Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Tradewind > 1959-69 Tradewind
Old 05-19-2017, 06:26 PM   #141
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
You have a "new" old trailer. Someone is going to get a beautiful vintage trailer with the work already done expertly. Warning, this trailer will not be "affordable", it is for the discerning traveler who wants a piece of history with modern features. Think of the attention it will draw at an Airstream rally.
You are very wise to upgrade the old axle, less the old axle shake your new trailer apart. I see more and more people installing Dexter axles, not the Axis. I understood getting the specifications right for a Dexter axle was a challenge as everything had to be exact. I might try the Dexter next time I need to replace an axle, or two, or three.
Don't you just love installing a new belly pan on your back. Maybe your shoulder is sore like mine was from drilling a couple hundred holes for rivets. A belly pan man I ain't.
Yes, we love to see your pictures.
David
Old 05-19-2017, 08:59 PM   #142
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
Belly pan shoulder, yes, and a kink in my neck. Almost done, going to finish in the morning. Thanks for the compliments. I hope to find it a good home. Gas lines start tomorrow. I'm excited to wrap it up!
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 05-20-2017, 01:27 PM   #143
goransons's Avatar
1963 22' Safari
Two steps forward one back! Got all the gas lines in this morning. Water heater working, stove and oven work, refrigerator works but the furnace is dead. Repaired the gas valve but the cast iron burner is rotted out. I'm going to leave the chimney and build a small oak cover for where it should be and install a wave catalytic heater. Not the period look I wanted but Since I'm selling it I don't want a temperamental appliance I can't work the bugs out of. On order but I can get the other things wrapped up and polish while I wait for the heater to arrive.
Scott & Megan
Old 05-20-2017, 06:13 PM   #144
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My son has a Wave 8000 btu catalytic heater in his Globetrotter. It works darn good. He likes the fact it is great for boondocking, no DC power consumed, and very efficient (like 95%) with propane. They are not so great in Minnesota winters, but perfectly fine in more temperate climates.
You are wise to get rid of the old furnace. They can be hazardous to your health. I prefer a newer, modern one.
Almost done!
David
Old 05-22-2017, 08:33 AM   #145
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
Originally Posted by goransons View Post
Since my last post we've installed a new dexter axle, which was interesting for sure. In 1962 I've heard that Airstream considered the torsion axle to be a "forever" axle so it was welded in. No axle plate at all, just pressed against the frame and welded until the factory ran out of welding rod or the dinner bell rang.
Interesting. I assume you have a California built 1962 Tradewind. My Ohio built 1962 Safari had it's axle bolted in. I had only previously heard that some 1961 Airstreams had the axle welded in, and maybe from California only (can't remember the source of that info, so can't double check to be sure). I wonder if yours was a very early 1962 model?
Joe
WBCCI/VAC #702 & #6768
66Overlander is offline   Reply With Quote
Old 06-04-2017, 06:52 PM   #146
goransons's Avatar
1963 22' Safari
Sorry the updates have been few and far between. We've been working hard finishing up Windy the last few weeks. Megan is just finishing up sewing curtains and you'll find it posted in the next couple days over on the classifieds. Here's pictures so far. We look forward to wrapping up this one and getting to work on the Wally Byam 55 Cruiser and the Cadillac.
Here's exterior shots
ID:	286892   Click image for larger version
ID:	286894   Click image for larger version
Scott & Megan
Old 06-04-2017, 06:55 PM   #147
goransons's Avatar
1963 22' Safari
Interior Shots part 1
ID:	286896   Click image for larger version
ID:	286898   Click image for larger version
ID:	286900   Click image for larger version
Scott & Megan
Old 06-05-2017, 07:09 PM   #148
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Windy is looking great. It will be hard to let it go after all the blood, sweat, tears, and dollars. It's worth a lot.
But the 55 awaits.
Hey, have Megan sew up a set of curtains for my Trade Wind while she's at it.
David
Old 06-05-2017, 10:53 PM   #149
goransons's Avatar
1963 22' Safari
Megan's curtains are done, just a few hooks at the fabric store to hang the bathroom curtain tomorrow.
ID:	286973   Click image for larger version
ID:	286975   Click image for larger version
Scott & Megan
Old 06-06-2017, 03:49 AM   #150
Images: 59
Stunning. Absolutely stunning.
Old 06-06-2017, 10:47 PM   #151
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Really beautiful work! The new owner will be really fortunate to get to camp and enjoy this spectacular Airstream.
Dan
1962, full monte, panel replacement, shell off, tradewind
Top wind or Side wind? kirkrik Hitches, Couplers & Balls 14 08-11-2015 08:40 PM
Tin Can Dreams and Wee Wind Wishes avenuegirl Member Introductions 9 09-30-2008 08:53 AM
Just signed on and just started my 61 trade wind Craig Murphy Member Introductions 11 10-25-2007 09:28 PM
Rims and tires for my Wee Wind vonkamp Tires 9 11-30-2006 09:55 PM
Wind screen sealing and veneer replacement abridges01 Argosy Motorhomes 8 09-04-2006 10:05 AM
