Old 06-15-2008, 12:23 PM   #1
smcpheters's Avatar
1962 22' Flying Cloud
1954 26' Romany Cruiser
Freeport , Maine
Popped Interior Rivets - 1962
Hi all,
New question for everyone. I am finding rivets on the floor occasionally after I move the trailer. Doesn't happen with every move, but off and on. My wife has told me this means a bad thing. Myself, it seems natural that a structure moving along the roads in Maine should have a few popped rivets, I know I do. Do I need to worry or should I just replace the rivets?
smcpheters is offline   Reply With Quote
Old 06-15-2008, 12:29 PM   #2
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
Have you checked your axles? If they need replacement, they could cause enough of a bad ride to pop rivets. Also, you might check your tires for bubbles or out-of-round conditions. Unbalanced running gear is an issue with interior problems like popped rivets, drawers coming out, wall/interior shell separation, etc.
We were popping interior rivets in our moho until we got new tires and redid the suspension. It was very annoying!
Good luck!
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 06-15-2008, 02:09 PM   #3
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Timely question.
I have heard various views on this.
Inland Andy says it results from bad axles (they wear out) and/or unbalanced running gear.
Someone else told me that it's normal for rivets to pop out.
Seems to me that if an airplane can go for thousands of miles and landings without rivets shooting out my trailer ought to make it to the camp ground without an in transit disassembly.
So I replaced about 12 interior rivets that self detached and balanced by wheels, hubs and brakes. So far all the rivets are where they belong.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 06-15-2008, 02:11 PM   #4
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The other item that may cause the in-flight rivet loss may be a too-stiff tow vehicle suspension, or a WD not set up quite right.
Old 06-15-2008, 02:48 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We had a couple of interior rivets pop right after we got our SE unit... we had them replaced and since then none have been lost... (Now watch...the next time we go out we've have them popping out all over he place!)
TB & Greg and Abbey Schnauzer
#3954
Old 06-15-2008, 03:55 PM   #6
2008 27' Safari FB SE
Mesquite , Texas
Interior "pop" rivet popped out
Timely post.
I had one rivet laying in the middle of the bed on our new 27FB when I picked it up Friday. Looking at it, it didn't seem to have expanded very much, if at all on the back. I found an aluminum rivet the same size in the garage and popped it in.
Nothing else since then even though we were on some pretty rough roads in construction zones over the weekend.
I will keep my eyes open though.
wayner61 is offline   Reply With Quote
Old 06-15-2008, 05:23 PM   #7
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
Originally Posted by smcpheters View Post
Hi all,
A stands for axles
B stands for bad axle
C stands for Cough up the dough for a new axle
W stands for Wife is right again.......this may be the hardest thing to accept. Oh yeah, and Maine roads are really BAD right now. But that will be fixed in about fifty years and fifty million dollars.
Don't worry, be happy, get a new axle.
safari62 is offline   Reply With Quote
Old 06-15-2008, 07:06 PM   #8
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Old Maid rivet ...
Wayner61:
It must have been one of those Old Maid rivets that usually resides in the bottom of the bucket, unpopped.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 06-15-2008, 07:25 PM   #9
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Originally Posted by 47WeeWind View Post
Wayner61:
Fred, That's a rather "corny" comment.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 06-15-2008, 08:57 PM   #10
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Well this is my opinion only and I don't even pretend to be an expert.But I have found working(they leave a little grey stain around them) rivets in bulk heads and walls, under the rear goucho, and now external rivets poped above the axles. Needless to say this unit is GROUNDED till my new axles arrive.This is too big and investment to take chances with, Unless of Course U are made of money. Inland RV has a thread that shows U the proper angle that your axle should be at. Take HEED my friend this could be trouble. Also the PO had our unit way way over hitched,that has caused a few external rivets in the front to pop.
Best of Luck to U
Roger
Mikethefixit is offline   Reply With Quote
Old 06-15-2008, 09:47 PM   #11
Mesquite , Texas
Hey Fred - Very NICE!
I had kind of a silly little remark to put in there myself but chickened out.
Wayne
Old 06-16-2008, 06:03 AM   #12
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Images: 43
And just a few other thoughts........
Your model and year has the aluminum interior walls that overlap the fiberglass interior end caps. This is where rivets may be more likely to loosen up as the holes in the fiberglass have enlarged over, say, the last 45 years. Try some slightly larger rivets or maybe even epoxy in and between first.
ALSO VERY IMPORTANT!!! Do not travel with large amounts and heavy materials in overhead compartments. Dishes, canned goods etc must be placed in lower storage areas while travelling. I place these kind of things in a plastic tub under the sink, etc and also as much forward in the trailer as you can.
Tires....lots of info elsewhere but avoid truck highply etc. Go radial and away maintain correct pressure.
good luck
Old 06-18-2008, 07:09 AM   #13
smcpheters's Avatar
Freeport , Maine
Thanks All,
As it so happens, I have another problem with electric brakes that will require replacing the axle. I need to call Inland at the end of the month to find out what I need to order and get it done. We want to haul to PEI in August with another couple who tow a SOB.
Old 06-18-2008, 08:14 AM   #14
Baltimore , Maryland
I want to throw my two cents in here... Are the popped rivets in the same area every time? If you have floor issues the rivets in that area will pop out when you tow, due to the floor flexing more than it is designed to. I strongly encourage you to look very closely along the wall below that area. A broken cross member or some soft floor will often lead to the problem you are experiencing. Yes bad axles will cause this too. So is this in one area or all over?
Help a newbie! Popped rivets on interior roof and side... Arnoldjeff General Repair Forum 7 08-24-2014 03:35 PM
Question: popped rivets on the wheel well trim. TomS General Repair Forum 4 08-24-2014 07:00 AM
Window hinge popped rivets HiJoeSilver Windows, Doors, Locks & Vents 4 11-08-2013 05:25 PM
Help.... popped rivets? Markj55 Windows, Doors, Locks & Vents 16 08-27-2013 04:13 AM
Popped rivets, repair and prevention Boondocker General Interior Topics 26 11-28-2005 04:57 PM
