Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Tradewind > 1970-79 Tradewind
Old 07-17-2015, 11:12 PM   #21
1968 24' Tradewind
1967 17' Caravel
Northborough , Massachusetts
Spray in foam...
I bought spray in foam kit for my underbelly. Mine came with foam sprayed in at the factory and it held up pretty well. It can hold water if it gets wet up in there though. I've made water getting in there from above quite difficult.
I've made it difficult for rodents and other in-sundry critters to find a way in there as well. I have a couple screened intakes for airflow to the fridge and a custom mounted AC unit. I'm looking into trying to engineer a serviceable remote AC unit down there in my next renovation.
Chuck
cwbiii is offline   Reply With Quote
Old 07-18-2015, 05:34 AM   #22
johnamjr's Avatar
1970 25' Tradewind
parkville , Maryland
Spray foam! What an idea. What kind?
johnamjr is offline   Reply With Quote
Old 07-18-2015, 10:27 PM   #23
1968 24' Tradewind
1967 17' Caravel
spray foam kit
https://www.sprayfoamkit.com/spray-f...its-value.html
This is where I got the kit to do the spray foam insulation. I have yet to do it as I need to finish up everything and test it as well before I seal everything in there with the foam. I plan to put in several inches at about r-7 per inch.
The extra leftover I will use in another space in my house that needs it. There is a procedure for shutting the spray mechanism down to be used again later, but it needs to be used again within 30 days so I plan to use it all somewhere in one shot. I have to be careful how much I use as layering it on too thick can be a problem... I also don't want to get it on the back of any aluminum as it can be difficult to remove. I don't want it where it could wick water into the foam if it somehow gets inside. I will probably use painters tape and plastic sheet as a barrier where I will spray close to the shell... similar to masking for painting.
Chuck
Old 07-20-2015, 04:56 PM   #24
johnamjr's Avatar
1970 25' Tradewind
Name:	ImageUploadedByAirstream Forums1437432942.069674.jpg
ID:	243541Click image for larger version
Name:	ImageUploadedByAirstream Forums1437432961.649998.jpg
Old 07-20-2015, 04:57 PM   #25
johnamjr's Avatar
1970 25' Tradewind
That foam kits a little rich for my blood. Would be nice to do. But can't fit that in the budget.
Old 07-20-2015, 06:49 PM   #26
larry b's Avatar
1975 31' Sovereign
howell , Michigan
Originally Posted by johnamjr View Post
We are going to spray por15 whitecote.
Great product, used this and it laid out well with a foam roller no rollermarks, make sure you use a resperator, very potent fumes.
I tinted mine to a light grey and it worked great, mine cured a little faster than stated in the instructions be careful not to mix up too much for the first coat, I made this mistake and wasted a large qty.
larry b is offline   Reply With Quote
Old 07-21-2015, 05:41 PM   #27
johnamjr's Avatar
1970 25' Tradewind
Good to know thanks! I am trying to wait for the weather in md to not be so humid.
Old 07-22-2015, 03:53 PM   #28
johnamjr's Avatar
1970 25' Tradewind
Name:	ImageUploadedByAirstream Forums1437601966.563834.jpg
Almost ready for new air conditioner!
Old 07-22-2015, 10:17 PM   #29
1968 24' Tradewind
1967 17' Caravel
Crane...
Now all you need is a crane.
Chuck
Old 07-25-2015, 01:14 PM   #30
johnamjr's Avatar
1970 25' Tradewind
Yea that would be nice. I do someone with a bucket truck. That's an idea. Any ways. Tomorrow is the day going to remove the old and install the new.
Old 07-26-2015, 01:47 PM   #31
johnamjr's Avatar
1970 25' Tradewind
The old Armstrong came off with out much of a fight. Jacking it up from the inside really helped get it separated after removing all screws and cutting under all the vulcum.
Name:	ImageUploadedByAirstream Forums1437940018.872606.jpg
ID:	243963Click image for larger version
Name:	ImageUploadedByAirstream Forums1437940035.414422.jpg
ID:	243964Click image for larger version
Name:	ImageUploadedByAirstream Forums1437940049.186844.jpg
Old 08-10-2015, 03:20 PM   #32
johnamjr's Avatar
1970 25' Tradewind
New floor is in. Old fridge is out. Good thing the new ac unit works great. Makes it some much better to work inside.
Old 08-12-2015, 04:50 AM   #33
johnamjr's Avatar
1970 25' Tradewind
Name:	ImageUploadedByAirstream Forums1439376572.593920.jpg
ID:	245301Click image for larger version
Name:	ImageUploadedByAirstream Forums1439376585.015967.jpg
ID:	245302Click image for larger version
Name:	ImageUploadedByAirstream Forums1439376617.651628.jpg
Old 08-14-2015, 02:34 PM   #34
johnamjr's Avatar
1970 25' Tradewind
Name:	ImageUploadedByAirstream Forums1439584169.552437.jpg
Rear trim and rear compartment going back together.
Name:	ImageUploadedByAirstream Forums1439584210.820908.jpg
ID:	245469   Click image for larger version
Name:	ImageUploadedByAirstream Forums1439584276.036962.jpg
Name:	ImageUploadedByAirstream Forums1439584350.534402.jpg
Old 08-14-2015, 05:20 PM   #35
johnamjr's Avatar
1970 25' Tradewind
Name:	ImageUploadedByAirstream Forums1439594406.736575.jpg
ID:	245480Click image for larger version
Name:	ImageUploadedByAirstream Forums1439594420.778354.jpg
Old 08-15-2015, 01:50 PM   #36
johnamjr's Avatar
1970 25' Tradewind
Name:	ImageUploadedByAirstream Forums1439668194.445560.jpg
ID:	245547Click image for larger version
Name:	ImageUploadedByAirstream Forums1439668209.438336.jpg
Floor finished and couch back in.
Old 08-15-2015, 02:40 PM   #37
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Land Of Enchantment , New Mexico
Very nice work, johnamjr! Can't wait to see the finished bathroom.
Jaxon
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 08-17-2015, 06:43 PM   #38
johnamjr's Avatar
1970 25' Tradewind
Yea we are waiting on more por15 white coat.
Old 05-22-2016, 07:01 AM   #39
starstruck08's Avatar
1976 25' Tradewind
Tallahassee , Florida
I know this thread is older, but that front couch is gorgeous compared to the one that came with my '76. Is it a replacement or original? Re-upholstered maybe?
Starbound
starstruck08 is offline   Reply With Quote
Electric Grills, do they not get hot enough, are they a waste of time? adiben On The Road... 17 06-01-2015 10:45 AM
Are 1961 Tradewinds rare??? henrydahm 1959-69 Tradewind 33 05-28-2014 08:09 AM
1971 Airstream Excella 500; rare, rare rear bedroom model eBay Watch Airstreams on eBay 0 06-21-2013 09:20 PM
RARE RARE RARE 1964 22 ft Airstream Safari NO RESERVE eBay Watch Airstreams on eBay 0 08-01-2011 11:40 AM
They don't make them like they used to femuse Our Community 23 04-29-2003 07:15 AM
