparently rusted through) drop on I95 yesterday, shredding some of the belly pan along the way. Looks like I'll be peeling more stuff back to check out the condition of the rest of the frame and figure out how I'm going to get this thing road-worth again.
tim781996 is offline   Reply With Quote
Old 12-29-2014, 03:04 PM   #19
1966 17' Caravel
Okay Tim where is your thread and are there pictures?
Cliff
Old 12-30-2014, 06:49 AM   #20
1975 25' Tradewind
Biddeford , Maine
I'll start a thread later once I start tearing into it. In the meantime, here are some before photos.
ID:	229458   Click image for larger version
ID:	229460   Click image for larger version
Cautionary Tale Protagonist Off Topic Forum 18 08-24-2014 12:26 PM
A Cautionary Tale TomW 1965 - 1969 Overlander 2 08-06-2014 09:58 AM
Cautionary News Article Regarding Generators and Carbon Monoxide Poisoning Phoenix Off Topic Forum 2 11-10-2012 12:26 AM
One man's trash is another man's treasure richie rich Generators & Solar Power 29 02-16-2010 06:07 AM
A tale of woe - how I saved a buck on tires and destroyed my sewer connection dmreilly10000 Tires 30 04-10-2006 12:22 PM
