05-30-2007, 06:20 AM
1975 31' Sovereign
Latham
, New York
Any quick fixes for copper pipe?
Hi,
Haven't got the service manual yet, and have a chance to go camping this weekend but the only thing holding us up is a leak at this joint in the copper pipe. Anybody know of anything that can get us thru the weekend til we can take our "new baby" in for her first check up? We are real new at this!!....although we did get the water pump to work...
We still can't get any water to go thru the lines at the city water connection....nothing! Does that pressure regulator need to be adjusted to allow water to go thru it?
Christine
05-30-2007, 06:37 AM
Retired.
, At Large
If the leak is in the joint, just heat up the joint with a torch. It will re-sweat the solder and hopefully stop the leak. If it's at a point just above hte joint, you can unsolder the pipe using the same method, cut off the leaking part, and resweat the remaining pipe. Don't forget to put some flux on the new pipe, along with some fresh solder..
1996 28' Excella
Okemos
, Michigan
A quick temporary fix is to wrap a piece of thick (1/8") rubber around the leak and squeeze it with a band clamp. That should get you thru the weekend.
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
05-30-2007, 06:46 AM
Retired.
, At Large
That's a good suggestion if the leak is in the pipe itself. We have had to use a similar method on board some of the ships I was on, involving a sleeve of metal and several bolts with large wing nuts to tighten them. Clamp the sleeve over the leak with the bolts. They were supposed to be temporary, but I have seen some that had very obviously been in place for years .
05-30-2007, 06:50 AM
1966 24' Tradewind
Placerville
Originally Posted by jask12rs
Hi,
Christine
Hmmm; The leak fix suggestions you received are what I would suggest. Also there is the putty like epoxy material they use for quick repairs for boats and fuel tanks. You can find that at auto suppy stores. As for the lack of city water flow you have something blocking it. It wouldn't take much to 'fiddle' with the water pressure valve but I doubt that is the cause. If you do.... get a water pressure valve to put onto the hose fitting. Your system will not take much pressure over 45 psi or you will have more leaks to repair especially with your old rig.
Neil and Lynn
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
05-30-2007, 06:58 AM
Retired.
, At Large
I have had an Argosy with athe same lack of city water problem, it turned out the regulator was clogged. I rapped on it with a wrench and got enough water pressure to use for the weekend. A wqay to check this is to fill your inboard water tank, turn on the water pump, and watch for flow. If you get good pressure using the onboard systems, but the city water doesn't work, and you can't get it to work, you will have to replace the regulator.
05-30-2007, 07:21 AM
1993 34' Excella
Estancia
, New Mexico
A piece of plastic or rubber tubing overlapping both ends held in place with double hose clamps on each end. A little dish soap will help it slide on.
As for soldering on new connections, if the copper line has frozen but not cracked it is likely the copper will have stretched and new fittings will no longer fit.
05-30-2007, 08:35 AM
just jd.
2007 20' Safari SE
San Diego
call a plumber?
Another option: call a local plumber if you're not keen on doing it yourself. - The plumber will Do It Right (they aren't happy to do their own rework)
- The plumber will Do It Quick (hey, you want a "quick" + "fix", right?)
Me? I love to be the one to really mess things up first, before calling in the professionals, so I'd get right in there and flame on!
On the other hand, this might just be leak #1...fix it and find another Hopefully that's not the case!
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
05-30-2007, 09:18 AM
1975 31' Sovereign
Latham
, New York
That'd be too easy..
Cheers,
-jd.
That would be just too smart and too easy!! We got to give it the ol' "try to fix it ourself" routine first...but not much "know how" here!!
Don't think I'd dare put a torch in there...too many wires around and don't really know what I'm doing....
Thanks for all the advice everybody...wish us luck on the shakedown cruise!!
Christine
08-04-2007, 11:54 PM
Battle Ground
The pressure regulator is already set for the correct pressure. Check the water screen where you hook up the hose. At an auto parts store you can find a quick fix for the water pipe. I had a leaking water pipe under the kitchen sink. I converted it to plastic. Got the parts at a plumbing store.
