Old 08-21-2011, 09:47 PM   #1
Flynavy's Avatar
1974 25' Tradewind
2008 25' Safari FB SE
Col. Station , Ohio
City water entry
I have the old factory city water setup. Hose connector is mounted just forward of the waste outlet. Water pipe goes up into an elbow, check valve, then the regulator, then what I guess is a relief valve which dumps overboard.
Being as I'm changing over to Pex, I'm looking for a way to streamline this setup. I've seen the connectors that have the regulator and check valve internal but they all seem to require cutting a hole into the sidewall, which I would like to avoid if I can.
Has any one changed theirs to a simpler setup?
Flynavy is offline   Reply With Quote
Old 08-21-2011, 09:49 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
What is complicated about what you have? I have that on our 1979 Safari and would like something similar on the Liner, rather that cutting another hole in the side.
Bill
Just my personal opinion
Old 08-22-2011, 09:07 AM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
City water entry
I agree with Bill. Prior to learning the nuances of Airstreams, I allowed myself to get talked into having one of the modern multi-function through-the-wall water supplies installed on my Overlander to replace the original setup. After fifteen years, it is one of the changes that I most regret permitting on my Overlander . . . the part certainly wasn't designed to last more than ten years, and it is almost impossible to get a leak-free connection with the water hose . . . something that was never a problem with the original setup.
My Minuet still has its factory original setup, and it is going to remain that way. The connection point is unobtrusive, but easy enough to access, and I have yet to have significant trouble getting a leak-proof connection with the hose.
Good luck with your re-plumbing!
Kevin
Kevin D. Allen
AIR #827
Old 08-22-2011, 05:56 PM   #4
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
Thanks for the help. I will stay with the factory setup. I think I can reuse everything except the regulator. That looks like it may have cracked at one time and someone did a JB Weld job on it. After I get past the relief valve it will be Pex except maybe for the stops. I'm thinking brass for that.
Old 08-22-2011, 06:03 PM   #5
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
City water entry
Greetings Flynavy!
The adjustable brass regulators are comparatively easy to find. I found mine at Lowes when I needed a replacement for my spare parts bin on the Minuet.
Good luck with your re-plumb project!
Kevin
Kevin D. Allen
AIR #827
City Water Connection gaylejoe Fresh Water Systems 10 04-13-2015 12:59 PM
Proper City Water Fill, 30A inlet, etc. Placement? worldinchaos General Repair Forum 5 08-16-2011 02:39 PM
Water coming out city water inlet mutcth Fresh Water Systems 5 05-27-2011 09:23 AM
Water Heater Calcium Deposits -- What to do? roscher Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
Locating new city water inlet Globie64 Fresh Water Systems 12 03-10-2011 08:55 PM
