Old 01-28-2015, 06:56 PM   #15
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Yes label everything! I should have would have saved me kicking my self as much!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 01-29-2015, 09:33 AM   #16
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
And take lots of pictures as you deconstruct things. It's amazing how many times we went back to those pictures .....
Kay
Old 01-29-2015, 07:59 PM   #17
1960 22' Safari
Johnson City , Tennessee
Thanks for the advice! I've got photos on my phone and camera. I got out my sharpie and masking tape. Today.
Name:	ImageUploadedByAirstream Forums1422586738.661043.jpg
I've still got to remove the front interior lining, but I've got to figure out how to remove the clean water tank first.
teilhet is offline   Reply With Quote
Old 01-31-2015, 04:34 PM   #18
1960 22' Safari
HClick image for larger version
Name:	ImageUploadedByAirstream Forums1422747224.185688.jpg
Half the belly pan is out...it was poorly patched and corroded, so it needed to come out anyway.
Old 02-02-2015, 08:16 AM   #19
1960 22' Safari
Question:
Where was the furnace located in my Safari? Below the oven?
Old 02-04-2015, 04:01 PM   #20
1960 22' Safari
Name:	ImageUploadedByAirstream Forums1423090683.681281.jpg
The belly pan is out. The chassis looks ok, the last two cross beams and a couple outriggers will need to be replaced.
I hope to have the body removed this weekend possibly. Once the floor is removed I'll haul the trailer to have it welded and repaired.
I found a metal "endcap" with a built in c channel for the ply wood floor...does anyone have experience with this? Is it a good idea?
Old 02-07-2015, 01:05 PM   #21
1960 22' Safari
Name:	ImageUploadedByAirstream Forums1423339480.285972.jpg
ID:	231902Click image for larger version
Name:	ImageUploadedByAirstream Forums1423339506.153008.jpg
Old 02-07-2015, 01:25 PM   #22
1960 22' Safari
Removed the shell today. I braces the inside with 1x6 side to side then added cross braces to that. After all the rivets were removed 7 of were able to lift and walk sideways off the chassis. We rested the shell on some yard stones using the 1 x 6 braces.
The floor was removed and much of the perimeter was rotted and disintegrated.
I'm wondering how I will get the correct arch now.
Old 02-07-2015, 04:12 PM   #23
DFlores's Avatar
1968 22' Safari
Buda , Texas
Get some 1/4" panel cheapest stuff you can find and get your buddies to help get it under the shell an trace shape now, it will change shape as it sits there.
Second option is to do some research on making and using a story stick to duplicate the curves, that is what we did on our trailer.
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 02-07-2015, 04:19 PM   #24
DFlores's Avatar
1968 22' Safari
Buda , Texas
Here is link to one persons instruction on story stick, I'm sure there are more
http://www.airforums.com/forums/f36/...pes-29321.html
DFlores
David & Diana
Old 02-07-2015, 05:12 PM   #25
1960 22' Safari
My 1960 22' safari
Yes, I've read about the story stick...
I was thinking about doing that.
I didn't think about it changing shape. Thanks for the tip.
Old 02-07-2015, 06:28 PM   #26
paisley's Avatar
1960 22' Safari
Asheville , North Carolina
Hey there. Don't know if you've already found an answer to your furnace location question? In my 1960 22' Safari, the furnace is under the bench seat of the dinette (on the left, as you're looking at it).
Good luck with the restoration!
paisley is offline   Reply With Quote
Old 02-07-2015, 07:29 PM   #27
1960 22' Safari
My was directly beneath the oven. It took me awhile to look close enough at it to realize it was indeed the furnace.
Did you replace yours and with what?
Old 02-07-2015, 09:23 PM   #28
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
My 62' furnace is also under the oven. I replaced it with a new Suburban 24 K btu forced hot air unit. This unit requires lots of power from the 12 volt system to run the fan and therefore has limitations.
I would look into these units as an option. Olympian Catalytic Heater - Wave 3 - 3000 BTU
wbcci #3363
VAC - Region 1 vintage Club rep
New England unit
safari62 is offline   Reply With Quote
« My new 1960 Safari | Top | - »
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
Frame slicing through skin on 1960 Safari shinybean Ribs, Skins & Rivets 9 12-03-2006 12:18 PM
1960 or 1961 Safari/Flying Cloud? ScottyWed 1961 Safari 0 07-19-2006 09:19 AM
1960 22' safari Ajrandzin 1960 Safari 1 07-01-2003 11:44 AM
1960 Safari DanLyle 1960 Safari 0 03-26-2002 07:13 PM
