Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1960 - 1965 Safari
Old 02-07-2015, 01:05 PM   #21
1960 22' Safari
Johnson City , Tennessee
Name:	ImageUploadedByAirstream Forums1423339480.285972.jpg
ID:	231902Click image for larger version
Name:	ImageUploadedByAirstream Forums1423339506.153008.jpg
teilhet is offline   Reply With Quote
Old 02-07-2015, 01:25 PM   #22
1960 22' Safari
Removed the shell today. I braces the inside with 1x6 side to side then added cross braces to that. After all the rivets were removed 7 of were able to lift and walk sideways off the chassis. We rested the shell on some yard stones using the 1 x 6 braces.
The floor was removed and much of the perimeter was rotted and disintegrated.
I'm wondering how I will get the correct arch now.
Old 02-07-2015, 04:12 PM   #23
DFlores's Avatar
1968 22' Safari
Buda , Texas
Get some 1/4" panel cheapest stuff you can find and get your buddies to help get it under the shell an trace shape now, it will change shape as it sits there.
Second option is to do some research on making and using a story stick to duplicate the curves, that is what we did on our trailer.
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 02-07-2015, 04:19 PM   #24
DFlores's Avatar
1968 22' Safari
Buda , Texas
Here is link to one persons instruction on story stick, I'm sure there are more
http://www.airforums.com/forums/f36/...pes-29321.html
DFlores
David & Diana
Old 02-07-2015, 05:12 PM   #25
1960 22' Safari
My 1960 22' safari
Yes, I've read about the story stick...
I was thinking about doing that.
I didn't think about it changing shape. Thanks for the tip.
Old 02-07-2015, 06:28 PM   #26
paisley's Avatar
1960 22' Safari
Asheville , North Carolina
Hey there. Don't know if you've already found an answer to your furnace location question? In my 1960 22' Safari, the furnace is under the bench seat of the dinette (on the left, as you're looking at it).
Good luck with the restoration!
paisley is offline   Reply With Quote
Old 02-07-2015, 07:29 PM   #27
1960 22' Safari
My was directly beneath the oven. It took me awhile to look close enough at it to realize it was indeed the furnace.
Did you replace yours and with what?
Old 02-07-2015, 09:23 PM   #28
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
My 62' furnace is also under the oven. I replaced it with a new Suburban 24 K btu forced hot air unit. This unit requires lots of power from the 12 volt system to run the fan and therefore has limitations.
I would look into these units as an option. Olympian Catalytic Heater - Wave 3 - 3000 BTU
wbcci #3363
VAC - Region 1 vintage Club rep
New England unit
safari62 is offline   Reply With Quote
Old 02-08-2015, 05:41 AM   #29
1960 22' Safari
Thank you. This looks like a great option.
Old 02-13-2015, 12:26 PM   #30
1960 22' Safari
I towed the chassis to the sandblaster and then plan to make the requisite repairs.
Obviously this is the best time to add a grey water tank. I assumed I would add an appropriate tank purchased from vintage trailer supply.
What I'm unsure of is the best placement for a grey water tank.
Any tips?
Old 02-26-2015, 01:38 PM   #31
1960 22' Safari
Any insight on where to purchase replacement outriggers?
Old 03-30-2015, 10:04 AM   #32
1960 22' Safari
The welder has made some great headway. He replaced a few outriggers, a couple cross beams and the last 3' for one of the square tubes.Click image for larger version
Name:	ImageUploadedByAirstream Forums1427731420.227917.jpg
ID:	235190Click image for larger version
Name:	ImageUploadedByAirstream Forums1427731438.444235.jpg
Old 03-30-2015, 10:04 AM   #33
1960 22' Safari
I've made a plumbing plan as well.Click image for larger version
Name:	ImageUploadedByAirstream Forums1427731481.894850.jpg
Old 10-07-2015, 06:46 PM   #34
1960 22' Safari
I attempted to replace the belly pan starting at the rear. The first attempt failed. I used the original pan as a template, but the curve proved to be trouble anyway. Any insight would be appreciated.
Old 10-07-2015, 07:02 PM   #35
65CV's Avatar
Western , Massachusetts
I feel your pain.
I just looked back on my old Caravel thread and described my first day as the "worst day of Airstream ownership". My son and I spent a total of 14 man hours trying unsuccessfully to sculpt a corner belly pan. We tossed it. See post 17 and followup of this thread. In summary, we found that we needed to remove all interferences like insulation and cut a LOT more relief points.
Great legacy trailer, BTW.
65CV is offline   Reply With Quote
Old 12-05-2016, 04:46 PM   #36
1960 22' Safari
Originally Posted by 65CV View Post
I feel your pain.
Hey, thanks for replying on this thread. I'd long given up on the forum as I felt info overload. I'm still trudging through the renovation, but still enjoying it.
I disassembled my door and was going to insulate it- I happened to find one of your treads which proved most helpful. Anyway...thanks again.
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
Frame slicing through skin on 1960 Safari shinybean Ribs, Skins & Rivets 9 12-03-2006 12:18 PM
1960 or 1961 Safari/Flying Cloud? ScottyWed 1960 - 1965 Safari 0 07-19-2006 09:19 AM
1960 22' safari Ajrandzin 1960 - 1965 Safari 1 07-01-2003 11:44 AM
1960 Safari DanLyle 1960 - 1965 Safari 0 03-26-2002 07:13 PM
