Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Tradewind > 1959-69 Tradewind
Old 11-07-2009, 10:38 AM   #1
Profile:  1960 24' Tradewind
St. Albans , Vermont
Tub removal in 1960 tradewind
Good morning! We are in the process of removing the bathroom in our Tradewind so that Colin Hyde and fix the floor and chassis. How do you get the tub out? Do you have to remove the wall (has a full bed on the other side)? It feels like there is one more screw somewhere that I just can't find! Arrrgghh! My husband thinks he feels one more screw in the center of the wall directly under the faucet area so he is thinking just to drill a hole to access it-it is in the storage area of the full bed. What does everyone think?
ID:	90487   Click image for larger version
2vets is offline   Reply With Quote
Old 11-07-2009, 10:41 AM   #2
Ken J's Avatar
Profile:  1958 26' Overlander
Tijeras , New Mexico
That trim piece around the tub needs to come out and the tube is either screwed or riveted to the wall - can't remember which... you will need to remove the drain - it may be rusted on the trap below - in my case someone tried to fix the tub with epoxy and it was glued to the floor - in my case it was a crowbar...
Ken J.
1958 Overlander
Ken J is offline   Reply With Quote
Old 11-07-2009, 10:44 AM   #3
goransons's Avatar
Profile:  1969 25' Tradewind
1963 22' Safari
State of , Washington
the metal trim along the top of the tub sides are full of rivets that go into the wall also. the front skirt also likely is screwed to that wood nailer on the floor. also don't forget to remove the strainer plate on the drain. Take your time and don't fore it and it'll come out.
Scott & Megan
Visit our Blog- http://safari8671.blogspot.com
63 PARTS NEEDED
roof locker tracks (plastic)
square cornered astrodome screen
63 refer, or at least the original door insert
2 12v hehr motors (working) w/ or w/o fan blade
goransons is online now   Reply With Quote
1960 Tradewind 2vets 1959-69 Tradewind 20 10-24-2009 07:02 AM
tub and black tank removal nkeeler Repairing/Replacing Floor &/or Frame 3 04-07-2009 06:24 PM
1960 Tradewind JCIPOT 1959-69 Tradewind 68 08-30-2007 05:46 PM
tub removal -- help!!! mgann Sinks, Showers & Toilets 2 04-23-2007 11:19 AM
Tub Removal Procedure Buttercup Sinks, Showers & Toilets 0 05-27-2005 03:59 AM
