Old 05-19-2013, 06:35 PM   #29
Chatthayer's Avatar
1972 25' Tradewind
Chattanooga , Tennessee
Images: 21
Closest to the front will be 2 22" wide closets on top and 3 drawers below. The middle 37" with the windows will be the toilet and sink on one side and a shower on the other. the back 60" will be a platform bed, with access from the front, and new door on the back, and at one end will be a leaning board similar to the dinette. that will hide the 110 breaker box.
Now it is 4 days of work and then back to the project. I could easily sway the # of days.
Steve and Tobie Thayer
chatthayer@gmail.com
Chatthayer is offline   Reply With Quote
Old 05-21-2013, 06:33 PM   #30
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
Hi Barbie,
When we were at casini you showed me a catalogue for the metal trim around the counters. What was the name of the company?
Thanks, Steve slothayer@gmail.com
Old 05-31-2013, 10:11 AM   #31
webspinner's Avatar
Menlo Park , California
Brunner enterprises: - Aluminum angle, Aluminum tube, Aluminum extrusions, Anodized aluminum, Aluminum pipe, Aluminum channel, Extruded Aluminum angle, brunner enterprises, Aluminum bar, aluminum rod, aluminum edging, aluminum tubing connectors, square tubing connector,
Barbie
Our travel and renovation blog: http://tinpickle.blogspot.com/
webspinner is offline   Reply With Quote
Old 06-12-2013, 07:29 AM   #32
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
Thanks Barbie! Found what I wanted at Brunner, and received the trim for the dinette table and bath counter. Now I need to laminate those and put the vaneer in the edging.
Old 06-12-2013, 07:36 AM   #33
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
Here are some updated photos of the project. As you can see, I installed melamine walls and used the old trim as an edging. I had to cut down the drawers I made for under the old twin beds, and installed them with heavier sliders below 2 hanging closets. Still haven't decided if I will make doors for the closets or do a curtain.
Old 06-12-2013, 07:39 AM   #34
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
The two middle window areas will be a shower on one side and the toilet and sink on the other. I ordered a new 15 gallon holding tank which is twice the capacity of the stock one.
ID:	188105   Click image for larger version
Old 06-12-2013, 07:47 AM   #35
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
Being that my '72 didn't have a grey water tank I ordered a 40 gallon ronco tank for the rear of the trailer. I had a welder make a space for it; strengthen the frame members; lower the skids 3 inches; and install a receiver for our bike rack. Given that the rig had a rear bath, it need a lot of work to overcome the rusty metal and make it much stronger than original. the picture shows the tank in it's frame, ready for the new floor.
ID:	188107   Click image for larger version
Old 06-12-2013, 07:54 AM   #36
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
The old routing of the power cord through the back storage compartment never worked for me, so I installed a outside connection.
Next is to run the drainage and pex water lines.
Old 06-12-2013, 10:15 AM   #37
webspinner's Avatar
Great progress, Steve!
Barbie
Old 06-18-2013, 05:37 PM   #38
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
Here are some more updates. We are trying to get everything a least functional for a 5 day trip to the Sequoia National Park on July 4th. I really do enjoy having a project, especially one that presents some challenges. This one COUNTS!
I finished building out the 37" long x 32" wide shower over the wheel well. I have it all caulked and plan on spraying some textured paint on it....later. The drain line is under the floor and I put in a vent pipe on the back side where the water lines come up.
On the other side you can see the new black tank for the new toilet (that I will soon install plus a vent pipe that I am going to put a solar fan cover on) that will share the same size space as the shower with cabinets and a bath sink that will come...later.
ID:	188571   Click image for larger version
Old 06-18-2013, 05:42 PM   #39
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
I transitioned to pex for the back end. What great stuff and with slip on fittings it is sooo much easier than dealing with soldering copper. The only leaks I had when testing the system were at the copper to pex fittings, where I didn't slip on the fitting far enough. I even used the copper lines coming out of the water heater.
The drain line from the kitchen and bath sink took on some routing issues around the new black tank but it works.
Old 06-18-2013, 05:45 PM   #40
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
I am now routing the discharge lines and valves for the 2 new tanks, and starting to plan on how to structure my platform bed that will fill the back 62" by 89" (less the curves). I am also going to put in a back hatch that will allow me to store stuff under the bed as well as a door from the hallway. More storage is good!
Old 06-18-2013, 05:48 PM   #41
Chatthayer's Avatar
1972 25' Tradewind
Images: 21
When the welder was doing his thing he cut out the water line that was under the trailer. I have installed a new outside fitting that connect to the pex inside. It also serves as a one-way valve some I can pressure3 up the water system with the demand pump.
Old 06-18-2013, 11:38 PM   #42
webspinner's Avatar
Wow! Progress!
Have a great time at Sequoia National Park.
Barbie
