Old 05-22-2011, 06:48 AM   #15
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
They are most likely Olympic rivets. They are used when access to the inside for bucking is not possible. It is very common to see them used when a panel is replaced.
Richard
Old 05-22-2011, 10:48 AM   #16
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
"I am trying to decide between just sealing them up from the backside or possibly drilling them out and replacing with bucks."
Since you have access, I would drill them out and replace them with solid rivets.
Lance
Top is offline   Reply With Quote
Old 06-02-2011, 08:45 PM   #17
Baseman's Avatar
1974 25' Tradewind
Ponchatoula , Louisiana
Removed the fresh water tank today, this is the inside side of the plywood that was holding the fresh water tank. ???
Baseman is offline   Reply With Quote
Old 03-27-2016, 02:11 PM   #18
Topeka , Kansas
I used 3/4" marine grade plywood to repair the floor in my rear bath. Sealed the underside with Thompson's water-seal and coated the "C" channel with Flex-seal just prior to installing the wood. Next will seal the seam under the exterior trim.
Blues Bill is offline   Reply With Quote
'73 Tradewind Project constructor 1970-79 Tradewind 89 08-14-2014 05:53 AM
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 07:31 PM
1975 Tradewind project - questions! lots of them! keithmac 1970-79 Tradewind 4 03-05-2011 10:10 AM
VIN #L25D3 - S2526 Tradewind Seria # constructor 1970-79 Tradewind 6 01-16-2011 10:03 AM
