Old 08-04-2017, 08:58 AM   #1
1972 25' Tradewind
Hockley , Texas
'72 Demo Related Questions
During our demo we've discovered a couple of things:
1. After a recent a rainshower, the fresh water access door was leaking into the trailer. This answered our question as to why the fresh water tank was always full. Does the door need to be replaced?
2. The furnace duct is uninsulated and run on the floor. Is this common?
Sub floor is still looking good, but we haven't made it to the infamous rear "wet" bathroom.
Any thoughts from the "resto veterans" would be appreciated.
ID:	291279   Click image for larger version
hbf442 is offline   Reply With Quote
Old 08-04-2017, 09:06 AM   #2
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
Ductwork
The duct on my 67 Overlander is the same. It is long and only serves a single outlet under the tub. I think only a very small amount of warm air actually makes it that far but the long uninsulated run acts kind of like a radiant heater under the cabinets, bed and tub:-)
Mine is currently disconnected to make room for gray water plumbing...
BambiTex is offline   Reply With Quote
Old 08-04-2017, 09:14 AM   #3
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
No, they all do that. Makes you not want to drink out of your tanks. If you open the water door, you'll probably see a thin rubber gasket around the top and sides of the door. I think that was designed to avoid having water leak in, but I can't imagine it ever worked very well. You can try to replace it with a new very thin gasket, but I don't know that it's worth it.
Yes that's normal.
Wear a mask when you start tearing into insulation and other mousy stuff. Hanta virus is a thing. Keep taking pictures and posting. Looking good so far.
TheGreatleys is offline   Reply With Quote
Old 08-04-2017, 12:12 PM   #4
1972 25' Tradewind
Hockley , Texas
Ok, thanks y'all! At least the always full fresh water tank mystery is solved.
Old 08-05-2017, 04:33 PM   #5
1971 31' Sovereign
Temple , Texas
The fresh water access door on our 1971 Sovereign does not leak. The furnace ducting was not insulated.
TxDave is offline   Reply With Quote
Old 08-05-2017, 05:10 PM   #6
1972 25' Tradewind
Calgary , Alberta
Might want to think of replacing the water access door and water inlet with a locking one.
That heat venting is typical, I'll be replacing that same set up with 3" or 4" insulated flex ducting.
Monza is offline   Reply With Quote
Old 08-06-2017, 02:41 PM   #7
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
I threw all of my un-insulated ducting away, along with the 45 year old heater. Replaced it with a second AC. That's Florida living for you!
SuzyHomemakr is offline   Reply With Quote
Old 08-06-2017, 03:21 PM   #8
1981 31' Excella II
New Market , Alabama
As long as the heat from the furnace leaks into the trailer you are ok. They run uninsulated tubes usually under the kitchen and other areas where there is plumbing to help keep it from freezing. There is also a small tube that goes under the floor to keep the tanks from freezing.
Perry
Old 08-06-2017, 03:48 PM   #9
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If you plan on drinking "trailer water", the inlet door needs to be replaced. Many people simply bring along bottled water and solve the problem that way. Water for personal consumption is pretty far down on the usage hit list.
uncle_bob is online now   Reply With Quote
Old 08-07-2017, 07:49 AM   #10
1972 25' Tradewind
Hockley , Texas
Lol, in our first "Vintage" trailer (Argosy Minuet) we never used the heater. We always carried a small space heater just in case. The winters in S.E. Texas can be brutal, especially when we have to break out the long sleeved shirts. We'll be replacing all of the appliances in this one though.
Old 08-07-2017, 07:55 AM   #11
1972 25' Tradewind
Hockley , Texas
Hi
Don't drink the water!! Personal experience from many years of camping. I always warn every guest...that's just me though.
Old 08-07-2017, 03:15 PM   #12
1981 31' Excella II
The door inlet is not designed to be sealed. There is the inlet tube and a vent above that. If it were totally sealed the tank would air lock. You still need an air vent.
Old 08-07-2017, 03:35 PM   #13
1981 31' Excella II
Old 08-07-2017, 05:31 PM   #14
1972 25' Tradewind
Grapevine , Texas
I concur...both cases are typical. I will be addressing the water inlet issue in my rebuild, as that bothers me like crazy...even so, I'd never want to drink the tank water.
No need for insulation on the furnace duct since loss heat will end up in the trailer anyway. This is also why ducted ACs in an RV do not require insulation in certain circumstances. But when you have ducting running through your home attic, then your lost heat (or cold) will be truly lost; hence, the insulated ducts.
jballauer is offline   Reply With Quote
Tire related questions Not Done Tires 17 03-15-2013 08:46 PM
Zip Dee Awning Video Demo Colonial Airstream Commercial Listings 15 10-16-2008 06:24 AM
Clear Wrap Window Glass and other related questions StAlphonzo Windows & Screens 4 06-11-2008 08:49 PM
Floor Demo hhuber General Interior Topics 3 08-10-2003 11:06 AM
Airstream & NREL Demo gklott Our Community 2 08-05-2003 05:23 AM
