08-04-2017, 08:58 AM
1972 25' Tradewind
Hockley
'72 Demo Related Questions
During our demo we've discovered a couple of things:
1. After a recent a rainshower, the fresh water access door was leaking into the trailer. This answered our question as to why the fresh water tank was always full. Does the door need to be replaced?
2. The furnace duct is uninsulated and run on the floor. Is this common?
Sub floor is still looking good, but we haven't made it to the infamous rear "wet" bathroom.
Any thoughts from the "resto veterans" would be appreciated.
08-04-2017, 09:06 AM
1955 22' Safari
Laredo
Ductwork
The duct on my 67 Overlander is the same. It is long and only serves a single outlet under the tub. I think only a very small amount of warm air actually makes it that far but the long uninsulated run acts kind of like a radiant heater under the cabinets, bed and tub:-)
Mine is currently disconnected to make room for gray water plumbing...
08-04-2017, 09:14 AM
1974 27' Overlander
Baltimore
, Maryland
No, they all do that. Makes you not want to drink out of your tanks. If you open the water door, you'll probably see a thin rubber gasket around the top and sides of the door. I think that was designed to avoid having water leak in, but I can't imagine it ever worked very well. You can try to replace it with a new very thin gasket, but I don't know that it's worth it.
Yes that's normal.
Wear a mask when you start tearing into insulation and other mousy stuff. Hanta virus is a thing. Keep taking pictures and posting. Looking good so far.
08-04-2017, 12:12 PM
1972 25' Tradewind
Hockley
Ok, thanks y'all! At least the always full fresh water tank mystery is solved.
08-05-2017, 04:33 PM
1971 31' Sovereign
Temple
The fresh water access door on our 1971 Sovereign does not leak. The furnace ducting was not insulated.
08-05-2017, 05:10 PM
1972 25' Tradewind
Calgary
, Alberta
Might want to think of replacing the water access door and water inlet with a locking one.
That heat venting is typical, I'll be replacing that same set up with 3" or 4" insulated flex ducting.
08-06-2017, 02:41 PM
1972 29' Ambassador
Boynton Beach
I threw all of my un-insulated ducting away, along with the 45 year old heater. Replaced it with a second AC. That's Florida living for you!
08-06-2017, 03:21 PM
1981 31' Excella II
New Market
, Alabama
As long as the heat from the furnace leaks into the trailer you are ok. They run uninsulated tubes usually under the kitchen and other areas where there is plumbing to help keep it from freezing. There is also a small tube that goes under the floor to keep the tanks from freezing.
Perry
08-06-2017, 03:48 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
If you plan on drinking "trailer water", the inlet door needs to be replaced. Many people simply bring along bottled water and solve the problem that way. Water for personal consumption is pretty far down on the usage hit list.
08-07-2017, 07:49 AM
1972 25' Tradewind
Hockley
Lol, in our first "Vintage" trailer (Argosy Minuet) we never used the heater. We always carried a small space heater just in case. The winters in S.E. Texas can be brutal, especially when we have to break out the long sleeved shirts. We'll be replacing all of the appliances in this one though.
08-07-2017, 07:55 AM
1972 25' Tradewind
Hockley
Hi
Don't drink the water!! Personal experience from many years of camping. I always warn every guest...that's just me though.
08-07-2017, 03:15 PM
1981 31' Excella II
New Market
, Alabama
The door inlet is not designed to be sealed. There is the inlet tube and a vent above that. If it were totally sealed the tank would air lock. You still need an air vent.
08-07-2017, 03:35 PM
1981 31' Excella II
New Market
, Alabama
08-07-2017, 05:31 PM
1972 25' Tradewind
Grapevine
I concur...both cases are typical. I will be addressing the water inlet issue in my rebuild, as that bothers me like crazy...even so, I'd never want to drink the tank water.
No need for insulation on the furnace duct since loss heat will end up in the trailer anyway. This is also why ducted ACs in an RV do not require insulation in certain circumstances. But when you have ducting running through your home attic, then your lost heat (or cold) will be truly lost; hence, the insulated ducts.
08-07-2017, 06:23 PM
1979 23' Safari
Wayland
, New York
I'll umpteenth the door. Gasket sucks. Rain runs down collects dirt and washes it into the FW tank. My FW tank was full of black sludge from years of the door leaking. It was also brittle and starting to crack. Had to replace the inlet and tank. They don't make the inlet doors anymore.
Duct uninsulated.
08-07-2017, 09:26 PM
1972 25' Tradewind
Calgary
, Alberta
Interesting thought on the insulation.
08-12-2017, 08:07 PM
1964 26' Overlander
Milton
, ON
Be sure to check the subfloor where it goes under the wall. Poke something sharp in there to make sure it's sound. When an Airstream leaks the water often pools at the bottom of the wall between the interior and exterior skins. From there it can soak through the bolt and screw holes into the plywood. The plywood is part of the connection of the shell to the frame, so it's important that it's in good condition.
09-18-2017, 07:38 PM
1969 23' Safari
Blenheim
, Ontario
For the door to stop leaking I used the gasket for a out door outlet. Cut the gasket into strips and stick them on. Be sure to prepared your surface with methnolhydrate or something to get rid of any moisture before sticking it on. Cheers!
