Old 08-09-2011, 03:16 AM   #1
Flynavy's Avatar
1974 25' Tradewind
2008 25' Safari FB SE
Col. Station , Ohio
Converting dump valves
Our 75 is a twin bed rear 3/4 bath model. I pulled the above floor black tank in order to replace a section of rotted floor. Since it's all apart I thougth it would be a good time to repair the Thetford dump valves being as neither of them close.
When I couldn't get them apart I decided to just take them out completely and replace them. I had to cut the 3" ABS since the Thetford valve was glued at the black tank pipe end. The gray tank valve was the press on type so it came right out.
Being as it's all apart now I'm wondering if it would be best to just put in Valtera valves now and do it in a way where it could be serviced a lot easier next time around.
Has anyone done this? Any input would be helpful.
Thanks, Paul.
Flynavy is offline   Reply With Quote
Old 08-09-2011, 03:22 AM   #2
Ottawa , ON
Have a look at the results of this search. One of them is directly on your question.
Good luck with your mission!
Old 08-09-2011, 04:51 AM   #3
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Don't know what is best, but the Thetford valve is rebuildable. A kit is available from Out OF Doors Mart. The valve itself seperates via 6 or so screws so you can replace the gaskets & the blade. I bought an entire new valve, used the parts I needed since I did not remove the entire valve to work on it.
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 08-09-2011, 05:51 AM   #4
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
Thanks for the help. Looks like Valtera is more common, Thetford a little better made. Main thing I need to work out is a setup where I'm not forced into cutting pipe or pulling tanks to get the old ones out. Maybe a frunco here or there would do the trick.
Old 08-09-2011, 06:08 AM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
The Valterra valves are available anywhere and reasonably priced. The Thetford is pricy and uses adapters that are pretty well non standard these days. Both should be rebuildable.
I would change to Valterra
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 08-09-2011, 09:52 AM   #6
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
I just redid my entire dump system, including conversion to Valterra. I, like you was looking for a way to disassemble easily at a later date without cutting black pipe and re-buying the whole mess. I figured it out, and will shoot some pics and send them to you later today via this thread.
Phrunes is offline   Reply With Quote
Old 08-09-2011, 12:16 PM   #7
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
Thanks Phrumes.
I spent an hour and a half at the local RV store today and all I acomplished was get a headache. We went through the catalog and looked at all the fittings on the shelf, and while I think it can be done, we couldn't figure out how to keep the pipe inside the bumper compartment.
Looking forward to seeing how you did it.
Old 08-09-2011, 05:48 PM   #8
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Ok FlyNavy,
I'll try to make sense of these for you. Here is where I deviated from the norm:
On the hose end it goes thru the bumper on the street side of the trailer...I added a screw type fitting in the three inch pipe. That way, I could seperate from the complex bend assembly shown.
I added industrial slip compression fittings just before each valterra flange at the rear. That way, if a valve failed, I just have to replace a $2 valterra flange fitting and a short piece of pipe or just the defective valve, or just the forward flange and small piece of abs at the holding tank...Lot's of fleibility here. If you glue it all together and one valve were to go bad, you'd have to rebuild the entire assembly from scratch. Which sux, I know because I built this thing three times with glue before I finally settled on the compression fittings! Home depot loved me.
My system is as follows:
3" PVC and Valterra on black tank
2" PVC and Valterra on gray tank
Both collect into a 2" into 3" x 3" cleanout fitting and exit the bumper with 3" hose fitting.
Hope these help, don't hesitate to ask more questions if you have some.
ID:	137173   Click image for larger version
ID:	137175   Click image for larger version
Old 08-10-2011, 07:20 AM   #9
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
Although my layout is different that is what I am trying to accomplish. I need to get a 3x2 Y fitting and see if I can't work that out. Biggest prob. I've got is I do not have anyplace to put the slip fittings. My black valve goes straight into an ell, and the gray valve goes straight into the Y. There may not be enough room to add slip fitting.
Thanks for putting up the pics.
Old 08-10-2011, 09:12 AM   #10
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Try the plumbing supply houses, those fittings are aviable in flexable neoprene with clamp connections
jkcru is offline   Reply With Quote
Old 08-11-2011, 03:22 PM   #11
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
Sucess!!!! (at least I think so).
It looks to me like this is gonna work, using Valtera valves. I needed to find room so I could use slip couplings for future maintenance. AS had two 3" ells back to back coming straight out of the black tank. I'm going to do the same except I'll use two street ells with the slip ends faceing each other conected by a slip connecter.
AS used a 3x3 Y to pick up the gray tank which has a 2" drain. I'm going with a 3x2 Y with a 2" street 45 to pick up the gray. That leaves me enough room to use a 2" slip connecter behind the dump valve.
At least it looks good laid out on the shop floor. I have to replace some floor before I start putting it back together, but I think it is gonna work. I'll put up some pics when it's done.
Old 08-11-2011, 09:14 PM   #12
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Woohoo!....Don't glue it till it's in though!
Here's my old one...new one is same layout with valterras, slip joints and I changed gray to 2" all the way.
Black Tank Dump Valve Repair Cost bbherb Waste Systems, Tanks & Totes 12 06-23-2011 02:54 PM
Dump side question Tradermack Waste Systems, Tanks & Totes 7 05-19-2011 04:09 AM
Convert or Replace Thetford Waste Valves Emh142 Waste Systems, Tanks & Totes 2 05-15-2011 07:05 PM
2008 Airstream Interstate Black Water Dump Valve Installed touching exhaust pipe!! solar-guy Sprinter and B-van Forum 0 05-09-2011 10:54 AM
Dump valve-gate attachment to handle rod? walstibsf Waste Systems, Tanks & Totes 4 02-13-2011 06:44 PM
