Old 05-09-2006, 04:23 PM   #1
1959 18' "Footer"
on the road! , on the road
Weight of Pacer?
hi. i was wondering if anyone knows the weight of the 1960 pacer. and also what sort of tow hitch it takes. we are buying a ford explorer and wondering if it will tow the Pacer. any help?
thanks
quinn is offline   Reply With Quote
Old 05-09-2006, 06:41 PM   #2
RichardT's Avatar
It is not on the Weight chart, but my guess would be about 1900 pounds.
RichardT is offline   Reply With Quote
Old 05-09-2006, 09:38 PM   #3
1960 17' Pacer
easton , Maryland
Pacer weight
My findings find pacer wt to be 1750 empty, I'm using a 2001 ford explorer to tow with, max tow wt of 5500 lbs, so I've had on problems.
peregrine is offline   Reply With Quote
Old 05-10-2006, 10:04 AM   #4
1959 18' "Footer"
thanks... now for hitches....?
thanks! now, any advice on hitch and tow vehicle? we have access to a 1991 ford explorer, which i am really hoping will tow the pacer. if so, will the reese hitch do well enough with a trailer that size? thanks again.
Old 05-10-2006, 11:33 AM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
(off topic) great username for an "airstreamer"! (and welcome to the forums).
here's some trivia: the first child born to the pilgrims in the new world was named "Peregrine".... http://www.pilgrimhall.org/whitep.htm
(allegedly, an ancestor of mine. talk about a salty old newenglander, eh? )
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-10-2006, 11:41 AM   #6
AYRSTRM2's Avatar
1966 22' Safari
1979 30' Argosy
Armada , Michigan
Yes, that set up will be fine; Depending upon the engine in the explorer. Make sure to check your users manual with the Explorer. Also, DO NOT, UNDER ANY CIRCUMSTANCES, use the "bumper" hitch. You must use a frame mounted receiver type Class II hitch. Most will tell you to use a light weight distribution hitch. Don't know much about the ones for that light of a trailer. Hopefully someone can talk about very light WD hitches.
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 01-24-2008, 04:12 AM   #7
pezz
Perry's Avatar
1982 34' Limited
mire poix , midi pyrenees
Weight Pacer
Hi
So that is the empty weight, do you know full load weight
thanks
perry
PERRY
First European Airstream park http://www.airstreameurope.com
Perry is offline   Reply With Quote
Old 01-24-2008, 08:54 AM   #8
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
We towed a PU weighing in at 2800# full up, with a '89 Exploder V6. Draw Tite class III hitch, no WDH or anti-sway, never had any problems.
Ahab is offline   Reply With Quote
Sovereign weight and Preferred tow vehicle JLD 1974 - 1979 Sovereign 26 08-25-2019 05:25 PM
Weight 1987 34' Excella 83Excella 1987 - 1989 Excella 6 03-26-2003 06:43 PM
weight specs for 68 Overlander 26D PeterH-Airstreamer 1965 - 1969 Overlander 5 02-08-2003 03:49 PM
Trailer weight Dbraw 1969 - 1973 Safari 3 06-26-2002 12:01 PM
'71 Airstream Caravel 18' weight specs PeterH-Airstreamer 1969-1971 Caravel 0 06-15-2002 06:28 AM
