Old 05-10-2017, 03:51 PM   #1
1966 24' Tradewind
oberlin , Kansas
Wiring, electrical issues
Hello, I have a 66 Tradewind that I bought about 10 years ago. I had an AC (New and first for trailer) unit placed in roof 9 years ago. Last spring I had to replace it , as it quit (motor?), anyway, had a second new AC placed. Last camping trip on a hot day last year, I had the unit running, along with a fan plugged into outlet at junction box where AC wires meet. I could see sparks behind the faceplate so I stopped everything. When the first AC unit quit, I had been at a park that was having issues, but they checked my power pole and said it was ok. The junction box in trailer however had to be replaced after that incident. At this point I hate to run this new AC unit until I'm sure the wiring is sufficient. I will visit with the RV business that placed the AC to see for sure what wiring he used and how he hooked it all up. My husband will visit with him, he understands electrical better than I. Any advice from those of you familiar with these trailers would be much appreciated. Thank you, Kelly
pearl66 is offline   Reply With Quote
Old 05-11-2017, 07:56 PM   #2
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Pearl66
Sorry that you are having electrical problems. It sounds like there may be a problem with the junction box that was previously replaced. This needs to have the cover removed and make sure it is wired correctly. If a receptacle is wired into the junction box make sure, using a $10 tester, that it is working correctly. Your husband may be able to do this or the rv shop that installed the AC unit.
It may help to post a picture of the junction box with the cover removed.
Keep us posted, Dan
Electrical issues-66 Safari goshawks00 Lights - Interior & Exterior 15 09-07-2011 08:16 AM
Electrical issues with clearance lights 1987_345 Classic Motorhomes 13 08-25-2011 08:13 AM
Electrical issues! runningbarre Electrical - Systems, Generators, Batteries & Solar 2 06-11-2011 05:11 PM
12v Electrical Issues Clyde-2 Batteries, Univolts, Converters & Inverters 5 10-25-2009 08:12 AM
2005 CCD electrical issues ablaze Electrical - Systems, Generators, Batteries & Solar 7 10-29-2007 05:57 PM
