Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 1960 - 1963 Flying Cloud
Old 06-30-2012, 09:09 PM   #21
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
Picture #1, the front window. Need to find Wally a battery box, anyone got one laying around?
Picture #2 - Wally under a day's worth of nuvite on the window frames.
ID:	162138   Click image for larger version
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 07-07-2012, 06:35 PM   #22
goransons's Avatar
1963 22' Safari
M50 Help!!
A trailer Wally picked up that had been partially crushed by a snow shed collapse had what looks to be an amazingly good M50 refrigerator. Though brown instead of while he figured it could be refinished by an appliance shop or body shop easy enough. We got it loaded (long story) and back to his garage to figure out the burner has been taken apart and looks like a sheet metal sheild is missing.
Does any one have photos of what this should look like?
Does anyone have an otherwise dead unit that might have a donor burner assembly?
Upon first glance I didn't see a thermocouple in that area either, did it have one?
Shelves, door, hinges, shelves, freezer are amazing, even the original decals with the specs on the inside of the door are perfect. Would be 'cool' to get this back in the trailer.
Wouldn't fit out the donor trailer door without it coming apart, with it being 100 degrees outside we found a quicker way out, awefully convenient that the window was already out and just the right size.
ID:	162619   Click image for larger version
Scott & Megan
Old 07-07-2012, 06:41 PM   #23
Central , Mississippi
The parts missing from the M50 are, unfortunately, the parts that are very hard to get. The Klixon and ceramic burner and salvage parts only as best I can tell. I'm in the same boat...considering using a lat model fridge for the propane and controls and adapting it to my M50...if I could find a dead late model fridge!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 07-07-2012, 08:52 PM   #24
goransons's Avatar
1963 22' Safari
found parts, anyone ever seen a burner documented on the forums?
Wally had recovered the top of the burner unit, but couldn't figure out why the burner was so far away. Did find a vintage service manual pdf online with just drawings, so was out at the trailer getting a piece of trim and found this in the pile of rat droppings... We're closer.
forgot to take pictures of the other pieces, but I think the burner itself might now be complete, the klixton valve however I don't see that it is complete, missing the "tongue" portion.
Here's the diagram:
Dometic Service Manual MC16,M27, M28, MA35, MA40, M50,M52, MA52, MB52, M70
page 22 I think shows it best.
I'm wondering if a modern gas valve with thermocouple could be retrofitted.
Again if anyone has a junker around for parts, let us know.
Scott & Megan
Old 07-07-2012, 09:13 PM   #25
goransons's Avatar
1963 22' Safari
Also been reading this thread, have emailed the vendor, not sure if they are still around, haven't logged on the forums since 2007. Claimed to be able to order burner parts and klixon valve.
Scott & Megan
Old 07-07-2012, 09:16 PM   #26
Here is what mine looks like. As you can see the tongue is missing. You can't see the burner is actually broken, it's ceramic.
Old 07-07-2012, 09:22 PM   #27
Oh, I mentioned on my '63 thread I am willing to try a late model retro fit if I can find a donor late model fridge. I have fired mine up and gathered data to replicate the ceramic burner, klixon and wierd pressures used on this fridge cooling unit
Old 03-02-2013, 09:04 AM   #28
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
A new year and oh so many frame problems
The snow has melted and the weather nice enough for the start of what was a quick sub floor replacement and then the restoration of cabinets etc., etc... I took my time and was very careful not to damage anything as I removed the interior. To my horror as the different items came out, the trailer has changed shape. Someone in the past had replaced the front 10 feet of sub floor and didn't run it under the C channel. The result isn't pretty!!!
When I removed the remainder of the 10' patch, I discovered that all four main cross members will have to be replaced. I'll also have to repair or replace several out riggers.
This is my first "Ohio" trailer and I need to know a couple of things. Did Ohio trailers have sub floor that extended past the outriggers? My wall/C channel position is completely outside the end of the outriggers.
Question two, did the Ohio trailers ever have the bows rest on an outrigger? On the street side of my trailer there are only two bows that reach the floor, to many windows, and those two bows fall between the outriggers. The plywood must have been supporting the complete street side wall.
I'll be checking the rear sagging frame soon and will then decide if I'll repair or start looking for a donor frame.
Name:	plywood repairs not under the wall.jpg
ID:	180087   Click image for larger version
Name:	inside front street corner.jpg
Name:	rusted out cross member and rat crap.jpg
ID:	180089   Click image for larger version
Name:	curb front plywood removed.jpg
Wally H.
Parts needed
1962 Street side corner tub
range or parts
Dometic 50 or parts
flyrc is offline   Reply With Quote
Old 03-02-2013, 05:23 PM   #29
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
Hi Wally,
On my 1962 Ohio built ATW Airstream, the sub floor definitely goes under the floor channel. If I remember correctly it is about 88" wide and extends slightly beyond the ends of the outriggers, maybe 1/4" on each side. The floor channel was bolted to the end of each outrigger thru the floor. When the floor is removed, the base of the shell tends to spread wider a little and will need out be pushed into place slightly to rebolt the outriggers and screw the channel to the floor. In most cases, except where the end caps meet the sides, the ribs do not align to the outriggers. The floor definitely is part of the structure.
Joe
WBCCI/VAC #702 & #6768
66Overlander is offline   Reply With Quote
Old 03-02-2013, 07:18 PM   #30
goransons's Avatar
1963 22' Safari
Hey Wally looks like you have an overlap on the outrigger at bow #1, at least enough for bolting. What I used to pull the trailer skinny again was some orange ratchet straps. For better or worse I was able to screw some 1"s trap across the bows on both sides and used the straps to pull it together. Of course one side moved first, so it got bolted then did the othe side. Looks like the main rails are pretty solid, just the thinner guage cross members and out riggers. Jim should be able to weld those up nice. When you've got the welding done and the floor panels in I'm happy to come help you muscle the shell back into the right location. My fat butt is good for something!
Scott & Megan
Old 03-06-2013, 10:09 AM   #31
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
More fun ahead :-( Yesterday after I got all the many pounds of rat nest and crap out of the front belly pan area I found that there is mega rust issues in the first cross member that I presume holds the front anchor plate. If I have to remove it with the plate as one unit it is going to present a major problem because the floor is out and it is the only thing holding up the front shell. I guess I can do a temp floor install and then R&R the cross member before I Por-15 and finish the final sub floor install.
The next issue is what do I do with the main wiring bundle MESS??? Mine has been cut, taped, and spliced everywhere. Have you guys added a modern junction box on the inside wall up front?
I know advice is free, so fill the page :-) I'm getting a bid to have cross members and out riggers re-manufactured, so if the cost is O.K. I will be able to help anyone of you that might want light weight originals.
Thanks, Wally
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 03-06-2013, 03:58 PM   #32
Baltimore , Maryland
rewire it all...
Old 03-06-2013, 08:02 PM   #33
1962 22' Safari
2016 30' Classic
Images: 41
You do not need to go to the expense of having cross members custom formed. You can just purchase 14 ga. 4" x 2" rectangular steel tubes (like shown below) and cut one side off to make cross members. This is what I did on my trailer. I would think this would work for your front cross member that has the hold down plate as well as the other cross members. Definitely degrease it and use an etcher before painting.
I assume most outriggers could be made from the same material, but possibly with an diagonal brace added to approximate the originals. I did not have to do this on my trailer.
Hopefully your main rails are good enough to not need replacement or reinforcement, but if you find a small section that needs to be replaced, the exact same 4" C-channel beam with the upper and lower flanges tapered is still available (see photo below). There is a thicker and thinner version. The thinner version should match your original 1962 frame. You may have to have a close out plate welded across the open side of the C to make a closed beam at the very front or rear. I had to replace about a 2 foot long section of one of my main rails back by the bumper using this stuff. The rest, while a little pitted in places (but still covered in black paint in other places) was still strong enough to be wire brushed and then repainted with POR15.
Regarding how to deal with the front cross member and hold down plate with the body on, you should be able to clamp or screw/bolt small pieces of plywood to the outriggers where the end caps meet the straight sides and then screw the shell to the plywood pieces to hold it in place.
If you ever have to raise the shell slightly to get a peice of plywood (or the final floor) between an outrigger and the floor channel, you can carefully use a floor jack and a "big wooden tee" (see photos below). The "big wooden tee" would have a large flat section on the top to push up on the roof, ideally spanning from rib to rib, or at least across a vent opening. I'd suggest a peice of 2x8. Keep it oriented lengthwise so it doesn't have to be curved to match the roof curvature. The leg of the tee would then extend down to the floor jack. You could use a 2x4 for this piece. You won't have to raise it much to open the gap enough to slide the plywood between the outrigger and floor channel.
As for wiring, while the inner skins are at least partially out, you might as well replace it all. And yes, I'd recommend replacing the original 110VAC circuit breaker box with a modern equivalent and add a 12V panel as well.
Joe
Old 03-07-2013, 07:25 PM   #34
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
Joe are you talking about the front when you say I should add a 12V panel? Here is what it looks like right now Is the panel just attached to the inner wall. Where would you route the wire harness?
Thanks, Wally H
P.S...I think the cross member will need to be replaced
Name:	Bad front cross member.jpg
ID:	180393   Click image for larger version
Name:	front 12V wiring mess.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 03-07-2013, 08:22 PM   #35
asbury park , New Jersey
wally, i apologize for backtracking but i've only just read the thread. Did the owner you bought your trailer from give you the photos? Where did the photos come from? Did they tell you any info that helps you trace it from the Original owners to them? I'm interested in the history. Thx.
NJtoNC is offline   Reply With Quote
Old 03-08-2013, 07:52 AM   #36
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
Photos and History
The person that sold me the trailer didn't know anything about the trailer. He bought it in Arizona and "flipped" it for a profit. I was tipped off by a friend about what I was buying and a brief history. There are a few survivors of the 63/64 caravan.
About two months ago I started tracking down Fran Halls surviving family and located a niece that had a lot of information about the caravan and 130 B/W photos. The color photos are from Airstream Advertising. Fran (Francis) Hall was hired by Airstream to be the trip photographer. One thing I've learned about Mr. Hall is that he worked for Disney and filmed the movie,"The living Desert".
I'll try to attach a 70 odd page pdf of Frans recollection of the caravan that he dictated to his niece when he was in his 80's. If I can attach it,I'll gladly send you the PDF and all the photos on a CD.
It's great to have people interested in the caravan. If you have LOTS of time read Scotts blog on this forum,
'63 Safari - It 'Bee' Traded (#8671)
Wally H.
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 03-08-2013, 09:36 AM   #37
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
#83 survived
When I look at these photos I'm thankful I have a trailer to work on and I'm not surprised at some of the problems I'm running into These photos where taken in Afghanistan just down the mountain from Khyber Pass.
ID:	180449   Click image for larger version
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 03-08-2013, 10:41 AM   #38
thank you so much for the copy of the transcript. i will read it tonight. or start it. wow! an accident on the trip. im not surprised. i wonder what they did about it. maybe ill find out in the pdf.... are there still dents in the front from this? Do you have more old photos? i love old photos!
Old 03-08-2013, 03:35 PM   #39
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
Thanks Joe for all the advise. I tried to buy 14ga tubing but it isn't available in this valley.
Wally
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 03-08-2013, 09:10 PM   #40
1962 22' Safari
2016 30' Classic
Images: 41
Wally
Hi Wally,
Not sure how big Yakima is. Might have to go to a larger city. I bought mine in person (no internet sales) from a little hole-in-the-wall type shop in Pontiac, MI that sold steel beams and pipes of all types. My welder told me where to go to get it. Quite frankly it would have been easy to miss the shop if I hadn't been told exactly where to go. The shop had the tools to cut it to the length I requested and sold it to my by the inch/foot.
Before I talked to the welder, I called a few shops I found via an internet search asking if anyone had a formed piece that could be used for the cross members, but no luck. The idea to cut the side off the rectangular tube for make the cross members was the welders idea. I suppose you could use the rectangular tube whole, but could then only install the floor with screws. I wanted to bolt the floor down, so we cut one side off for access. Cutting one side off isn't tough with a grinding wheel, but a band saw would do an even better job if you have access to one.
I would bet that any larger city has a shop that sells steel like I found. There are always guys building equipment and race cars and other stuff that need steel. I guess you just need to know where to look.
EDIT: This place looks promising for having the type of steel tubing you might be looking for:
Yakima Steel Fabricators
Address: 6 E Washington Ave, Yakima, WA 98903
Phone: (509) 575-1570
Hours: Friday hours 8:00 am–5:00 pm
http://www.yakimasteel.com/about/ste...icecenter.html
Joe
Around-the-World Caravan Roster of Caravanners and Trailers PeeWee WBCCI Forum 26 09-08-2023 01:03 PM
Around-the-World Caravan Thank You Marco Polo PeeWee WBCCI Forum 31 02-15-2023 06:32 PM
#7702 - Around the World Caravan? Lumatic Airstream History 14 01-01-2011 02:29 PM
Around-the-World Caravan PeeWee WBCCI Forum 1 09-20-2007 09:23 PM
Found this 1990 250 Classic in San Fran. Astrodokk General Motorhome Topics 6 05-04-2004 08:15 PM
