Old 08-08-2010, 06:34 PM   #1
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
I'm an Airstreamer. the '73 TW is home
Well, she's a 73 not a 72, kinda thought a 72 sounded cooler, but what are the differences anyway. She pulled home with no effort or trouble. Tommorrow begins the cleanup/inventory/what she needs day. I hope the pic loads. MPJ
moparjohn is offline   Reply With Quote
Old 08-08-2010, 06:36 PM   #2
moparjohn's Avatar
1973 25' Tradewind
lets try an interior shot
here is the kitchen
Old 08-08-2010, 06:37 PM   #3
Kevin245's Avatar
Glad to hear your trip was successful. The first picture looks good. Keep us posted on your findings.
Good luck,
Kevin
Eleanor Roosevelt
Old 08-08-2010, 06:38 PM   #4
moparjohn's Avatar
1973 25' Tradewind
ok another shot, the twin beds
here we go
Old 08-08-2010, 06:41 PM   #5
moparjohn's Avatar
1973 25' Tradewind
lets try a buch
here's four more
ID:	108359   Click image for larger version
ID:	108361   Click image for larger version
Old 08-08-2010, 06:45 PM   #6
moparjohn's Avatar
1973 25' Tradewind
last ones for today
some more shots
ID:	108364   Click image for larger version
ID:	108366   Click image for larger version
Old 08-08-2010, 06:56 PM   #7
x
XXXX , XXXX
Welcome
Welcome to the 73 club. Your model with the rear bath is often subject to rear end seperation because of the weight back there. Search in frames for this subject and read what has been done. The only way to know how bad things are is to drop the belly pan. My 73 excella 31' looks great on the outside. I just dropped the pan and found that the entire frame needs to be rebuilt. Both my main frame rails have rusted out. I now need to pull the shell off the frame and build a new one. It was not what I wanted to do when I started renos but can't leave it like this. Your A/S looks to be in great shape. You are very lucky to have original zip dee awning in good shape. I just spent $3000 for new zip dees all the way around (3 in total). Good luck with your new baby.
wasagachris is offline   Reply With Quote
Old 08-08-2010, 07:06 PM   #8
x
XXXX , XXXX
Floorplan
Hi John I have attached this floorplan for your trailer. Hope this helps you find everything.
Old 08-08-2010, 07:08 PM   #9
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
NICE...very clean trailer..doesnt look like its going to need much done to it!
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 08-08-2010, 07:16 PM   #10
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Thumbs up
It looks like it's in great shape! Congrats!
blmitch5 is offline   Reply With Quote
Old 08-08-2010, 08:12 PM   #11
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Nice looking unit. Looks ready to go.
As wasagachris mentioned take a look at the rear end for a gap between the bumper cover and shell. If you can, check if you can see the floor behind the bathroom storage compartment. If there is any wetness or funky wood back there address that problem first.
Good luck, enjoy your new TW. We do,
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 08-08-2010, 08:15 PM   #12
Splitrock's Avatar
Sioux Falls , South Dakota
Looks nice!
Old 08-08-2010, 09:05 PM   #13
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Saskatoon , Saskatchewan
Images: 30
Let the camping begin! She looks great. Congratulations!
Lisa
Lisa and Paul
2008 23' Int. CCD "The Atomic Pod" https://atomicpod.wordpress.com
2002 Chinook Destiny | 1973 13' Boler (fiberglass egg) "The Boiler"
WBCCI #23223 (=23 CCD)
bolerama is offline   Reply With Quote
Old 08-09-2010, 05:50 AM   #14
moparjohn's Avatar
1973 25' Tradewind
Thanks and...
Thanks for the kind words and welcome!. I had a chance to investigate more after she was home yesterday:
The Bad-
Small floor rot by entry door (6"x12")
more rot under new fridge
lil more rot under bath sin cabinet
2 tambour doors in bad shape
one front window has moisture trapped in between panes
one shylight/roof vent poorly sealed/patched (might have leaked)
dinner table has some rotted wood on the mount that attaches to
wall where hinge is
front pull out couch is loose from front wall, can not use with flip
over, looks like 2 srews hold it to front wall. will fix with better
mount to floor
Vista views have peeling uv coating
battery does not hold charge
little almn. "rot" just starting on rear over bumper 2 small specks
needs a door seal
AS Tax Deduction as Second Home boutdoors Dollars & Cents 36 05-16-2016 02:58 PM
1500 Mile Trip to get her home - Suggestions? Bambi_Bandit 1960 - 1964 Overlander 17 03-01-2015 05:17 PM
Airstreamer Greetings martian Member Introductions 9 05-16-2011 11:11 PM
