Old 07-20-2016, 02:39 PM   #1
Firemntom's Avatar
Manhattan , Illinois
71 Tradewind
Just brought home 'RubyJane" and started digging and testing Hoping you guys can help with a few questions.
1. Original univolt, plugged it in and can here a Humming, doesn't have a battery installed, is that the reason nothing lights up?
2. I have the original connection for the black water tank dump. If I am hooked up at the site can I leave the dump valve open or should I be worried of sewer gas coming back through out the drains? I would like continues flow from the toilet and gray water and not worry about opening the dump.
3. Hooked it up to city water and didn't get any flow from the sinks, Does the Pump have to be charged or on for flow?
Tom
Firemntom is offline   Reply With Quote
Old 07-20-2016, 02:44 PM   #2
1971 31' Sovereign
Palm Desert , California
Welcome.
1) Dump the Univolt. It causes a lot of problems. Go to Bestconverter.com and order a new one.
2) I don't know the answer to this one.
3) Hooked to city water you should have flow. If you have zero flow there is probably a blockage at the regulator or somewhere else.
CaCraig is offline   Reply With Quote
Old 07-20-2016, 05:40 PM   #3
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
2. Leave your black valve closed and dump periodically or you will have an awful caked on mess to deal with. You need some volume to flush out the solids. If you leave it open, liquid will drain but solids won't. You can leave the Gray valve open if you have one. Traps at all your fixtures should keep sewer gasses out of the coach.
TheGreatleys is offline   Reply With Quote
Old 08-09-2016, 12:26 AM   #4
1973 25' Tradewind
Redding , California
71 Tradewind
1. Change out univolt soon as you can. Easy worthwhile upgrade. The univolt has a panel on it you should keep for the shunt and possibly the fuse block if you choose not to upgrade the fuse panel. The rest you can toss.
Leadvox is offline   Reply With Quote
1963 Tradewind :: 1963 Airstream Tradewind Fredrick00 Airstream Registry Discussions 0 06-27-2014 08:37 AM
1959 Airstream Tradewind :: 1959 Airstream Tradewind steveirving Airstream Registry Discussions 0 10-28-2012 05:55 AM
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
