Old 08-09-2010, 05:58 AM   #15
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
and the good
The good
She is almost all original inside
New fridge/freez
found the original couch fabric on armrest (see pic)
hope to get something close to re-do couch in
no floor rot in front window area, or in front of toliet/shower
fiber optic side marker (driver side) works!!
full awnings, good sahe work good
body has fair shine, should wash up nice, till I get to polishing
all good glass, all windows work
no rips in screeens
oven clean, includes original broiler tray
all tambour door insert trays there, and in good shape
newer fresh water tank
new tires
stereo works
has a vintage CB, probably will remove
no oders/ bad stains, will clean up nice
moparjohn is offline   Reply With Quote
Old 08-09-2010, 06:31 AM   #16
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
rear-end separation isn't a big problem in this model; its usually the much longer trailers (the looooong rear overhang from the axles). Then, later in the 70's, they added grey tanks (more weight) which exacerbates the issue. But you can still have floor rot along the back edge; its not what's in front of the toilet thats the likely problem--its what's behind it, and its really hard to see from inside the trailer.
The other areas of rot might be from leaking roof vents, or more likely, that old antenna. Check those thoroughly to find the source of your leaks. The non-aluminum base of the antenna corrodes, being in contact w/ the aluminum skin. The o-rings on the crank shaft deteriorate, too, and water comes pouring in right down the shaft. mine was too far gone to fix, so I just removed it and patched the hole.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 08-09-2010, 11:20 AM   #17
x
XXXX , XXXX
John Welcome to owning a 70's airstream. They seem to be an aluminum can of worms. The more you open the more problems you find. Most is easily repairable but takes some time.
The Bad-
Small floor rot by entry door (6"x12")- You can try 2 part epoxy to fix google Rot Doctor to find info
more rot under new fridge Ditto
lil more rot under bath sin cabinet Ditto
2 tambour doors in bad shape Depending on problem they can be repaired or replace material
one front window has moisture trapped in between panes Replacements available repairs are very tricky and gaskets not available
one shylight/roof vent poorly sealed/patched (might have leaked)Parts available also reseal vent pipes on roof
dinner table has some rotted wood on the mount that attaches to
wall where hinge is Rot Doctor or replace wood
front pull out couch is loose from front wall, can not use with flip
over, looks like 2 srews hold it to front wall. will fix with better
mount to floor I used hollow wall anchors (butterfly type) to secure mine to wall
Vista views have peeling uv coating Repairable most people remove inner plexiglass pane I repaired mine and reinstalled inner pane
battery does not hold charge Check water level and fill fill distilled water and try again to recharge
little almn. "rot" just starting on rear over bumper 2 small specks If you mean aluminum rot on rear wall there will be more under lower beltline there is a steel holddown plate inside the rear wall and steel and aluminum mixed with water leaks cause major corrosion
needs a door seal Parts available
A lot of the parts you will need are avilable from Inland Rv in California or from Out Of Doors Mart on the East Coast. Vintage Trailer Supply is aslo good for parts.
I suspect that you have alot more floor rot than you think and if the floor is that bad the frame, crossmembers and outriggers will be rotten too. You won't know until you drop the belly pan and banana wrap. Don't ask me how I know.
wasagachris is offline   Reply With Quote
Old 08-09-2010, 12:00 PM   #18
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Job one is find all the leaks and stop them. Check all the vent stacks for leaks, my TW had rotten floor under all 3. No need in doing a lot of work til you get the leaks stopped. There is a wealth of info you can search here on the forums about sealants, etc.
Inland RV or Vintage Trailer supply have replacement door and window gaskets. The areas of rot you found are "classic" so don't feel bad. Check your axles before any long trips.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-11-2010, 07:10 PM   #19
moparjohn's Avatar
1973 25' Tradewind
Well, I've had her 5 days, It took me two days to properly clean the outside, washing and scrubbing the dirt, mildew off with a brush, she came out really nice. The only leaks I found (so far) is the door side Vista view, and the door itself. I started today on the interior walls/ceiling, with spray nine to see how it would clean up. It looks like all the walls will be a brighter white when done, only the curved bathroon ceiling did not "clean up". I am running the A/C when I'm in the trailer, it's hooked up to an outlet in the garage, and it blows the circut breaker every now and then, also the fan/light combo goes on-off-back on too! (not at te same time/ or in unison) any tips? MPJ
Old 08-11-2010, 07:12 PM   #20
moparjohn's Avatar
1973 25' Tradewind
Another thought in my head is, to do it right, how much of the trailers insides come out to put in new carpet? MPJ
Old 08-11-2010, 07:27 PM   #21
x
XXXX , XXXX
Carpet removal
Hi John on my 73 Excella I was able to remove all the carpet without removing any furniture. The carpet is held down to the floor with tack strips just like a house would be done. There were a few staples as well but not too many. Glad to hear the outside came up nice and that the interior walls are coming clean. If your bathroom is like mine the walls are a different colour and pattern. I just painted all my walls with Krylon paint for plastics. They look great now like brand new.
Old 08-13-2010, 11:02 PM   #22
RichHog's Avatar
1972 23' Safari
Houston , Texas
Most of the switches on the overhead lights are easy to replace. Out of doors mart. After a good cleaning you'll feel like she's yours. I thought my 72 was in great shape when I bought her. Then I replaced the fridge, then toilet, then Formica, then gaucho fabric and cushion, then drapes and roller shades, then partition folding door, then put all new wood onerous the plastic etc etc.
Boy are you going to have fun. Then you'll really feel like she's yours.
Oh yes I left out the axels and shocks.
RichHog is offline   Reply With Quote
AS Tax Deduction as Second Home boutdoors Dollars & Cents 36 05-16-2016 02:58 PM
1500 Mile Trip to get her home - Suggestions? Bambi_Bandit 1960 - 1964 Overlander 17 03-01-2015 05:17 PM
Airstreamer Greetings martian Member Introductions 9 05-16-2011 11:11 PM
