Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Tradewind > 1959-69 Tradewind
Prev Previous Post   Next Post Next
Old 12-15-2002, 09:28 PM   #1
tw64's Avatar
Profile:
Question what holds black water tank in place
I purchased a 1964 Tradewind recently and of course it needs a little TLC. The black water tank had dropped almost 4", and so did the toilet. I removed the toilet and the underbelly at the rear bumper and then found an access panel at the bottom of the gate valve. It looks like the tank was built in a tin box, suspened some how between the frame. The "tin" seems to have rotted away leaving the tank in a dropped position. Also the aluminum cross brace( you see it when the bumper cover is raised) has dropped down with it. From what has been posted before this tank dosen't protrued above the floor. Any suggestions........
tw64 is offline   Reply With Quote
Modified black water tank Marlboro Mafia Waste Systems, Tanks & Totes 13 03-13-2004 06:31 PM
Black Water Tank David Hall Waste Systems, Tanks & Totes 3 12-28-2003 08:24 PM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 08:59 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 05:17 PM
Flushing Black Water Tank 1985air345 General Motorhome Topics 3 05-16-2002 03:59 PM
