01-23-2015, 07:14 AM
1960 22' Safari
Johnson City
, Tennessee
My 1960 22' safari
I spotted this one on a small lot full of 50s/60s era trailers and motorboats, surprisingly the owner was willing to sell. I got it for $3200, probably not the best deal as I have no idea if anything works. I was looking for a custom renovation anyway.
So far I pulled out 2 layers of carpet and 3/4 ply before I got to the laminate in the photo. I'm told it was used as hunters cabin for awhile, and it shows.
The last photo is of the bathroom closet floor. They had a second water heater in there that looks like it had been leaking. The floor was very soft, so I hammered it out.
01-23-2015, 07:44 AM
Bartlett
Looks like a fun project. Have fun and keep us posted, we like to follow along.
01-23-2015, 07:50 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
It looks like a great one to have and keep. If I were you I'd pull the entire interior out and then look at the floor. You may be OK with just some major patching, then a thin overlay to smooth things out before the finish flooring and your refreshed interior. Working the floor with all the cabinets, tables and beds in the way makes for a bigger project. Have fun.
01-23-2015, 07:58 AM
1960 22' Safari
Johnson City
, Tennessee
I've pulled most of the furniture except the wall dividers...they are firmly in place...what's the best way to remove those so I can save them as templates?
01-23-2015, 09:01 AM
1953 32' Liner
1955 22' Safari
Valley View
The curved aluminum channel at the wall/wood side can be fastened with rivets to the wall. Drill those rivets out. Careful with the channels. That extrusion is impossible to find. Your right about the patterns.
01-23-2015, 12:23 PM
Mission Viejo
Its going to be beautiful!
01-23-2015, 02:57 PM
1966 17' Caravel
Newport
, North Carolina
For hunting huh? Smell a little musty? Looks like a great project so where (what state) are you? I ask because it looks warmer there which means more work time unless you are having our nc monsoon season! Please keep us posted we love a good repair story.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
01-23-2015, 04:06 PM
1960 22' Safari
Johnson City
, Tennessee
Cliff
I'm in East Tennessee actually. The trailer came out of North Carolina before it sat for the last four years where I found it.
The smells not horrible.
01-24-2015, 03:10 PM
1960 22' Safari
Johnson City
, Tennessee
01-25-2015, 04:54 PM
1966 17' Caravel
Newport
, North Carolina
You are making progress but you do have your work cut out for you! Cutout yeah a lot of that too! Keep up the great work.
Cliff
01-25-2015, 07:02 PM
1960 22' Safari
Johnson City
, Tennessee
Cliff
Yeah, the biggest conundrum being; I can't grasp the idea of replacing the floor with the body in place????
01-28-2015, 03:29 AM
1966 17' Caravel
Newport
, North Carolina
So remove those inner walls and pop that shel loose! Made it easier in my opinion!
Cliff
01-28-2015, 07:42 AM
1960 22' Safari
Johnson City
, Tennessee
Cliff
I think I settled on that. Looking into a warehouse that might make it easier.
What's the theory on adding a grey water tank? I've found that at least one crossbeam will need to be replaced and I've read that moving one may be necessary to add a grey tank....
Size?
Placement?
I figured I would keep the black water and clean water tanks where they are...seems to work well.
Thanks!
01-28-2015, 09:04 AM
1972 31' Sovereign
Lexington
Shell-on floor replacement is do-able: we did it that way on a 31 footer. Shell-off is probably easier overall in after thought. Make sure you label your inner walls as you remove them. Makes it SO much easier when you put the jigsaw puzzle back together!
Good Luck!
Kay
01-28-2015, 06:56 PM
1966 17' Caravel
Newport
, North Carolina
Yes label everything! I should have would have saved me kicking my self as much!
Cliff
01-29-2015, 09:33 AM
1972 31' Sovereign
Lexington
And take lots of pictures as you deconstruct things. It's amazing how many times we went back to those pictures .....
Kay
01-29-2015, 07:59 PM
1960 22' Safari
Johnson City
, Tennessee
Thanks for the advice! I've got photos on my phone and camera. I got out my sharpie and masking tape. Today.
I've still got to remove the front interior lining, but I've got to figure out how to remove the clean water tank first.
01-31-2015, 04:34 PM
1960 22' Safari
Johnson City
, Tennessee
H
Half the belly pan is out...it was poorly patched and corroded, so it needed to come out anyway.
02-02-2015, 08:16 AM
1960 22' Safari
Johnson City
, Tennessee
Question:
Where was the furnace located in my Safari? Below the oven?
02-04-2015, 04:01 PM
1960 22' Safari
Johnson City
, Tennessee
The belly pan is out. The chassis looks ok, the last two cross beams and a couple outriggers will need to be replaced.
I hope to have the body removed this weekend possibly. Once the floor is removed I'll haul the trailer to have it welded and repaired.
I found a metal "endcap" with a built in c channel for the ply wood floor...does anyone have experience with this? Is it a good idea?
