Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Tradewind > 1970-79 Tradewind
Old 04-17-2018, 07:20 PM   #61
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Hey, I spotted an old Trade Wind today on a dealer's lot. I don't know the year exactly but it has the three round lense tail light cluster. It had been gutted inside.
I figure it would be a good project for you.
David
Name:	1804 Albuquerque Trade Wind 1 (Small).JPG
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 04-18-2018, 05:42 AM   #62
Chatthayer's Avatar
1972 25' Tradewind
Chattanooga , Tennessee
Images: 21
Where is it?
Steve and Tobie Thayer
chatthayer@gmail.com
Chatthayer is offline   Reply With Quote
Old 04-19-2018, 07:30 PM   #63
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
The trailer was not on the sales lot. It was parked close to the service building. I assumed it was a customer's trailer in for repairs.
Sorry to imply it was for sale. Air Forums is a good place to search if you are looking for one.
David
Old 04-20-2018, 05:16 AM   #64
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
No problem. Probably renovated my last trailer.
Old 07-07-2018, 05:28 PM   #65
1972 25' Tradewind
Beaumont , CA
Steve, I have recently purchased a 1972 Tradewind. I have looked at your posts and see you have done what I hope to do with mine. Are there any pictures of your completed shower/toilet areas. Also, I am in the IE area of California. Is the welder you used still in business?
mdyucca is offline   Reply With Quote
Old 07-09-2018, 11:11 AM   #66
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
ID:	316421Click image for larger version
ID:	316422Click image for larger version
ID:	316423Click image for larger version
ID:	316424Click image for larger version
ID:	316425Click image for larger version
ID:	316426Click image for larger version
ID:	316427Click image for larger version
Old 07-09-2018, 11:12 AM   #67
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
My welder was in San Luis Obispo.
Old 07-09-2018, 11:29 PM   #68
1972 25' Tradewind
Beaumont , CA
Thanks for the additional pictures. SLO is a good distance from me in the IE. I will look for a welder in my area. Did you use the original black water tank, also, what size shower pan did you use?
Old 07-11-2018, 04:46 AM   #69
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
As you might see from my posts, I added a grey tank in a bed that the welder made. I also needed headroom in the shower, as well as turn around space. Two problems came from those needs. Trying to get a slope for the drain to the tank under the rear bed, and finding a shower pan to fit. I ended up just building and sealing the area from wood.
Old 07-11-2018, 04:52 AM   #70
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
The old black tank was shot and in an unusable place. Once again I needed a good slope to the drains in the back, so ended up getting a new 15 gallon tank that sits above floor level. The platform under the toilet is part of the tank. Do notice the air tubes coming up in both applications
Old 07-11-2018, 10:45 PM   #71
1972 25' Tradewind
Beaumont , CA
With the additional information and pictures I have a have a greater appreciation for what you have been able to accomplish. Airstreams do not leave much space for a 6 footer to shower and also have the gray water get into a holding tank within the frame wells. I have calls into both the guy I know that welds and Mr. Salwender.
Old 04-22-2019, 07:46 AM   #72
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
My project for last spring was to finish converting to all pex by replacing the copper under the sink area and the old faucet. No more junction leaks!
Old 04-22-2019, 07:49 AM   #73
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
This year was a repair started by my battery not being charged during the winter by the converter, which is located under the platform bed. After reaching as far as I could and not finding bad fuses, I had to pull out the mattress and wood under it that makes up the platform. Not fun.
Old 04-22-2019, 07:51 AM   #74
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
Turns out that I had to do that to see that the wire nut connection from 110 to converter had come loose over 6 years and 6000 miles.
Old 04-22-2019, 07:52 AM   #75
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
It won't come loose again!!
Old 04-22-2019, 07:53 AM   #76
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
Ready for our first trip this weekend to the Georgia mountains!
Old 06-01-2019, 07:49 AM   #77
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
Ok. The next 6 year old instillation to come apart was the pex fitting to the toilet. I didn't put in enough wiggle room, and it broke a fitting on the toilet. $27 and 3 hours figuring it out and fixing.
Old 06-01-2019, 07:54 AM   #78
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
