Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Tradewind > 1970-79 Tradewind
Old 07-15-2002, 10:17 AM   #1
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Battery Location
I have a few concerns about the battery in our 1971 Tradewind:
There is a Battery door which goes to under the rear bed area, and above it there is a small vent with a vent hose attached to it. That's it. No Battery box or containment or hold down of any kind.
I would like to know what all is missing, or if anyone has modified this setup to hold 2 Batteries.
I have looked at marine type battery boxes, but they are not sealed, just basically a battery container with a lid. What about fumes and /or acid etc.??
I was thinking of perhaps relocating the batteries to the area behind the propane bottles, for safety and convenience.
I am open to suggestions and any information is appreciated.
Uwe
Old 07-16-2002, 03:27 PM   #2
71tradewind's Avatar
Profile:
Hi ! there is infact a hold down for the battery mine was a metal plate that was screwed to the floor then a clamp that went around the battery. I removed mine and put a more up to date marine type battery box made of plastic. You can find them at sears,wallmart,ect. These boxes will contain the battery in case of a spill. If you have any more questions , i will be happy to answer them to the best of my ability. Tom
71tradewind is offline   Reply With Quote
Old 07-16-2002, 03:37 PM   #3
Profile:
Oh almost forgot as far as fumes go , you could seal the vents the drill a hole and insert the tube in it. I also had the same concerns but then thought of how many airstreams have been made this way with only a tube placed near the top of the battery ,and have never heard of it being a problem . I dont think i would relocate the battery to the front for 2 reasons the 1st being the most important, the long run of wire from the univolt will more than likely have a large voltage drop at that distance requiring you to run rather large cables Ie 4 quage or larger. 2nd the extra wieght on the tounge esp 2 batteries remmeber how far back your axles are plus the already heavy tounge weight of a tradewind. Hope this helps ! Tom
Old 07-16-2002, 04:10 PM   #4
uwe
418
uwe's Avatar
Images: 41
batteries
Thanks again, Tom. This does help. i am new to this, for the most part.
I will search for decent battery boxes and then make an aluminum rail that holds them down with long allthread, or the like of it. I guess i could make a connection manifold between the 2 battery boxes and connect it to the outside vent, just in case. It's easy to do and can't hurt, right?
So Airstream did not really have a slider or other mechanism for the battery behind the door, i guess? Just a plate and holddown.......interesting.
I agree on the tongue weight - not a good idea to add 2 heavy batteries to it.
Uwe
Old 07-16-2002, 05:08 PM   #5
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Check Summitt Racing as a source on the web for various types of battery boxes.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-16-2002, 05:32 PM   #6
Profile:
Batteries and placement
Oh boy, I gotta disagree....
Batteries out gas with hi activity.
battery vapor or gas rises
batteries enclosed need not be pressure sealed
marine batteries are very carefully placed and use a plastic battery box
Airstream trailers rarely use greater than 30 amps to do any task, so a 10 gage stranded wire will work great for any battery placement.
Batteries on the front of a trailer get more service as out of sight ..out of mind is common...
The new trend for battery placement is on the trailer tongue
I'll add more later.......
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 07-17-2002, 04:53 AM   #7
Profile:
Frank the things you point out are true except you must take into account for voltage drop as well ,plus if the unit has the original univolt it may not be as effecient as it once was,so the battery may not get the necessary charge to maintain a proper charge,then comes the problem of running on to low of voltage! currant increases as voltage drops .Plus adding any wiring to an A/S is no small task esp. to do right ie. "safe".The current battery location is directly behind the axles which from a load stand point makes it near ideal"over the axles" is best plus the fact that the tradewind axles are set towards the back of the unit ,adding any weight up front multiplies it quit a bit, it is true that the trend is moving them forward but the axles are also towards the center of the units , NOT set back nearly as far as our 71 tradewinds are. As far as gasses go yes it is safer to vent them ! but it does not seem to be a problem as they were oringinaly was more or less just vented to atmosphere with a small piece of tubing laying near or acroos the top of the battery. My post are not done with out thought put into them and i do not want to overwhelm people with too much info ,In jest all i was saying is its better to leave them where they are put them in a better box and if you like vent them better.With all do respect please dont make this and i know more than you do thing, every one has valuble info including you !
Old 07-17-2002, 05:37 AM   #8
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 13
Battery wiring
I have to agree with FrankR on the wiring question.
#10 should be plenty for current from the battery unless you have unusually heavy requirements. There is ordinarily nothing in any coach that would be sensitive to the very minor voltage drop caused by 30 or so amps through #10.
When on shore power, charging current from the UniVolt to the battery is only a few amps, therefore, the voltage drop will be even more negligable.
I just looked at the wiring diagram for my International and the battery feed to the panel is 159" of #12 wire. Both hot and ground are #12. The only #8 in the entire trailer is a chassis ground that runs from the tongue area to the center of the back of the trailer and connects to nothing else.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
Old 07-17-2002, 07:10 AM   #9
Profile:
I agree John But were talking about moving the batteries apporx. 20 feet of wire or more away from the univolt, wire lenght exceeds actual distance because of turns , having to go around things ect. My unit has 7 light fixtures 4 bulbs each ,water pump, furnace, range fan,bathroom fan, 2 reading lamps,docking light,tounge jack,poarch lamp,radio,way more than 30 amps worth if all added up.All these add up if they were turn on at once. You cannot safely wire for "normal use" whats normal for you,Frank, and I may not be normal for others. You have to wire for worst case senerio. The current location of the battery has a 2 foot run of appox 10 gauge .Without moving the univolt also ,I feel its safer to run heaver than lighter wire at that distance . But why move the battery at all is what it still comes down to.Its in a real nice area to begin with ,there is NO advantage to moving it. Tom
Old 07-17-2002, 07:42 AM   #10
Profile:
Battery wiring location.
Again I must disagree with Tom. My background was mostly as a electrical contractor for 30 + years. I'm very familar with wiring and loads. Line loss does not play any part in relocation of a battery in an Airstream. Any loads are protected by the seperate fuses . Even the battery is fuse protected. It must be your opinion that Airstream and other trailers have a big design flaw by relocation of batteries. You can believe me, when I say my wiring is not the norm. I've made many many changes. It is my belief that Airstream made too many decisions based on a few dollars...... Your arguements are not based on any scientific information only opinions. It is MY OPINION, that the grounds should NOT be fused. I have never witnessed another piece of equiptment where the ground is fused. Others may be different, but the 1979 Airstreams are wired this way. Is there any example or information that I can provide to make you better understand??
Old 07-17-2002, 07:55 AM   #11
Pahaska's Avatar
Images: 13
Wire sizes
I have almost precisely the same items in my International. You don't have to size the wires for 100% of the load ... it never happens. Maximum draw with absolutely everything on at once in my International would be 88.28 Amps. Airstream applies a formula as follows (from the manual):
1st 20 amps - 100% = 20 amps
2nd 20 amps @ 50% = 10 amps
rest of amps at 25% = 12.07 amp
____________________________
Grand total amps = 42.07
Converter is rated at 45 amps.
Actually, based on wire cross section, 21' of #10 is equal to the 13' of #12 that AS put in my trailer.
John W. Irwin
Old 07-17-2002, 09:58 AM   #12
uwe
418
uwe's Avatar
Images: 41
Gel Cells
I find all your replies very interesting. And i thank you all for your involvement. The electrical understandign that I have tells me that you all got very good points in this issue.
I decided not to relocate my battery, because I do want to keep using my trailer this summer, and if I started wiring, then I would be removing 1/2 of the trailer's interior and bellypan from the current battery location on forward.......I like doing things safe and sound.
So, instead I am shopping for Gel Cells. My friend has a garage, he can buy them at wholesale and give me a good price, basically wholesale cost plus tax and a six pack of suds. I am told that the Gel Cells do not fume out, and are impervious to mounting locations etc. Now we got to figure out which ones. I believe I saw a thread already in here. The batteries in question come from Interstate, which i had good luck with in my cars all these years. They have yellow, blue and red tops, i believe.
I will stil put them in battery cases, just to keep things neat. I actually look forwad to cleaning up the rats nest of wiring near my Univolt.( Original)
I am still not sure if the Univolt can charge 2 batteries in parallel.
Uwe
Old 07-17-2002, 04:41 PM   #13
Profile:
This is exactly why I dont post more offen ! Sorry UWE .
Old 07-17-2002, 06:42 PM   #14
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
2 matched batteries wired in parallel should be no problem for the univolt but you may want to carefully look at the charging requirements on the gel cells you are installing. If my memory serves, (I have a bad case of CRS, Can't Remember S**t) gel cells require a higher boost charge to get them fully charged after a long discharge. I think that makes sense. Basically gel cells require a higher voltage to properly condition and charge them than a traditional wet cell. Anyway I would check out the manufacturers spec. on charging before spending dinero in the new batteries. On the other points, outgassing, mounting etc. you are correct. So inside un-vented is fine. Just my $.02 cents worth.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
battery location Dave&Heide Electrical - Systems, Generators, Batteries & Solar 4 09-15-2002 06:32 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
