Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Tradewind > 1970-79 Tradewind
Old 08-11-2002, 09:35 PM   #1
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Blower in bathroom?
I discovered a toggle switch right next to a little nose shaped cover in the rear bathroom of my 71 TradeWind. It is located right next to the toilet in the lower rear plastic cover panel. What is it? A vent? Vacuum? Where does it go?I can't seem to find an exhaust vent for it? I can hear a blower come on when I flick the switch.
Uwe
www.area63productions.com
Old 08-12-2002, 05:17 AM   #2
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
More than likley it is your bathroom vent fan. It was not untill later in the 70's hat they started putting them in the roof. I find it very convienent being able to turn on he vent fan while having a set. I have no "exaust port" on the exterior either. I think it vents into the belly of the coach somewhere, but I cannot tell for sure where.
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
Old 08-12-2002, 10:51 AM   #3
Moderator Emeritus
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Fart Fan
Blower in mine is located in vanity next to toilet and output is directly down to the bellypan.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 08-12-2002, 11:36 AM   #4
uwe
418
uwe's Avatar
Images: 41
Pest Control
This explains why there are no mice or spiders in my bellypan........
Uwe
Old 08-14-2002, 04:11 PM   #5
71tradewind's Avatar
Profile:
UWE Ialso have the same setup the blower you hear is in the closet in the bathroom and vents thru the belly pan on the curb side all the way to the rear of your coach . Its a real nice feature except it vents right where you do your intertaining Tom
71tradewind is offline   Reply With Quote
Old 01-03-2008, 04:21 PM   #6
Profile:  1976 31' Sovereign
St Petersburg , Florida
Mine blowes right into the cabinet. Is it supposed to???
I'm replacing water heater and part of the cabinet. I was simply not going to reinstall the blower...unless I can be convinced that its functional.
DreamWeaver is offline   Reply With Quote
Old 01-03-2008, 06:05 PM   #7
Profile:  1972 25' Tradewind
Madison , Wisconsin
If you have everything out of the way you can always change the oulet location. I am considering changing mine when I put the new waste tank in next spring. I am thinking all of the heavy black vent hose may have to be replaced with something a bit more modern. There is about three feet of excess vent hose in mine. The blower is a bit noisey, so a new motor may be considered but I will either leave it be or modernize it. Just ripping it out and not replacing it may be something you wished you had not done later when things need venting
I don't think the vent is supposed to vent into the cabinet??????? Mine is a belly pan type discharge (at least for the moment.
Smokin Camel is offline   Reply With Quote
Old 01-03-2008, 06:28 PM   #8
I don't see any way it could have been vented to the belly pan. I'm sure the floor is original, however, the original owner left paperwork that indicated the factory waterheater was recalled. Perhaps during the recall, the vent pipe to the fan was not re-installed and a partial floor replacement was done???
Old 01-03-2008, 06:56 PM   #9
Commercial Vendor
Profile:  Corona , California
The bath exhaust fan that's in the cabinet that hides the water heater, was always noisy.
It's supposed to be hooked up with a flexible hose, to a fitting in the flloor and then thru the underbelly. That's how Airstream original made that installation.
Since the cubic interior feet of even a 31 foot trailer is small, it was felt that it would be very nice to exhaust those unfavorible odors, to the exterior, instead of letting them slowly dissipate within the interior.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 01-03-2008, 07:06 PM   #10
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Check out this thread that deals with this very question. There are photos at approx post #8 thru 10.
Dave
http://www.airforums.com/forums/f455...ari-33495.html
Fyrzowt is offline   Reply With Quote
Old 01-03-2008, 07:08 PM   #11
Since mine had no vent hose, I thought it was there to mask unfavorable bathroom noises.
Would a flexible hose to a fitting on the black vent pipe work to exhaust some of those unfavorable odors or should I cut a hole in the floor to the underbelly?
Steve
Old 01-03-2008, 07:13 PM   #12
Dave
Thanks, I didn't get that thread on my advanced search for "bathroom exhaust fan".
Old 01-03-2008, 08:59 PM   #13
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
Here's a pic of one in a 71. It was originally a black fiber tubing just shoved down in a rough cutout in the floor. The vent tubing was replaced when the water heater was changed out.
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 01-03-2008, 09:11 PM   #14
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Here is a picture of ours, it is pretty much as-built:
Name:	bathroom vent 001.JPG
(No Longer at Inland RV)
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 09:01 AM
Bathroom woes. Part II Theo Sinks, Showers & Toilets 30 02-24-2004 11:13 AM
advice wanted for bathroom sink replacement Shelby Copeland Sinks, Showers & Toilets 8 12-25-2003 08:06 AM
Pergo in the bathroom Chuck Floor Finishes 8 08-05-2003 06:13 PM
Wanting to replace the WHOLE bathroom... larrylisa Sinks, Showers & Toilets 16 12-06-2002 01:08 AM
