Old 07-01-2003, 08:25 AM   #1
Smile 1960 22' safari
I have found one in NY and they are asking 3500 for it. I have to check it out. What is its dry weight as i have a ford Van with a 302 and rv package.
Ajrandzin is offline   Reply With Quote
Old 07-01-2003, 11:44 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
1960 22' safari
While the Airstream weights and measures pdf doesn't list 1960 model, the 1961 would be fairly close in weight. The '61 Safari is listed with an empty weight of 2,900 pounds and a hitch weight of 390 pounds. Keep in mind that the empty weight does not include the weight of any optional equipment installed on coach, water, or other fluids carried in the trailer. You can find this information at:
Airstream Weights and Measures
Good luck with your inspection!
Kevin
Kevin D. Allen
AIR #827
lookin for 1963 22' safari floorplan/model nevisstudio 1963 Safari 7 02-03-2005 08:17 PM
Purchasing Advice: 2004 22' Safari donreitz 2004 Safari 12 10-14-2003 06:44 PM
2004 22' Safari MSRP donreitz 2004 Safari 1 08-20-2003 07:57 PM
1960 Safari DanLyle 1960 Safari 0 03-26-2002 07:13 PM
