03-09-2011, 09:40 PM
1973 25' Tradewind
Burnsville
, North Carolina
'73 Tradewind Project
The project is well underway. Haily is getting a facelift. I want to start logging some of the work. Here are a few shots of what we started with. The photos don't show just how dirty the inside really was.
Ann - The Constructor's scribe.
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
03-09-2011, 11:55 PM
1975 23' Safari
1978 31' Excella 500
Franklin
, Indiana
Looks good! The interior looks almost all original (ex. curtains).
Good luck with your resto!
Dallas Peak, MD 'That 70's Guy!'
VAC Past President
WBCCI #8481
03-10-2011, 09:47 AM
Addicted
1971 27' Overlander
Currently In: Skowhegan
, ME
Is the tambour in your galley in good shape and functional still? That's the one area that we had to rip out and replace.
03-10-2011, 10:19 AM
1973 25' Tradewind
Burnsville
, North Carolina
Tambour and More Stinking Leaks
All but under the sink work well. We are going to try the cut in half method and let one side retract in and the other piece slide back and forth.
Dang DANG DANGGGGG. Just went and inspected Haily on my lunch break as we have had hours of hard rain. We have LEAKS that we thought we got. Poor constructor will have to do some more sealing. Front windows which he beautifully broke out one pane and removed the ugly tint mess and mold are leaking and back in the street side closet where the shell meets the frame.
03-10-2011, 11:17 AM
1973 25' Tradewind
Burnsville
, North Carolina
Punch List and Costs
At the risk of TMI....
03-10-2011, 05:47 PM
Addicted
1971 27' Overlander
, ME
Never too much TMI -- it's interesting to compare our costs on stuff against others. All of our vertical tambours were dead (galley and credenza) and had to be removed. Eventually, I just built regular doors on the front of the galley, but we wanted to keep everything as original as possible in ours (at least from an appearance standpoint). After squeezing two kids up front in our double/double, we removed the credenza and built in a seat that folds out to a twin bed. We still have the tambour everywhere else, and still in decent shape.
03-10-2011, 06:55 PM
1974 31' Excella 500
Charleston
, South Carolina
Tear it up! I'm ready to see some blood and guts.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
03-10-2011, 07:22 PM
1974 27' Overlander
Sault ste Marie
, Ontario
Our PO's were smokers, I think I brightened up our interior by about 50% just by scrubbing the walls and ceiling with a good industrial cleaner. Luck was also with us as all our tambour doors work. The only one that was a little sticky was the narrow one under the galley counter and that was fixed with a little candle wax. Hope you get your leaks sorted out, they seem to be a constant issue. Cheers............Phil.
03-10-2011, 07:37 PM
1975 23' Safari
Franklin
, Indiana
On the interior vinyl coated aluminum walls of these 70's units, there is a sticky substance which is continually exuded from them resulting in sticky walls. You'll find other's posts on here talking about it and how to mitigate it. But it's always there on these units. It does tend to attract dirt pretty badly. We accused our PO's (prior owners) of deep fat frying all the time when--but later learned the recurring vintage Airstream lesson of "They're all like that" applies....
VAC Past President
WBCCI #8481
03-10-2011, 07:42 PM
Addicted
1971 27' Overlander
, ME
We tried the floor wax treatment on the walls after they were cleaned, and it seems to have worked well for the past year.
03-10-2011, 07:56 PM
1973 25' Tradewind
Burnsville
, North Carolina
AH HA, So glad I started this. Vinyl floor wax I assume.
03-10-2011, 08:39 PM
1973 25' Tradewind
Burnsville
, North Carolina
I have searched and cannot find any info on the lower exterior trim on our 73 Tradewind being the source of leaks. Our trim is pretty beat up and not tight in many places. The PO installed the awning in a manner that has separated the trim from the shell.
03-10-2011, 08:42 PM
Addicted
1971 27' Overlander
, ME
Yeah -- first we ordered a little handheld bathroom scrubby cleaner off amazon (it's battery operated, used for cleaning your tubs and such). Sprayed the walls with orange oil (or whatever degreaser you're comfortable using), then wiped on Future Floor Wax. If you don't get it clean, then the wax will only work for a little while -- you have to get all of gunk off first.
03-10-2011, 09:09 PM
1973 25' Tradewind
Burnsville
, North Carolina
Trim Pics. The constructor is making his plan for sealant and riveting this back down. Advice is appreciated. The awning is going to be removed. Besides the poor install it is in bad shape.
03-10-2011, 09:24 PM
1973 25' Tradewind
Burnsville
, North Carolina
Flooring and Curtains 73 Tradewind
Work In Progess (WIP). We can't seem to finish up one job when another issue nips at our heels (the leaks today). We may not be 100% by 1st trip Date, April 7th, but we will make due and ENJOY! The flooring is floating engineered bamboo and curtains are sunbrella with a blackout lining. We still want to tint the windows and darn it, if that got left off the LIST. Along with including the new stained clear pine stand off that the constructor installed for the curtain track and to put the couch cushion in the correct place.
03-13-2011, 08:00 PM
1973 25' Tradewind
Burnsville
, North Carolina
1 The constructor got the new instant hot water heater partially installed using parts from the old hwh box, still some fabricating to go.
2. Working in the plumbing.
3. I ruined the light indicator with the stripper. Where do I find a new one of theses?
Ordered the cyclo and parts for polishing tonight. Didn't get any work done today and little yesterday due to us both getting a dreaded cold
03-13-2011, 09:41 PM
1972 23' Safari
Houston
Good luck on your TW. Did a lot of work on mine, on that tambour under the sink I did what you said split the panel so the right 1/3rd was fixed and only the left side had to roll up into the canister. Recovered all of the plastic woodgrain with 1/8" Red oak veneer. Stained with Minwax Provential 215 and it matches the original color and tambour.
03-14-2011, 01:49 PM
1973 25' Tradewind
Burnsville
, North Carolina
Thank RH, your panel redo looks great!
03-14-2011, 01:52 PM
x
XXXX
, XXXX
Ann here is a link to the part you need for the taillight monitor.
Inland RV Center Inc.
03-14-2011, 07:00 PM
1973 25' Tradewind
Burnsville
, North Carolina
73 Tradewind Leaks and Polishing
Next up: Along with tracking down exterior leaks is ...Pulling the fresh water tank. It is leaking if filled over 1/4 full. All our booked trips this year are in campgrounds with water and city water is working fine but we do want this taken care of.
Speaking of leaks, the trim at the banana wrap to the exterior siding is not tight and the siding laps behind NOT over the banana wrap as we expected. Does this mean the BW was replaced wrong or is this a factory original? The constructor has placed it on the list of places to seal up. He is planning on butyl tape and vulkem. Input please! The pictures shows the poorly installed awning by the PO that is also on the list for removal and replacement, that has further pulled the trim off.
Starting the polishing and I am going to help (thinking like the kid on the shake and back commercials, did she really help?) Question on the polishing, we don't have a Dewalt, but a 7" Chicago 1000 to 3000 rpms. Will this work? It isn't adjustable except by the pressure placed on it. Ordered the cyclo... so that is covered.
