Old 11-03-2017, 04:19 AM   #1
1963 24' Tradewind
Godigana, Terrugem , Sintra Lisboa
Water tanks, repair or replace
Hi! I'm on the water repair section of my 1963 Tradewinds and I wonder if there is a way to clean the inside of water tanks instead of just replacing them with new ones. Has anyone ever tried to do that? Does it worth the effort? I would prefer to keep it as original as possible...
Thank you
Ed
Daddylolo is offline   Reply With Quote
Old 11-03-2017, 05:33 AM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Replace them. You will spend more money trying to repair and clean the old ones.
Old 11-03-2017, 10:58 AM   #3
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
water tank clean/repair
The water system in my 1961 Safari was very similar to what I see of yours. I am guessing you have an air pump for water pressure the same as mine. I removed my tank, inspected the interior as well as I could with a flashlight, then inserted a hose and washed the tank. The interior looked good and there was no sign of any leaks. I then capped off all fittings on the tank except one which I hooked to city water and tested the tank at full water pressure of (72 PSI). I then disinfected with a chlorine mixture, reinstalled the tank and have been using it for more than 10 years with no problems.
samb is offline   Reply With Quote
Old 11-05-2017, 04:26 PM   #4
1963 24' Tradewind
Thanx Samb, I will do as you say, I also believe in recycling and keep it original. All the best!
Replacing water tanks, holding tanks & battery? Nelsons 1956 - 1959 Flying Cloud 57 10-19-2014 08:21 AM
Replace or Repair gray water tank?? boo_n_sue Waste Systems, Tanks & Totes 1 08-17-2010 05:31 PM
I am New. Should I replace my water tanks? chronoboat Member Introductions 7 06-28-2010 02:40 PM
Water heater repair or replace ddsouth Water Heaters, Filters & Pumps 9 06-22-2006 04:29 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
