Old 08-21-2011, 06:10 PM   #1
Flynavy's Avatar
1974 25' Tradewind
2008 25' Safari FB SE
Col. Station , Ohio
How far should I go with this.
Now that I've got the interior of the 74 taken apart I'm wondering if I should go ahead and replace all the ABS pipe and fittings. It's not like I don't have plenty of other things to do, or that I see anything wrong with what is in there now. Some people have told me they have had trouble with old ABS glue fittings leaking in their house plumbing. I already plan on changing out the copper to Pex.
In general have any of you folks had problems with 30 or 40 year old ABS?
Flynavy is offline   Reply With Quote
Old 08-21-2011, 06:42 PM   #2
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I haven't heard of people having trouble with those, and mine are still fine. But if you're doing everything else and it makes you feel better to know everything is new, at least you have good access right now.
Stephanie
Old 08-21-2011, 06:42 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
No problem with the ABS drain and vent pipes, though plenty of problems with the copper stuff. You're replacing that anyway.
Old 08-21-2011, 08:53 PM   #4
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
how far
if I cut a corner, and don't do something because of time and/or money, I always end up regretting it. just sayin' ol' bill
wmarsha is offline   Reply With Quote
Old 08-22-2011, 06:34 PM   #5
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
I have a couple of days to ponder on this. There is no sign of leaks anywhere. Only thing is,the more I look around I've come to the conclusion who ever glued it up to begin with was more than a little cockeyed. Either that or they were in a hurry.
