Old 08-21-2014, 09:22 AM   #15
Robfromnorth's Avatar
1973 25' Tradewind
Calgary , Alberta
The plumbing lines will be winterized through a dry out method. I can put a low pressure compressor on the line and blow them out rather than flow antifreeze through them. Dry pex is safe and secure even below -40.
Winter or below freezing camping simply won't use the plumbing system. It's too finicky to try and heat tape things when a single overnight power or LP failure can blow out your plumbing and force you to pull lines in the spring.
Robfromnorth is offline   Reply With Quote
Old 08-21-2014, 12:15 PM   #16
1981 31' Excella II
New Market , Alabama
Well there are low places like the toilet fill valve that are hard to get all the water out of. It can be done but it is not that critical for me since I live in the south.
Perry
Old 08-22-2014, 08:06 PM   #17
1973 25' Tradewind
Calgary , Alberta
The burdens of the north.
On the plus side I managed to buy a 20 gal. sandblaster on sale and will be ready for frame clean up when it gets out of the axle shop.
Old 12-29-2014, 10:57 AM   #18
1975 25' Tradewind
Biddeford , Maine
How's your restoration going? I had major piece of mine (that was apparently rusted through) drop on I95 yesterday, shredding some of the belly pan along the way. Looks like I'll be peeling more stuff back to check out the condition of the rest of the frame and figure out how I'm going to get this thing road-worth again.
tim781996 is offline   Reply With Quote
Old 12-29-2014, 03:04 PM   #19
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Okay Tim where is your thread and are there pictures?
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 12-30-2014, 06:49 AM   #20
1975 25' Tradewind
Biddeford , Maine
I'll start a thread later once I start tearing into it. In the meantime, here are some before photos.
ID:	229458   Click image for larger version
ID:	229460   Click image for larger version
Old 06-09-2015, 12:30 PM   #21
ScoobyShack's Avatar
1976 25' Tradewind
Dallas , Texas
Well Rob, did it completely break you? We need updates!
David
ScoobyShack is offline   Reply With Quote
Old 07-23-2015, 03:21 PM   #22
1972 25' Tradewind
Calgary , Alberta
Hey I see your in Calgary, me too. I was wondering how yours is coming along?
Monza is offline   Reply With Quote
Old 07-24-2015, 05:56 AM   #23
aquinob's Avatar
Portsmouth , Virginia
David
It must have broke him, he hasn't posted since last August. So the score is:
TW: 1
Rob: 0
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 07-24-2015, 10:56 PM   #24
1973 25' Tradewind
Calgary , Alberta
Yee of little faith.
I am alive and the trailer is progressing. I need to organize some pictures and move them to be able to post but I have much details and progress.
I am down to a shell only and the interior aluminum walls have even been peeled out.
The axles are brand new as are the tires and I have even added a 4" lift by way of changing the torsion axle resting angle. BC Boondocking more possible now.
I am working the gutting beneath and arranging some substantial sub contracting to spray foam the underside and sheet with better aluminum for the belly pan and I am happy to have found a good interior aluminum fabricator that has experience and creativity with the interior walls.
Monza. Mine is stored well in the SE (just off the ring road) and I would be happy to show a fellow enthusiast the state of complete emptiness I am at. Have a beer and talk about where things are at.
So far the tally is
TW: 0
Rob: 0
Old 07-24-2015, 11:55 PM   #25
1972 25' Tradewind
Calgary , Alberta
Don't tell me your trailer is stored at the storage area on 104th in the SE??
I bought a 73 today from there and saw another Airstream stored there.
Regardless lets discus and pool resources.
Old 07-25-2015, 02:10 AM   #26
1976 25' Tradewind
Dallas , Texas
Congrats on your new '73, Monza. And Rob, I've gone years between posts, so I get how slow these projects can go. So glad you've posted an update, and that you're still hard at it!
David
Cautionary Tale Protagonist Off Topic Forum 18 08-24-2014 12:26 PM
A Cautionary Tale TomW 1965 - 1969 Overlander 2 08-06-2014 09:58 AM
Cautionary News Article Regarding Generators and Carbon Monoxide Poisoning Phoenix Off Topic Forum 2 11-10-2012 12:26 AM
One man's trash is another man's treasure richie rich Generators & Solar Power 29 02-16-2010 06:07 AM
A tale of woe - how I saved a buck on tires and destroyed my sewer connection dmreilly10000 Tires 30 04-10-2006 12:22 PM
