04-17-2018, 07:20 PM
#61
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Hey, I spotted an old Trade Wind today on a dealer's lot. I don't know the year exactly but it has the three round lense tail light cluster. It had been gutted inside.
I figure it would be a good project for you.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
04-18-2018, 05:42 AM
#62
1972 25' Tradewind
Chattanooga
, Tennessee
Where is it?
04-19-2018, 07:30 PM
#63
1986 34' Limited
1975 27' Overlander
Conifer
The trailer was not on the sales lot. It was parked close to the service building. I assumed it was a customer's trailer in for repairs.
Sorry to imply it was for sale. Air Forums is a good place to search if you are looking for one.
David
04-20-2018, 05:16 AM
#64
1972 25' Tradewind
Chattanooga
, Tennessee
No problem. Probably renovated my last trailer.
07-07-2018, 05:28 PM
#65
1972 25' Tradewind
Beaumont
, CA
Steve, I have recently purchased a 1972 Tradewind. I have looked at your posts and see you have done what I hope to do with mine. Are there any pictures of your completed shower/toilet areas. Also, I am in the IE area of California. Is the welder you used still in business?
07-09-2018, 11:11 AM
#66
1972 25' Tradewind
Chattanooga
, Tennessee
07-09-2018, 11:12 AM
#67
1972 25' Tradewind
Chattanooga
, Tennessee
My welder was in San Luis Obispo.
07-09-2018, 11:29 PM
#68
1972 25' Tradewind
Beaumont
, CA
Thanks for the additional pictures. SLO is a good distance from me in the IE. I will look for a welder in my area. Did you use the original black water tank, also, what size shower pan did you use?
07-11-2018, 04:46 AM
#69
1972 25' Tradewind
Chattanooga
, Tennessee
As you might see from my posts, I added a grey tank in a bed that the welder made. I also needed headroom in the shower, as well as turn around space. Two problems came from those needs. Trying to get a slope for the drain to the tank under the rear bed, and finding a shower pan to fit. I ended up just building and sealing the area from wood.
07-11-2018, 04:52 AM
#70
1972 25' Tradewind
Chattanooga
, Tennessee
The old black tank was shot and in an unusable place. Once again I needed a good slope to the drains in the back, so ended up getting a new 15 gallon tank that sits above floor level. The platform under the toilet is part of the tank. Do notice the air tubes coming up in both applications
07-11-2018, 10:45 PM
#71
1972 25' Tradewind
Beaumont
, CA
With the additional information and pictures I have a have a greater appreciation for what you have been able to accomplish. Airstreams do not leave much space for a 6 footer to shower and also have the gray water get into a holding tank within the frame wells. I have calls into both the guy I know that welds and Mr. Salwender.
04-22-2019, 07:46 AM
#72
1972 25' Tradewind
Chattanooga
, Tennessee
My project for last spring was to finish converting to all pex by replacing the copper under the sink area and the old faucet. No more junction leaks!
04-22-2019, 07:49 AM
#73
1972 25' Tradewind
Chattanooga
, Tennessee
This year was a repair started by my battery not being charged during the winter by the converter, which is located under the platform bed. After reaching as far as I could and not finding bad fuses, I had to pull out the mattress and wood under it that makes up the platform. Not fun.
04-22-2019, 07:51 AM
#74
1972 25' Tradewind
Chattanooga
, Tennessee
Turns out that I had to do that to see that the wire nut connection from 110 to converter had come loose over 6 years and 6000 miles.
04-22-2019, 07:52 AM
#75
1972 25' Tradewind
Chattanooga
, Tennessee
It won't come loose again!!
04-22-2019, 07:53 AM
#76
1972 25' Tradewind
Chattanooga
, Tennessee
Ready for our first trip this weekend to the Georgia mountains!
06-01-2019, 07:49 AM
#77
1972 25' Tradewind
Chattanooga
, Tennessee
Ok. The next 6 year old instillation to come apart was the pex fitting to the toilet. I didn't put in enough wiggle room, and it broke a fitting on the toilet. $27 and 3 hours figuring it out and fixing.
06-01-2019, 07:54 AM
#78
1972 25' Tradewind
Chattanooga
, Tennessee
