Old 01-12-2017, 06:11 PM   #85
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Plenty of panels like this that are trash
Name:	ImageUploadedByAirstream Forums1484269707.488295.jpg
The good news is I'm only a sheet in so far but know I'll be in several more fixing doors and drawers
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
Wally Byam's 1955 26' European Caravan Trailer!
goransons is offline   Reply With Quote
Old 01-12-2017, 09:03 PM   #86
goransons's Avatar
1963 22' Safari
I'd sure appreciate it if folks could keep an eye out for these pop in vents. I'm short a lot. I need to do a final count but need a dozen or so. Haven't found a source yet locally. They are smaller than ones I've purchased for soffits etc. Anyone have any ideas?
Name:	ImageUploadedByAirstream Forums1484280145.071218.jpg
Name:	ImageUploadedByAirstream Forums1484280164.883776.jpg
Name:	ImageUploadedByAirstream Forums1484280176.886630.jpg
Sorry for the bad tape measure. It's an old stand by and the shop was down to 4 degrees so I moved fast!
Scott & Megan
Old 01-13-2017, 07:36 AM   #87
1968 22' Safari
NorCal , California
Round louvered vents
You can find some similar online. I'm not sure if you're trying to match the same vintage or not but here's a google search that turned up several options.
http://tinyurl.com/jc7rjqp
Gratitude for all there is and all there isn't!
Photos of our gal.
WBCCI #19233
EmptyNesters is offline   Reply With Quote
Old 01-13-2017, 10:06 AM   #88
goransons's Avatar
1963 22' Safari
Thank you! Yeah I'm hoping to match if I can. Lots of plastic ones out there. I like the lines of the original Better than the simplified newer ones but they are certainly better than a empty hole in the cabinet. Each double wardrobe has 6 of them, 4 of them on the singles. Maybe someone has a drawer of used ones they saved?
Scott & Megan
Old 01-13-2017, 11:55 AM   #89
Central , Mississippi
I know I have some, lemme look tonight.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-13-2017, 04:52 PM   #90
Will this get you started?
Name:	ImageUploadedByAirstream Forums1484351532.805912.jpg
Old 01-13-2017, 05:57 PM   #91
goransons's Avatar
1963 22' Safari
Thank you! I just got home from a quick hardware run. Was tipped off locally that one of the mom and pop stores and they had some in a bin the back. I just got on to post and saw your stack. Thank you for looking but they have me covered and they look really close.
Name:	ImageUploadedByAirstream Forums1484355463.353290.jpg
New on the left
Scott & Megan
Old 01-18-2017, 06:14 PM   #92
goransons's Avatar
1963 22' Safari
Today we woke up to almost a half inch of freezing rain so no work today. It briefly was above freezing for a change so I heated up the garage and got to work.
Water tank cleaned up, polished the filler pipe and put 3 coats of clear on it. Started to polish the cap too but have more work to clean out the years of pliar marks.
It's ready to go back in after one more rinse.
5 more drawers and 4 doors were refinished today although nearly all the prep work had been done already. The bathroom vanity now is complete and ready to reassemble once the hardware is stripped. Kitchen cabinet is nearly complete, one more upper door and one lower left
Also heated up the trailer and cut in for the final color so I can put up the kitchen roof locker for good and install the lights and power everything up on the 110v side.
This week is supposed to be wet, but some days above freezing so I hope to finish painting the sheet metal and install the cabinets that are already done.
I still have 17 more doors and 5 bed drawers and one false front left.
I'm stunned how much storage this thing has. It's no wonder it's the "caravanner" layout. Tons of room for long trips for someone
Grover water pump is in great shape although we'll be going to a modern on demand pump.
Scott & Megan
Old 01-18-2017, 06:32 PM   #93
goransons's Avatar
1963 22' Safari
Name:	ImageUploadedByAirstream Forums1484789487.786538.jpg
Name:	ImageUploadedByAirstream Forums1484789510.342666.jpg
Name:   ImageUploadedByAirstream Forums1484789528.729142.jpg
Name:	ImageUploadedByAirstream Forums1484789540.234569.jpg
ID:	278383Click image for larger version
Name:	ImageUploadedByAirstream Forums1484789554.692649.jpg
Scott & Megan
Old 01-20-2017, 06:40 PM   #94
goransons's Avatar
1963 22' Safari
Tomorrow the power finally goes on. All the lights are painted and will get reassembled tomorrow. So happy the PO didn't toss them. They cleaned up nicely
Scott & Megan
Old 01-21-2017, 04:09 PM   #95
goransons's Avatar
1963 22' Safari
Kitchen cabinet is in for good, roof cabinet is back up, doors starting to go back on and managed to get the lights all up minus the kitchen one. I'll need to pick up parchment for the sconces. 110 is on, but not 12 volt yet
Scott & Megan
Old 01-26-2017, 12:28 PM   #96
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thank you for the photos of your restoration project. It is looking great. Not very many can start from the exterior skin and work their way in. I know I could not. You are building a great thread for those who may happen to find a Tread Wind shell in the street after a storm.
Very nice period look.
David
Old 01-28-2017, 08:00 PM   #97
goransons's Avatar
1963 22' Safari
Thanks David! It's progressing. It's not perfect but will be a nicely cared for original interior. This one has such a unique layout I didn't want to toss it, although I have way more hoursvin veneer repair and replacement and sanding than it would have taken to build new. Sorry these pictures are at night. Doors are on, front most tall door still needs one more turnbuckle installed but I need to find one or make one. Bathroom cabinet doors are on water tank is in. Hope to finish painting tomorrow while I wait between coats of finish on the roof locker doors and doors over the refrigerator.
Scott & Megan
Old 01-29-2017, 05:34 PM   #98
goransons's Avatar
1963 22' Safari
Doors doors doors. Only 2 to make and 5 drawers to sand left
Scott & Megan
1962, full monte, panel replacement, shell off, tradewind
Top wind or Side wind? kirkrik Hitches, Couplers & Balls 14 08-11-2015 08:40 PM
Tin Can Dreams and Wee Wind Wishes avenuegirl Member Introductions 9 09-30-2008 08:53 AM
Just signed on and just started my 61 trade wind Craig Murphy Member Introductions 11 10-25-2007 09:28 PM
Rims and tires for my Wee Wind vonkamp Tires 9 11-30-2006 09:55 PM
Wind screen sealing and veneer replacement abridges01 Argosy Motorhomes 8 09-04-2006 10:05 AM
