Old 04-12-2011, 06:22 PM   #1
Baseman's Avatar
1974 25' Tradewind
Ponchatoula , Louisiana
'74 Tradewind project
Today's progress,
Removed most of the floor,
Supported on screw jacks to level it up in preparation for frame repair and reinforcing.
ID:	126822   Click image for larger version
Baseman is offline   Reply With Quote
Old 04-12-2011, 08:46 PM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Ahh, the joys of the tear down! Have fun
Lance
Top is offline   Reply With Quote
Old 04-17-2011, 09:46 AM   #3
Baseman's Avatar
1974 25' Tradewind
Trying to decide on the plywood for the floor. Leaning toward 23/32 pressure treated plywood as it wool not be as likely to be damaged by small leaks that may occur. Planning on covering it up with heavy linoleum. Is there any reasons not to use pressure treated plywood?
Old 04-17-2011, 10:11 AM   #4
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
And here we go...
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 04-17-2011, 10:23 AM   #5
x
XXXX , XXXX
Yes the chemicals in PT will react negatively with aluminium and cause severe corrosion.
wasagachris is offline   Reply With Quote
Old 04-17-2011, 11:02 AM   #6
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
If you treat the edges of the new floor, AC ply, with West Epoxy resin in about 6 inches on top and bottom you will protect the areas that always rot. On the wood for the bath area I did the epoxy around the edge and then put 3 coats of marine spar urethane on top and bottom. On the recommendation of another Airstream restorer, I used one piece of cork pattern vinyl to cover the whole floor (it was much less expensive than tiles or planks and I got complete coverage). I only glued it around the perimeter so the floor would "float". Then I used clear silicone sealant around the edge of the inner wall and the floor to prevent any water that may get in by some future mishap from getting to the wood. If you go the one piece route, make a pattern with rosin paper. Get it perfect and then trim the vinyl before you put it in the trailer.
Good luck.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 04-19-2011, 05:03 PM   #7
Baseman's Avatar
1974 25' Tradewind
Thanks for the advice!
Found a guy with a fire damaged truck camper that has a good Onan 2500 lp generator, good furnace, pump etc. It's all a 1998 model. Going to take a look at it and see if it's as good as it sounds. If so it will save me a lot of cash, but will be a little trouble to haul off the hulk when I am done scaveging it.
Will be off next week and plan on leveling up the frame and hopefully finishing the frame welding and starting on the floor install.
Old 04-19-2011, 05:12 PM   #8
DanielB's Avatar
Technically it isn't the chemicals in the PT wood, it is the metals, specifically the copper in the treatment. It sets up galvanic corrosion between the copper and the aluminum. Same reason that you don't really want to use stainless steel screws in aluminum.
- Andrew Carnegie
Old 04-19-2011, 05:43 PM   #9
Baseman's Avatar
1974 25' Tradewind
I woner if the newer treated plywood, Yellawood would have the same issue, it is a different treatment. It is yellow no greenish like the old style.
Old 04-19-2011, 05:53 PM   #10
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Baseman,
I highly recommend you use the highest quality AC exterior or AB MGP you can find and treat it with some sort of waterproofing like epoxy or six coats of spar varnish.
Lance
Old 04-19-2011, 06:01 PM   #11
Baseman's Avatar
1974 25' Tradewind
Yeah,
I just googled yellawood and it is also copper based. It says it's approved for direct aluminum contact, but the next paragraph is goblydy gabildy ask somebody else.
It seemed to easy, and is. I will try and find some marine grade plywood localy and seal it as you guys are recomending.
Thank you guys for helping me avoid another picklehead mistake!
Old 04-19-2011, 06:10 PM   #12
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
No problem. We live for this stuff. I mean, we ahh love this stuff! I had to have the local lumber yard order the MGP I used. I don't think it was the highest quality there is, but it was the best I could get in central Texas. I'm not too sure that the MGP that I got was any better than AC exterior. The price was only $15 per sheet different, so I went with the MGP.
Lance
Old 04-27-2011, 09:47 PM   #13
Baseman's Avatar
1974 25' Tradewind
Today's progress, straightened the back section of frame and reinforced. Boxing in the 5" C-channel with 1/8 flat bar and welding in 3" channel along the bottom from the axle plates to the back bumper.
ID:	128395   Click image for larger version
Old 05-22-2011, 06:35 AM   #14
Baseman's Avatar
1974 25' Tradewind
Progress so far:
I have boxed in the rear 12 feet of frame rails and re-installed the 3 cross members and made a new rear hold down crossmember from 3" channel.
Slow going, but progressing.
On the rear of the trailer, I have found that the rear lower skin and rear lower curbside skin has been replaced- installed with what I think are cleeco's that are not sealed on the inside of the skins. They look good from the outside (look like buck rivettes)
I am trying to decide between just sealing them up from the backside or possibly drilling them out and replacing with bucks.
Any advice or recomendations on this?
ID:	130401   Click image for larger version
'73 Tradewind Project constructor 1970-79 Tradewind 89 08-14-2014 05:53 AM
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 07:31 PM
1975 Tradewind project - questions! lots of them! keithmac 1970-79 Tradewind 4 03-05-2011 10:10 AM
VIN #L25D3 - S2526 Tradewind Seria # constructor 1970-79 Tradewind 6 01-16-2011 10:03 AM
