Old 06-15-2014, 01:10 PM   #1
1975 25' Tradewind
dallas , Texas
Angry Battery Drain - Will Not charge
So i have the 2 golf cart Costco batteries, and i have them hooked up with the positive to negative.
I hooked the shore power up to a generator for a charge this morning. It has been 3 hours and no charge.
I have all LED lighting inside and nothing, no power whatsoever.
Help.
hippygypsy is offline   Reply With Quote
Old 06-15-2014, 01:42 PM   #2
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Check the breakers and fuses? There should be a fuse on the converter output also.
The NSA -- The only part of the government that listens.
newroswell is offline   Reply With Quote
Old 06-15-2014, 02:20 PM   #3
1975 25' Tradewind
dallas , Texas
ok. I checked all the fuses and the converter charge light is blinking rapidly like it should when it is charging. But still nothing. 3 hours on the generator. Nothing.
Old 06-15-2014, 02:46 PM   #4
richinny's Avatar
2011 34' Classic
how dead were the batteries? do you have a meter or test light to check the connections?
Ricky
Old 06-15-2014, 02:53 PM   #5
Chief Chili Cook
newroswell's Avatar
Probably time to start checking voltage. You should have 13.6 or more at the converter output. If you're on the road without a multimeter, you could just pick up a cheap one at walmart or equivalent for simple troubleshooting like this. If you have 12.6 or more at the battery then your problem is further down the line.
Old 06-15-2014, 04:00 PM   #6
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Do you have AC where you should, ie is air conditioner working (if you have one?). New batteries should have had a pretty good charge on them. What converter do you have? My PD Converter was blinking when it had no AC supply due to a faulty outlet.
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 06-16-2014, 02:29 PM   #7
1975 25' Tradewind
dallas , Texas
My converter is behind the stove. I am about to take a look at it. I know there is a simple problem for this.
I may have a short on one of the lights causing the drainage. I also have treetops which I am going to solder out.
Might as well. The batteries are at interstate getting recharged. They said about a week and gave me a loaner deep cycle.
Sent from my SM-N900V using Airstream Forums mobile app
Old 06-16-2014, 02:31 PM   #8
1975 25' Tradewind
dallas , Texas
Oh they tested at less than 3. So it took a week to drain them out and I had that condenser button on the dometic fridge on...i read that's a big battery suckered also...
Old 06-21-2014, 01:06 PM   #9
1975 25' Tradewind
dallas , Texas
So far so good. I think it was the little button under the Dometic fridge...but still want to check all those wires before i hit the road again.
Thanks for all the help.
Old 10-02-2014, 11:53 AM   #10
1975 25' Tradewind
dallas , Texas
Turns out the mechanic had unplugged the converter and battery was not recharging on shore power.
Charge wire on 7-pin, what demands does AS need and how does this charge starcraft Batteries, Univolts, Converters & Inverters 10 04-20-2012 08:38 AM
AC Drain & Battery Charge la4photo 1974 - 1979 Sovereign 4 05-10-2009 05:00 PM
Full Charge - No Charge! Cracker Batteries, Univolts, Converters & Inverters 2 06-22-2007 02:04 PM
How to wire truck to charge TT battery? femuse Electrical - Systems, Generators, Batteries & Solar 19 04-09-2003 10:23 AM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 05:49 AM
