Old 02-08-2015, 05:41 AM   #29
1960 22' Safari
Johnson City , Tennessee
Originally Posted by safari62 View Post
My 62' furnace is also under the oven. I replaced it with a new Suburban 24 K btu forced hot air unit. This unit requires lots of power from the 12 volt system to run the fan and therefore has limitations.
I would look into these units as an option. Olympian Catalytic Heater - Wave 3 - 3000 BTU
Thank you. This looks like a great option.
teilhet is offline   Reply With Quote
Old 02-13-2015, 12:26 PM   #30
1960 22' Safari
I towed the chassis to the sandblaster and then plan to make the requisite repairs.
Obviously this is the best time to add a grey water tank. I assumed I would add an appropriate tank purchased from vintage trailer supply.
What I'm unsure of is the best placement for a grey water tank.
Any tips?
Old 02-26-2015, 01:38 PM   #31
1960 22' Safari
Any insight on where to purchase replacement outriggers?
Old 03-30-2015, 10:04 AM   #32
1960 22' Safari
The welder has made some great headway. He replaced a few outriggers, a couple cross beams and the last 3' for one of the square tubes.Click image for larger version
Name:	ImageUploadedByAirstream Forums1427731420.227917.jpg
ID:	235190Click image for larger version
Name:	ImageUploadedByAirstream Forums1427731438.444235.jpg
Old 03-30-2015, 10:04 AM   #33
1960 22' Safari
I've made a plumbing plan as well.Click image for larger version
Name:	ImageUploadedByAirstream Forums1427731481.894850.jpg
Old 10-07-2015, 06:46 PM   #34
1960 22' Safari
I attempted to replace the belly pan starting at the rear. The first attempt failed. I used the original pan as a template, but the curve proved to be trouble anyway. Any insight would be appreciated.
Old 10-07-2015, 07:02 PM   #35
65CV's Avatar
Western , Massachusetts
I feel your pain.
I just looked back on my old Caravel thread and described my first day as the "worst day of Airstream ownership". My son and I spent a total of 14 man hours trying unsuccessfully to sculpt a corner belly pan. We tossed it. See post 17 and followup of this thread. In summary, we found that we needed to remove all interferences like insulation and cut a LOT more relief points.
Great legacy trailer, BTW.
65CV is offline   Reply With Quote
Old 12-05-2016, 04:46 PM   #36
1960 22' Safari
Originally Posted by 65CV View Post
I feel your pain.
Hey, thanks for replying on this thread. I'd long given up on the forum as I felt info overload. I'm still trudging through the renovation, but still enjoying it.
I disassembled my door and was going to insulate it- I happened to find one of your treads which proved most helpful. Anyway...thanks again.
« My new 1960 Safari | Top | - »
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
Frame slicing through skin on 1960 Safari shinybean Ribs, Skins & Rivets 9 12-03-2006 12:18 PM
1960 or 1961 Safari/Flying Cloud? ScottyWed 1961 Safari 0 07-19-2006 09:19 AM
1960 22' safari Ajrandzin 1960 Safari 1 07-01-2003 11:44 AM
1960 Safari DanLyle 1960 Safari 0 03-26-2002 07:13 PM
