ok. I checked all the fuses and the converter charge light is blinking rapidly like it should when it is charging. But still nothing. 3 hours on the generator. Nothing.
Probably time to start checking voltage. You should have 13.6 or more at the converter output. If you're on the road without a multimeter, you could just pick up a cheap one at walmart or equivalent for simple troubleshooting like this. If you have 12.6 or more at the battery then your problem is further down the line.
The NSA -- The only part of the government that listens.
Do you have AC where you should, ie is air conditioner working (if you have one?). New batteries should have had a pretty good charge on them. What converter do you have? My PD Converter was blinking when it had no AC supply due to a faulty outlet.
Oh they tested at less than 3. So it took a week to drain them out and I had that condenser button on the dometic fridge on...i read that's a big battery suckered also...
Sent from my SM-N900V using Airstream Forums mobile app
