Old 10-04-2016, 08:06 AM   #1
johnnywood's Avatar
1978 31' Sovereign
1968 24' Tradewind
Salem , Oregon
Where is the 12v fuse block?
Hey guys,
I'm trying to figure out why my trailer brakes aren't working on my 68 Tradewind. Does anyone know where the 12v fuse block is at the end of the 7-way wiring harness?
-johnny
johnnywood is offline   Reply With Quote
Old 10-04-2016, 10:28 AM   #2
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Are you getting power from your brake controller to your plug?
Also check your connection from the trailer side of the cord.
Silverflames is offline   Reply With Quote
Old 10-04-2016, 10:50 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Brakes should not be fused in the trailer. They are fused in the TV.
Check for power at the receptacle of the TV while someone applies the manual brake controller handle. If you have power there look at the end of the umbilical as it goes into the trailer. You should see the brake line brake off there and check for power there.
2004 Excursion 4x4
Old 10-04-2016, 07:39 PM   #4
johnnywood's Avatar
1978 31' Sovereign
1968 24' Tradewind
Salem , Oregon
Yes, I tried my truck out on a different trailer and they work.
On the trailer side I've tried both blue and yellow in the appropriate position and we don't get brakes.
Thank you
Old 10-04-2016, 07:41 PM   #5
johnnywood's Avatar
1978 31' Sovereign
1968 24' Tradewind
Salem , Oregon
Ok, thanks. I'll find the spot where they separate from the umbilical cord.
Thank you.
Old 10-05-2016, 11:44 AM   #6
1969 25' Tradewind
Lamar , Colorado
There is a 12volt fuse in the front where the radio is when it blows you loose all 12volt
Lights and there are more fuses in the rear compartment where the battery is if you haven't already. We have a 69 tradewind and I had similar problem and it was the fuse in
The front by the radio. Bill
bparker3849 is offline   Reply With Quote
Old 10-05-2016, 01:24 PM   #7
1967 26' Overlander
Spartanburg , South Carolina
HowieE is right, there should be no fuse in the trailer brake circuit unless a PO added one for some reason. Sounds like a bad connection or broken wire. Only a trace from the trailer connector back will find it. Have you tried pulling the safety switch to see if the trailer battery will apply the brakes?
Jacob D is offline   Reply With Quote
Old 10-06-2016, 05:20 AM   #8
johnnywood's Avatar
1978 31' Sovereign
1968 24' Tradewind
Salem , Oregon
Do you mean the breakaway cable? Mine doesn't have one, I'll have to get it installed. Would missing this be part of the problem?
Thanks you guys
-Johnny
Old 10-06-2016, 06:28 AM   #9
1968 22' Safari
Dorchester , Illinois
On my 68 Safari the 12v fuse bar is below the sink above the 120v panel. Stand on your head to see it!
Missed-Em is offline   Reply With Quote
12v
Broken Fuse Block In Distribution Panel - How Best To Repair montanaandy Batteries, Univolts, Converters & Inverters 12 06-01-2015 08:01 PM
new fuse block bilby05 Batteries, Univolts, Converters & Inverters 8 01-16-2008 05:47 PM
Fuse Block philippes Classic Motorhomes 6 09-26-2007 08:40 PM
Fuse block driving me nuts! bkahler Mechanics Corner - Engines, Transmission & More... 11 07-08-2007 08:52 PM
Fuse Block replacement - help Craig Electrical - Systems, Generators, Batteries & Solar 6 10-13-2004 03:01 PM
